Heater fires but cuts out again after 30 seconds
  • 111 Answers
Sounds like flame sensor.try taking it out and polish with steel wool.flame sensor is a rod that is in flame with a single wire going to it.If there is no flame sensor,check limit switches,but they usually have to be reset when triped.high limits usually reset when cool.check flew for blockage if theres air conditioning,check a coil could be dirty.if every thing else is ok then control board is bad.real hard for nubies to diagnoise.
Posted on Dec 29, 2010
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
I have a Reddy heater 30-55,000 btu.. When lighting it I press in the initer for the recomended time but after I release it the flame goes out.. Can you tell me why?.
It seems as if you are not holding the igniter long enough after it fires, have you tried holding the igniter down for a few seconds more to allow the safety cut out to warm up, (Similar to the gas heaters, when ignited keep the flame going for the thermal coupling to heat up), If you do this and it still goes out the safety valve is faulty, but try holding it in longer before messing about with the coupling.
Jan 05, 2012 | Reddy Heater-30-55,000 BTU Variable
Spark plug fired,( Sears -30,000 BTU) starts and runs for approx. 30 seconds, then cuts off. The reset button does not reset for restart for about another 20 - 30 seconds. Then the unit will restart...
check and see if the heater has a high temperature limit switch. if it does it will shut the machine off until it cools down.. just replace it with a new one.
Jan 31, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
What makes the heater start up then cuts off after about 5 seconds with a little of kersone running out of the front of it
This is normal. It has a time limit to fire off. The heater will cut off if it does not light.It sounds like it is never lighting up. Check your ignition source. I am not sure if you have a spark plug type or a glow bar.
Jan 03, 2011 | Reddy Heater-30-55,000 BTU Variable
My water heater cuts of after 30 seconds and shows C2, 11 code
sounds like your gas lines are too small or not enough pressure... or you may have to clean the rods
Jan 13, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
My central heating unit is in the attic of my 2bd/2bth house. I don't know its age. It's a gas unit, but doesn't have a constant pilot flame. Rather, the pilot is ignited electronically. The problem is...
You don't mention make or model so here is my guess as to how to thinkout the trouble of what ever is in your attic.
For some reason, your heater is mis-firing. Normally, I would expect 3 to 5 such events at which time the heater goes out on safety. The heater knows it is on safety but you don't until it gets cold in your house. When you turn the power off, wait the 30 seconds, turn it back on, the heater no longer knows it is on safety (memory cleared) so it fires. Your heater continues to fire until ? at which time it starts counting again to 3 or some number. At the max mis-fire number - it goes out on safety again ... repeat - turn it off, wait 30 seconds, turn it back on - no memory and so forth.
Do you have a service contract or regular service man? Might be time to find one.
Thanks for your question at FixYa.com
Jan 05, 2010 | Heating & Cooling
My heater will fire but after usually after 30 but then cuts out
could a bad high limit switch on the heat exchanger .
or most likly a flame proofing switch in burner
Dec 10, 2009 | Cozy Enclosed Front Console Heater 70,000...
Unit fires for 30 to 45 sec then cuts off
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 13, 2009 | Reddy Heater-30-55,000 BTU Variable
All pro 115k
This sounds like you will need to replace the thermostat!
That should fix this common problem!
Dec 20, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy heater won't stay on
sounds like a Thermal Cut-off this is a small sensor that detects if the heater has ignited properly, sounds like this sensor has failed and the heater shuts off to prevent from gassing anyone
Nov 02, 2007 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
