Question about Samsung Televison & Video
Smuges on glass even after wiping with sanus screen cleaning gel
    Brigadier General:
  • 8,909 Answers
Try using a mild solution of washing up liquid and warm water. If it is still there afterwards, it is probably an abrasive mark, which of course will not come out.
Posted on Dec 29, 2010
I cleaned my projection panasonic magnavox tv with windex, not there are streaks coming up from the bottom of the screen followed by black spots, did i damage it completely, should i turn it off, and let...
Never spray directly on a screen. If the solution seeps into the underside (back etched side of the glass) it could damage the surface. You may have to get to the inside from the rear projection area or lift of the front glass screen and remove it completely. Usually the Rear surface of the screen is etched and can be wiped clean. Go to Bed Bath and get a good streak less windows cleaner. Spray it on a soft cloth and wipe the front and/or back glass. Wipe dry with a CLOTH, not a paper towel, and when dry use a flash light to see any streaks or blemishes left behind. Clean again is necessary. Do not apply pressure, gently clean and try not to cause scratches as they show up when the projection device flashes the image on the glass portion. Put it all back they way it was and enjoy.
Dec 18, 2013 | Philips 9P6040C 60" Rear Projection...
I seem to have a grease marks on the screen how do I clean them off
Glass on window cleaner is fine- But you wipe it straight away as the liquid can spread under the LCD.
Hope this helps.
Wely250
Jul 02, 2012 | Computers & Internet
How can I remove the scratches from my glass coffee table?
Unfortunately, there is no safe way to remove scratches from glass. I don't recommend trying anything at home because you could make it much worse. If you are bent on keeping the table I suggest taking it to glassworker to see if he can sand it down with special tools.
May 29, 2012 | Furniture
My glass aquarium cracked. How can I fix it?
There are a few steps to take to fix a cracked tank:
  1. 1. b>Move the fish to a backup tank with cleanwater
  2. 2. Wipe the crack with white vinegarto clean the glass and let it dry completely. This will allow the silicone tostick.
  3. 3. Line the crack withaqua-marine safe silicone gel
  4. 4. Let the gel dry completely(usually overnight) before returning the fish to the water
May 13, 2012 | Fish
My screen suddenly shows blue and pink vertical lines
Sounds like the gel has dribbled down into the workings and has effected the circuitry. Time for a new monitor. More importantly, why the heck were you using a liquid/gel sanitiser on electrical equipment. Use dedicated screen wipes
Sep 27, 2017 | Computers & Internet
How do i safely clean my samsung epic screen?
you can simply use glass wipes as you would for your glasses, buy either using some lens cleaning wipes or spray on a cloth first. then purchase some screen protectors like below for example
http://www.amazon.com/Three-Screen-Guards-Protectors-Samsung/dp/B0044NV3VY/ref=sr_1_1?ie=UTF8&qid=1305134276&sr=8-1
May 11, 2011 | Cell Phones
Want to clean inside of glass
there is no way to clean the inside of the glass. The CRT is a completely sealed unit and unless there has been a malfunction, there should be nothing on the inside of the glass. The way CRT's work is a photon gun shoots electricity at the inside of the screen, which is coated with a layer of phosphur. this excites the phosphur and makes it glow with color, forming the picture that you see. Even if you could get at the inside of the glass, you wouldn't be able to clean it becuse you would wipe away the phosphur coating.
Mar 21, 2011 | Gateway VX 720 17" CRT Monitor
On sending a fax the receiver copy has a black
You must clean the glass strip that the origional passes over to be scanned. You may have White-Out or an Ink smuge on it. Another way to determine if it is your FAX is to put in an original and make a copy. If the line is on your copy than it is your scanner **** (glass).
Oct 30, 2009 | HP Officejet 6500 Wireless All-in-One...
How to clean screen
I have never seen a mfg that recommended anything but a soft cloth and warm water on it, and below is what your manual say about cleaning. You should just use what the manual says.
Use a soft cotton cloth to gently clean the screen.
2. The screen glass is very fragile. Do not scrape it with any sharp object. Do not press or tap
the screen to avoid cracking. When the screen is seriously contaminated, use a soft cloth
moistened with diluted neutral cleaner to clean the display. Wring water out of the cloth
before cleaning to prevent water from penetrating into the housing. Wipe the display with a
dry cloth after cleaning.
Apr 13, 2009 | Vizio L32 32 in. LCD HDTV
Horizontal ink smuges
You probably have a buildup of partially dried ink on the carriage itself. I don't know how difficult it is to access the carriage on your machine but if you can force-feed several sheets of paper under the carriage and put a broad streak of alcohol across the sheets, you may be able to 'wipe' the ink buildup off of the carriage without disassembling the machine.
Mar 11, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
