We have a Risograph GR3770. It has been great but last week it decided not print correctly anymore. It is about 3/4" off on everything we print. We put the margins over as far as it will go, but it is still off about 1/4". We have reset everything, unplugged, cleaned, checked the machine, etc. It is not under a maintenance contract anymore since it is so old. Is there something we can do or do we need a tech. to come look at it? Any suggestions would be great. Thanks!
printech
  • 159 Answers
SOURCE: printing dots on Brother HL 4040CN
do this procedure
1.print test page then stop the printer on the middle print proses by turn the printer of or open the rear cover
2.remove the paper jam carefully
3.look to the paper if the problem found change the drum unit els the fusser unit cause the problem
Posted on Apr 01, 2008
SOURCE: Epson 9600 suddendly stopped printing yellow
We have the same problem a couple months ago. After changing the button battery on the back of the printer,  everything were back to normal.
Posted on Sep 24, 2008
  • 13 Answers
SOURCE: Optra T610 Print Problem
Your paper size settings for Tray 1 is probably wrong. Make sure it is set to Letter and the type is Plain Paper. If your Paper size is Universal, then either the paper guide in the tray is set wrong or the paper size sensor is broken. If the sensor is broken, you can disable auto paper size sensing so the printer will allow you to specify a paper size. To disable paper size sensing, you need to go into Config Mode. The other way is to send a PJL command to the printer to disable the function.
Posted on Feb 08, 2009
POCBM
  • 121 Answers
SOURCE: 4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Posted on Apr 07, 2009
SOURCE: paper and ink lights blinking
Try doing a printer check by doing the steps below. If it doesnt work, then try to call the printer manufacturer for more advanced solutions or information
  1. turn off the printer and disconnect it from computer
  2. place a plain sheet of paper
  3. press and hold down the paper feed button, then press and release the power button. Continue holding down the paper button until you see the power light flashes
  4. if it prints a test page it is working fine, the problem might be the computer settings, printer settings, software or printer application, or cables, otherwise the problem is the printer itself
Posted on Apr 12, 2010
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
How do remove jammed master from the disposal unit on a risograph GR3770?
This model is pretty obsolete, finding someone to service it will be difficult, and most will only promise to attempt it and not warranty the work, never the less, its what I recommend. If you must attempt it yourself, I recommend a set of picks from Menard's (around $5 for a set, they look like dental picks) and an exacto knife and then cut the master free in small pieces.
most riso techs who are trained on these will do a partial disassemble. If this were an RZ or an EZ I'd be willing to try talking you through that. I don't recommend it if you're a novice on these though. They're much crankier.
Jul 14, 2014 | Riso Office Equipment & Supplies
My OfficeJet J4680 Stopped Printing Wirelessly. I have an Acer Aspire One netbook running XP 2002 Service Pk 3. I have an OfficeJet J4680 which is hardwired to my main computer, a Mac mini and connected...
I've seen this happen on several HP printers. You have to "point" the computer back to the right IP address. Go into the printer properties, under the Ports tab, and highlight the correct port for that printer. Then click on the Configure Port button below the list of ports. Next to "Printer Name or IP Address," type in the correct address -- 192.168.1.110. Then click OK to exit that window and OK to exit the Properties window and save the change, and after a couple of seconds for the IP address change to take effect, you should be able to resume normal printing.
Jul 11, 2011 | HP J4680 Office Jet All-In-One Printer
I have an old (more than 15 years old!) Hotpoint dryer..it has lasted me forever and I have never had to replace anything on it..however last week it decided that it didn't want to turn on anymore..i set...
usually, this is a simple "belt" replacement and you can do it yourself if you are somewhat handy. However, make sure that you UNPLUG the unit prior to attempting any repairs. SAFETY FIRST! Good luck.
Jan 20, 2011 | Dryers
Risograph GR3770 - cannot pul out the drum, Error code T14. How can I pull it out :)? thanks
This solution is ONLY for pulling out the drum.
Open front door. If you look at the metal housing below the drum you will see a plate mounteg with two screws. Get it off and you will see a small lever. Turn it right to loosen the drum. Be extremely careful when pulling out the drum. If the drum is not in zero-position it might be a bit difficult (e.g. have a look at the master clamp). Please note that it may be difficult to insert the drum again.
Jan 03, 2011 | Riso RZ220 Duplicator
Anybody know if Risograph GR hd black ink is ok for use in Riso FR machines?
Short answer is no. RISO GR HD ink is only compatible with a GR3770, a 600 dpi machine.
Mar 05, 2010 | Eagle Signal Br1 30min Reset Timer
Print from Memory
Check and see if your fax has a power save button next to your LCD screen. Pressing it will store everything into memory or you could do a flash memory clear however you will lose everything that is stored in memory(RX and TX only). Press FUNCTION , 9,*,8,#,7 then press start, next press your # key to scroll to flash memory. Press start. This should fix it.
Apr 23, 2008 | Sharp FO 5550 Plain Paper Laser Fax
Sony
Check the disc is not damaged or got finger prints on...
connect the system to a wireless network to get the latest software updates.
Dec 12, 2007 | Sony PlayStation Portable (PSP) Console
47 people viewed this question
k24674
