My peavey special 130 amp has developed a strange fault - when switched on sounds like echoing thunderous roar. Can't hear guitar at all behind it. Eventually it calms down to a low buzz. Still no guitar. When you switch it off however you hear a second's worth of guitar before it dies away.
SOURCE: A HUMMING Peavey Classic 30
I have a Peavey Classc 30 with the same issues. It sounds like the Caps to me. How can I test the Caps?
Thanks
Luke
Posted on Apr 29, 2008
SOURCE: Amp powers off after switching on
the last click you hear before the amp turns on is the power relays for the amp circuit,these have 2 very small copper contacts inside them which after much time get corroded and cause high resistance when they try to power up the amplifier circuit.awkward to get to and desolder but can be opened up and serviced,done mine and a few friends with yamaha amps which use similar system,had no problem since,also worth checking for dry joints around amp chip i.c legs onto main board.
Posted on May 02, 2008
  • 142 Answers
SOURCE: peavey banit 65 guitar amp. When
A few things can cause it. Bad ground\bad power supply filter capacitor\bad low level op amp IC. You most likely have a bad power supply or trouble at your input jack. Good luck!
barneyluc
Posted on Oct 10, 2008
quang123
  • 107 Answers
SOURCE: I have a VSX-D901S Receiver
Yes it worth to repair it but you must bring into Pioneer factory or service center for Pioneer they are able to repair it
It require to replace a few electrolytics capacitors in power supply regulator if you are in AUSTRALIA it would cost between $150 to $250 to repair it
I hope that give you some idea
Cheers
Posted on Dec 03, 2008
  • 11 Answers
SOURCE: A peavey special 130 guitar amp with excessive hum
I used to have one of these years ago!
What do you mean when you say 'switch to the off position'? Do you mean it hums when switched off?
Because the sound does not fully follow volume, it is likely a bad connection or power filter capacitor is not working.
Either way, it means a trip to a repair shop. There is nothing in there you can fix unless you are a repairman. Your local music shop should be able to coordinate a repair.
If this amplifier is like the 1983 version I had, its built like a tank and the fix should be easy.
Hope this helps!
Posted on Apr 01, 2009
Testimonial: "Yeah, it was a filter cap ( electrolytic )that was at fault. I replaced it my self, and now the amp is working fine.I suspected a bad cap, thanks! "
Peavey problems
Numerous possible issues with your description. I would start with the tubes, and check if not one or more has faulted.
Jul 19, 2014 | Peavey Valveking 112 - Tube Guitar...
Peavey Valveking head strange feedback.
Sounds like one of your tubes going bad and becoming microphonic...
Google "Microphonic Tube" for additional info.
Oct 25, 2012 | Peavey Valveking Vk100 Guitar Head
Peavey Vypyr 75w
If you hear any difference in the sound while moving the pot and not scratching sounds while moving it then its not the pot...
If i understood the problem right, i have seen it in 2 ELKA guitar amps.
In their case it was the TL072 opamps in the preamp section the problem and i tracked it and it must occured due to no earth connection in the wall socket and as a result to the amp...
Mar 11, 2012 | Peavey Electronics Peavey Vypyr 75 -...
What kind of fuse does peavey pr15 passive use
Here is a site that has PR15 fuses... shown as a 2.1 amp. Very strange value, and it must strictly be for the tweeter portion as 2.1 amps is nothing for a speaker... I don't know that I believe this site.
If you have a Guitar Center near you, inquire there.
Dec 28, 2009 | Peavey Music
My amp and cable are working... but my guitar wont make sound... when i turn up the amp it makes white noise... HELP!!!
PLUG YOUR LEAD INTO AMP TURN UP JUST A LITTLE SEE IF IT BUZZES WHEN YOU TOUCH THE END OF YOUR CABLE.IF IT BUZZES THEN THE FAULT IS IN YOUR GUITAR MOST LIKELY THE ACTIVE WIRE HAS COME OFF THE INTERNAL GUITAR PLUG.
Nov 04, 2009 | Peavey Music
Hi, Peavey Classic Guitar amp , Has NO SOUND
Hi Mike,
If you switch on the amplifier, do you hear nothing at all?
Or do you hear low level noise or hum out of the speaker?
Don't know if you're technician.
If the tubes are glowing, you can measure the high voltage.
Check also fuse 3 and 4, thats the neg. voltage -27V and -14V.
regards,
Gerard
Jul 06, 2009 | Peavey Audio Players & Recorders
Circuit diagram for a Peavey 130 special
Try http://www.peavey.com/support/contactinfo/ You may be able to get one from them. When I was doing repairs they would only release schematics to Peavey dealers but you can always ask.
Jun 24, 2009 | Peavey Pv 2600 Power Amplifier
Special 130 Won't Power On
Hi....
Peavey puts many of their fuses on the main curcuit board inside the amp...I work on peaveys alot and that's what I'd check for 1st
Apr 09, 2009 | Peavey VTB1 1-Channel Amplifier
Hope this helps!
Mar 19, 2009 | Audio Players & Recorders
110 people viewed this question
 Grubhead
Grubhead
