Question about Acer Aspire X3200 PC Desktop
The computer acer x3200 goes dead and wont come back on unless the power cord is removed for a few seconds when it goes dead it is as though the plug is out
    Guru:
  • 2,178 Answers
Your power supply is going bad or there is a bad start-up capacitor on the motherboard that's bad. Replace the power supply or have it tested from a qualified technician. If the power supply is good, then the motherboard has a bad capacitor.
Posted on Dec 29, 2010
Lg ibm multinet i tower allows power to the motherboard but wont start up, what should i do?
remove the power cord, remove the bios battery, short the two contact together in the battery holder for a few seconds, replace the battery and power cord and try again.
if that doesn't work, start removing items/plugs (not the big 20/24 pin one) from the motherboard until you get beeping noises.
if still nothing then put everything back and try a different power supply.
if that doesn't work, your motherboard is probably dead.
Apr 18, 2014 | Computers & Internet
How to remove hard drive from acer aspire x3200
Remove the cover/side panel on the case to get access to the components inside the computer.
The SATA hard drive is secured to the disk drive bay with 4 screws.
Unplug the SATA data cable and power cable from the hard drive, then remove the 4 screws securing the hard drive in the drive bay.
The hard drive can be removed from the drive bay.
Reverse this order to fit the hard drive back inside the computer.
Oct 05, 2012 | Acer Aspire X3200 PC Desktop
ACER ASPIRE ONE 722 WILL POWER UP FOR 5 SECONDS THEN GOES DEAD
If it's not plugged in then it sounds like the battery is dead. If it is plugged in then your power cord/charger is probably dead.
Jun 26, 2012 | Acer Aspire One 722-0022 : 1.0GHz C-Series...
My friend has just moved and his comp was working before. But now when plugged into power the tower has no power. Any suggestions to what might be going wrong?
firdt check another outlet ,that outlet maybe dead. then check if the power cord is properly seated in the plug at back of tower, then check if it has a reset button power supply, then open the case and check if duing moving the inside power connection came loose. check all the connections, then If it still wont work, either the power supply went dead or somehow the system motherborad fried
Jul 12, 2009 | HP Desktop Computers - Hewlett-Packard...
Acer Aspire won't start
There is one common flaw with most all laptops. The socket plug for the power cord is connected to the motherboard. When you plug the power cord into this socket it applies pressure or weight on the socket inside the computer. It sounds as if your charge cord is working. Moving the computer around while it is plugged in can cause even more stress on the plug socket.
Try this...but be careful...using a small item such as a toothpick or other non-metalic item...push up and down on the plug socket. If it moves around this is not normal and probably the cause of your problem.
I fixed my laptop by soldering the contacts of the socket back down to the board. I don't suggest doing this yourself unless you know how to take a laptop apart. Check with your local computer repair shop and have them give you an estimate to either fix by reconnecting or replacing the motherboard. Hope this helps. Thanks!
Jun 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Computer won't turn on though plugged into wall
Make sure you have power at the outlet. Take power cord off and remove battery. Hold power button down for 10 seconds, plug just power cord. Try to turn on. If dose not work , you have a hardware issue.
Apr 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Laptop no power, power cord lights up
You should try unplugging the laptop from the power and taking out the battery. Then after about 30 seconds plug the battery back in and attempt to turn the computer back on.
Feb 02, 2009 | Toshiba Satellite M40-S417TD Notebook
make sure the plug is completely secure into the back of the laptop.. i also have an acer aspire..
maybe someone spilled their drink on it...
..idk..
Jul 30, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire X3200  PC Desktop Logo
246 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
