Question about Samsung CLX 3160fn All-In-One Printer
I have black vertical lines on copies from automatic feed
I have vertiical black lines on automatic feed copies
  • 3 Answers
Good luck. I've tried everything. The stupid thing jams on me 9 of 10 times so I guess the good news is I don't get a lot of black lines since it won't even print.
Posted on Jul 22, 2008
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
Black line running down the middle of the page when faxing or copying using automatic feed tray. If I lift lid and copy no line. Receiving fax not line?
Generally this problem is due to the the glass under the lid being dirty. Some combo units have 2 scanning areas, the large one you are using to copy ans a small one it runs the faxes through. I suggest you clean any and all glass you can find on the machine and give it another go.
May 04, 2011 | Brother Office Equipment & Supplies
I get black lines on the copy if I run it through the automatic feed of the copier.not when you put it directly on the glass.
lift the lid ull see a **** glass that needs to be cleaned any mark on it will be shown as a black line
Nov 05, 2010 | Ricoh AC205 All-In-One Laser Printer
Black vertical lines on copies and scans from auto
This means the read area is dirty. Clean the glass with glass or lens cleaner at the area where you place the head of the paper if you wanted to lift the cover and scan a page without the autofeeder. There may be white out or toner stuck to the glass. This can be removed with a glass blade.
This answer assumes that prints from the computer are fine...
Apr 03, 2010 | HP Officejet 6500 Wireless All-in-One...
I have an Officejet 5510 all-in-one printer/scanner/fax. When do a manual print (laying paper face down on glass), it works fine. When I use the automatic feed the copies have black lines along the entire...
You need to inspect and clean the narrow glass and the white reference bar that sits above the narrow glass. Scratches, whiteout, and debris will cause the lines on scanned documents.
Dec 24, 2009 | HP Officejet 5510 All-In-One Thermal...
The automatic line feeder dosen't work
You can have mine. It wastes line by feeding automatically way too often. Black & Decker sells Junk!
Dec 14, 2009 | Black & Decker 14" Grass Hog Xp...
When I use the automatic feed a blank line appears in t
BLANK or BLACK?, if it's Black, clean the SCANNER GLASS.
Aug 05, 2009 | HP LaserJet 4345mfp Printer
Vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Jun 01, 2009 | Brother MFC-7820N All-In-One Laser Printer
Automatic feed gives a white line in copy or scan
Although this problem would normally show as a black line on the copy, it's quite possible that there is something white (i.e. a piece of tape or paper) stuck on the scanner where the page feed passes through. Clean this area carefully with a soft cloth.
Jun 01, 2009 | HP LaserJet 4345mfp Printer
Samsung CLX 3160fn All-In-One Printer Logo
151 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
