Question about Fisher Micromaster I Binocular Microscope
The mechanical stage adjustment on my fisher scientific micromaster does not go (either to the left or right) as far as it previously did. I am no longer able to read the entire field of a rafter cell slide. What can I do to fix this?
  • 43 Answers
The gear that runs along the stage is probably loose. It is held in place by three screws. If the gear is nots parrallel with the X/Y axis gear it will bind. My guess would be that it is the two outer ones that are loose, thereby creating a see-saw affect.
Posted on Dec 30, 2010
Sparks/fire when plugging USB from scope to computer.
You probably have done this, but......try a new and top line USB cable. rj
Sep 26, 2017 | Fisher Scientific Micromaster Inverted...
Fisher and Paykel GW512 wont complete spin step.
This the lid lock device
If lid is open circuit, one of the wires have came off the plug.
Jul 19, 2012 | Fisher and Paykel Washing Machines
Can I readily remove the stage from a Micromaster I, in order to examine a larger object (eg.violin) ? And then reinstall it without damage? Thanks Sam
Yes you can. Probably the best way is to remove the whole focusing assembly, otherwise once you remove the stage, you will have the sub-stage (where the condenser is) in your way. To remove the entire focusing assembly, you will first need to remove the sub-stage. On the left hand side of the sub-stage arm you will see a tiny set screw. It should be a flat head one, and you don't need to remove it all the way, but you have to back it of a ways. Once the screw is backed off far enough, the sub-stage can be lower down to a point at which it will come off. That will expose 4 hex screws; remove those 4 screws and the entire focus assembly will come off.
That should give you enough room for a violin to fit under it, but you are still going to have issues with focusing in on it. With the focusing assembly gone, there is no way to easily adjust your focus. You will literally need to act as the focusing assembly by lifting it up, or pursing it further way. You will also run into an issue with light... there isn't going to be any, but you can use an external light source from above, like a desk lamp or better yet a flash light; something that has a focused light would be best. Ideally this would be a fiber optic light source.
If you haven't already bought a microscope yet though, I would strongly consider getting the right type of microscope for this, which is a stereo for magnification of 100x or below, or you could do it will a transmitted inverted metallurgical microscope for magnifications above 100x. Where you might be able to get the micromaster to work, it really isn't the most ideal candidate for this type of application.
Feb 02, 2011 | Fisher Micromaster I Binocular Microscope
How to calculate 3.009 X 10 -6 power in scientific notation with Casio Fx-115 ES
You don't need to calculate it. Just press
3 . 0 0 9 x10^x (-) 6
to enter the value.
x10^x is on the bottom row, to the right of the decimal point key.
(-) is on the far left column, above the RCL key.
Jan 27, 2011 | Casio FX-115ES Scientific Calculator
Just acquired a used "Micromaster" scope from
Sounds like you have the wrong bulb installed. This scope requires a 6v-20w halogen bulb. They are available from: Delta Optical Instruments, Inc. email: robin@deltaoi.com
Oct 28, 2010 | Fisher Micromaster I Binocular Microscope
How do I fix a mechanical stage from ''drifting'' downwards? Won't stay in position.I move the stage up into position under the objectives but as soon as I let go of the knob the stage drifts right back...
You need to tighten the coarse adjustment so it generates enough friction to keep the stage in place. How to tighten it will vary from scope to scope, but most just have the screws on the knob (metal circle inside the knob with two holes in it). To adjust this type, you'll need a special key wrench.
Feb 03, 2010 | Science & Laboratory
MW512 filling in spurts then goes to error.
it nneds a new Outer blance switch , cheap nd easy to fix
Jan 23, 2010 | Fisher and Paykel Fisher & Paykel Washer
RE: Fisher Model CA-270 - 480 watts.
These units use amp-pacs for the output stage, if I remember correctly. All in all, the unit will require some diagnosis to determine the problem with the power supply and the final output stage. The total cost of repair easily could exceed $125. You can probably replace the unit with a better one for not much more.
If you would still like this unit repaired, please indicate where you are in the country and I'll try to find a shop for you.
Dan
Aug 12, 2009 | Audio Players & Recorders
Fisher Micromaster I Binocular Microscope Logo
194 people viewed this question
Top Fisher Science & Laboratory Experts
J.D. Browning
J.D. Browning
ray gallant
Tom Chichester
Are you a Fisher Science and Laboratory Expert? Answer questions, earn points and help others
