Question about JVC RX-668V Receiver
Trying to hook an aux cable to my jvc rx668v but can't find the mode
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I have Bose speakers hooked up with JVC RX668V and
What models of speakers all around? Certain combinations of speaker efficiencies won't be within this unit's capabilities to compensate the volume.
Starting on Page 17 they discuss how you can adjust the Digital Acoustic Processor (DAP) mode to modify the levels of the rear speakers -10dB to + 10dB.
Starting on Page 20 they have similar settings for 5.1 discrete analog inputs.
Posted on Mar 02, 2010
My jvc mx-kc58 compact shelf stereo the aux in mode sounds far away an i can barely hear the words in aux mode only cd player sounds normal
It sounds like whatever is connected to the aux socket has a bad earth connection check and replace the cables to it.
Dec 23, 2016 | JVC MX-KC58 Shelf System
I have a JVC RX-7010V AUDIO/VIDEO CONTROL RECEIVER. And I can not get it to hook up to my TV for surround sound I have to hook it up through my headphone jack on my TV.
On the back of the JVC receiver, there should be a TV input, Coax IN and OUT or AUX input (I don't remember if this model had HDMI). On the back of your TV, there should be an AUDIO OUT, connect this to either the TV or AUX inputs and make sure on your TV, to set the Audio Out is On in the TV menu. Turn on JVC and set input to TV and adjust volume. Another way is using the COAX input and outputs. Connect Output of cable box to Input of JVC, then connect Output of TV to Input on TV.
May 15, 2016 | JVC Audio Players & Recorders
Trying to hook up tv to JVC RX-315 and not sure what to hook up where
Hi,here is my simple solution...
If you want to listen your TV on your Stereo system thru your receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on RECEIVER corresponding your RCA or Optic connection..
There you go..Your TV sound is on the Receiver..By this means whatever you watch on the
TV (
tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 24, 2011 | JVC Audio Players & Recorders
How do I turn my jvc kd-g200 to aux mode?
Thi JVC KD-G200 does not have an auxiliary input, or aux mode. If you want to play audio from an external device through this unit, you will need a FM transceiver.
Mar 03, 2011 | JVC KD-G200 CD Player
I have Bose speakers hooked up with JVC RX668V and the rear speakers aren't loud enough! What can I do to get more volume?
Mar 01, 2010 | JVC RX-668V Receiver
JVC AX-66 Integrated Amplifier seems to be muted?
You need to have a jumper between the 4 standalone jacks on the right side of the column of stereo connectors. A stereo RCA cable would work for this.
Oct 14, 2009 | JVC Audio Players & Recorders
I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Troubleshoot auxiliary equipment
There is no Phono input on your JVC.
What TT are you trying to hook up? If it's a traditional one you would need a preamplifier to boost the tiny signal from the cartridge to a suitable level for the AUX to use.
If you have an old traditional receiver with a Phono section hanging around you could rig something up between it and your JVC.
Plug the TT into Phono on the old receiver. Run RCA cables from any Tape REC output to the AUX. Done.
Jul 12, 2008 | JVC MX-D401T Shelf System
Hook up IPOD
I am not sure if the model you have supports iPod control, but if it has an input jack in the front, you can use a cable from the headphone jack into the Aux jack in the front of the stereo and when there is a cable inserted into the jack you will be able to select Aux with the source button.
The other option is to get a kit installed at your car stereo place that will allow you to connect it via 3rd party hardware.
Cheers
May 30, 2008 | JVC KD-SX840 CD Player
JVC RX-668V Receiver Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
