Question about Dell Dimension E510 PC Desktop
My dell E510
I have two problems. One is my Dell E510 has two HDD (160 GB). One its for back up, the problem is that the computer doesn't reconize it. How I can do about it?
The second problem its I have an external HDD (USB conection) and the same thing happining, the computer doesn't reconize it.
Thank you for you help.
  • mromaine Nov 14, 2008
    Same here. I just installed a second internal SATA HDD and it isnt showing up in explorer.
    Scholar:
  • 86 Answers
Both of you could try going to control panel/add new hardware and follow it through. Most likely the second HD is still raw - not formatted -hence doesn't show because as far as windows is concerned it isn't there.
Try that first
Posted on Dec 11, 2008
Can't turn my computer on and i have a yellow blinking light on my dell dimension E510
Do you use a surge protector? If you do, try turning off the power supply to the surge protector and switch on again.
There are a number of causes for this problem, the most likely being a PSU problem or a motherboard fault/failure. To check the power from the PSU to the motherboard, you will need a multimeter to make sure enough power is going to the motherboard. Also check the motherboard closely to see if there is any signs of corrosion or blackened areas, which could be caused by overheating components. Check for leaky or burnt capacitors.
Apr 13, 2012 | Dell Dimension E510 PC Desktop
Dell dimension c521
it could be and issue with the system board to confirm that try to run a HDD test once using an alternate video source to check id display coes on alt monitor...are u able to enter the BIOS check once.
Feb 12, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
Reset memory
Perhaps you mean to "re-seat" the modules?
To do this, unplug the PC, push the power button for a moment to discharge any power left on the board.
Then open the side panel (on your Dell the side panel release is on rear-top of the unit; push the black knob towards the back and it will release the door).
find the ram modules, and push the clips (normally white or black) gently toward the board, and it will eject the module. Do the same on the other side of the module.
If you are trying to troubleshoot a non starting computer, re-seat both modules and re-test. You can also try one module at a time if that doesn't help.
Nov 13, 2011 | Dell Dimension E510 PC Desktop
Regarding Adding Higher Configuaration HDD Into Exisisting Raid 5
In raid 5 yes you can, yet you won't use the ful hard drive, the system will take only 73GB because that's the smallest HD in your array.
Just, of course, follow the indications for your specific RAID hardware/software about how to add a new HD to it:
http://support.dell.com/support/edocs/software/svradmin/1.9/en/stormgmt/cntrls.html
Mar 20, 2009 | Dell PowerEdge 6600...
Dell dimension e510 won't turn on
Unplug the power cable from the power supply in your computer and reinsert it. If you still have nothing, most likely a dead power supply.
Jan 24, 2009 | Dell Dimension E510 PC Desktop
2nd HDD
Check Computer Management / Disk Management. Windows on Windows XP, Probably the Drive needs formatting first and partitioning before it will visible on My Computer. By Default the new Hard Drive is "Unpartitioned / Unallocated". So acess disk Management to format and partition the Hard Drive.
To access the computer management and disk management and create and partition under disk management, Check Videos for guide :
Nov 10, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Mainboard not reconizing my hdd
check to see if your ram has not losse, had the same problem with a mates computer.
Jul 03, 2008 | Dell Dimension B110 PC Desktop
Dell Dimension E510 PC Desktop Logo
65 people viewed this question
Alun Cox
