Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chainsaw starts runs 5 seconds then turns off
    Brigadier General:
  • 4,088 Answers
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Does the primer bulb fill with fuel after several pumps? The carburetor may need to be cleaned internally if the above doesn't help. Check the condition of the lower diaphragm for flexibility and no cracks or holes when working on the carburetor. Inspect the insulator inside the spark plug--it should be a light tan color if running correctly, but may be black (too much fuel) or white (insufficient fuel). Macs seem to require judicious use of the choke until warmed up. Make sure the 'fast idle' is being set (don't 'blip' the throttle during warm up). Hope some of this helps!
Posted on Dec 29, 2010
Cant get enought gas
repair - What should I check if my chainsaw fails to start ...
diy.stackexchange.com/.../what-should-i-check-if-my-chainsaw-fails-to-s...
Feb 26, 2013 - Does anybody have any idea what I can do to get my chainsaw started?... Clean carburetor and fuel lines, especially if it may contain old fuel. ... that prevents it from generating enough current to sustain repeated firing of the spark plug as the engine turns. ... Your muffler is pluged up your saw can't exhaust.
Stihl Chainsaw - starts but won't run - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Aug 9, 2006 - Re-chocking (once until it kicks) gets it running again for another 20-30 seconds ... carb body was not letting enough gas through to contunue running the saw at full speed ..... MY STIHL 029 CHAIN SAW BLOWS GAS BACK OUT OF THE .....Can't imagine why shaking the saw around would keep it running. Chain saw won't start
Feb 8, 2012
homelite xl chainsaw
Sep 4, 2009
Husqvarna chainsaw wont start?? HELP
Oct 15, 2006
chainsaw starts then after few cuts shuts down
Mar 30, 2006
More results from forums2.gardenweb.com
chainsaw won't start - any ideas? [Archive] - Straight Dxxe ...
boards.straightdope.com > ... > Main > General Questions
21 posts - ‎11 authors
Jan 31, 2016 | Garden
Why does my chainsaw sthal out after about 5 seconds after easily being started?
Does the clutch brake work ok? Had a similar issue with mine, turned out the chain was trying to drive at all times
Oct 07, 2014 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Changed carb on a stihl 025 from a single set screw to a double set screw . what settings do i need to start initially
on the needle setting closest to engine(air) it is turn clockwise till it stops, then open it up counter clockwise 1 turn. The second adjustment needle, should be turned clockwise till it stops, then opened up 1 1/2 turns. Adjust the second or gas, until your engine sounds like it is running it's best.
Dec 06, 2013 | Stihl Chainsaw 42mm Piston Rings 025 O25...
Saw runs good but when shut off it wont start again for sometime
Check your fuel filter in case it is clogged. When starting pull cord on full choke 5 times quickly. Wait 2 or 3 seconds...try again if it asks like it wants to start..then put on 1/2 choke...goes thru same process. Check spark plug.
Sep 28, 2013 | Stihl 25" Chainsaw Saw Bar 30030008830 Ms...
Mcculloch 210 strimmer lost power now wont start for more than afew seconds
remove the muffler and run it the mufflers plug up and restrick the exhaust some mufflers you can open and clean the screen
Sep 14, 2012 | Garden
Starting procedure for stihl 012 av
Full choke, stop switch on run. Pull rope handle 3-4 times or more until it "tries to start" (it will not start, but it will try to for a split second) move the choke lever to the half-choke position and without pulling the throttle, poll the rope handle until the engine fires and runs for 4-5 seconds then fully open the choke to the run position, let it warm up for 25-30 seconds (don't forget to let it cool down about 45-60 seconds before you turn it off!) and then proceed to use it.
Aug 07, 2012 | Stihl Garden
Will start on choke and run 5 seconds. will not start unless on choke when i try to rev up it goes dead.
Clean or replace all fuel components.Change the spark plug or coil.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Starts very easily runs for 5 seconds then dies, pump quick start bulb once, starts in 1 pull run for 5 seconds , new clean fuel, carb still has factory stops on adjusters limiting change to about 1/4...
hi , if you have a compression tester use that to test for worn piston rings /scored cylinder , if not remove the exhaust and visualise the cylinder and check for scoring , remove the spark plug and block the hole with your thumb , it should feel nice and night when you pull the saw over , if it fails then you will need replacement rings and/or piston and cylinder .
hope this helps
May 20, 2010 | Garden
The second hand McCulloch 120 chainsaw I purchased
I think the pre-adjust settings are to turn jets in all the way and back out 1.5 turns each. then:
You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Jun 08, 2009 | Standard Oregon Chainsaw Chain For...
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
136 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
