I have a compact labtop. when i turn it on, the screen tells me that there has been a problema and it gives me four separate desitions to start up. when i choose any of them it just either starts listing things and then restarts or brings me to the start up screen but then restarts.
  • 1,314 Answers
What is the model of your computer? And what is a labtop?
Posted on Jul 07, 2008
I rebooted my labtop then i turn on my labtop and the screen goes back whats wrong
Sounds like the recovery failed.You may have to reinstall your operating system if recovery fails
Nov 19, 2011 | Computers & Internet
Dell Studio 1737 --power button is broken. Is there another way to power it on?
friends ... i discovered a way that you can power on the dell studio 1535 easily ...
first of all you know the power button .. it's now working ( or stuck )
in the other side of the labtop, there's a wifi button, when the labtop is already shutten down, you can press it and it will give a light then shuts down the light in the button, that means that it gives power, now to complete the process you should know the touch button in the left side that means Dell MediaDirect ( touch control button of the dell studio ) ..
ok, Now, do exactly what i'm telling you :)
1- when the computer is shutten down, plz press the wifi detector button one press
2- it will give a light then shuts then gives light again for a longer time.
3- when giving the first light for a short time, do not wait, press the media touch button quickly, continuesly and separetly.
it it doesn't work ... try it for many times tell you know when exactly to press the media touch button
then you'll see that the labtop starts as if it was in sleep :)
Feb 10, 2011 | Dell Studio 1737 Laptop
I need a boot disk to reboot my labtop but i dont have one because it did not come with the labtop
in that case there must be a recovery partition on the disk - the first screen that appears when you turn the laptop on will tell you what key to press to access it - then just select to recover your laptop and follow the procedure.
Jan 15, 2011 | Toshiba Satellite C655-S5085 Notebook
Tengo problemas con el aire acondicionado esta tirando aire muy caliente aunque este en aire acondicionado.
Ok tienes que revisar si el compresor trabaja cuando activas el interruptor del aire si el compresor no se activa podria ser que le falte freon 134a al sitema,que tengas algun problema electrico.puedes comprobar el nivel de freon con un manometro si este esta bien tienes que revisar la parte electrica. Gracias
May 03, 2010 | 2002 Kia Sedona
Screen divided into 2 mirrored sections.
This sounds like a hard drive failure. You can press f8 to enter safe mode with networking during post. If it boots to windows,then go online & download the video driver from nvidia,install it & reboot. If that doesn't work,try re-formatting. If it won't do that then try a new hard drive. I have the software needed to test the hard drive,but it's for commercial use only. This is the back yard method.
Jul 15, 2009 | HP Pavilion dv9000z Notebook
When i turn on my laptop it turns on but the screen is just black/plain!=( idk i didnt do anything i hooked it up trying to use my home computer screen and it still was blank! help me
give ram and the pc usage a rest then when you open it it will be blank again so while it is open take of the bettery and put it againand turn on the labtop and you will see options like start the pc in safe mode with command propt. or start in safe mode with net working.and the last one is start in safe mode.When you look down you will see start windows normally.PRESS ON IT!.and the laptop should start again
Jul 03, 2009 | Compaq Presario R3000 Notebook
Lock out of my computer through eztune-
Call Gateway @1-800-gateway. They will tell you to unplug the monitor, plug it back in while holding the power button. A screen will apear giving you a code number. The gateway rep. asks for the code number and then gives you a code number to unlock your screen.
Oct 25, 2008 | Gateway FPD1975 19" LCD Monitor
usually does this when it has failed to shut down properly, you should get an option to start windows normally or try repair.
Sep 14, 2008 | Acer Aspire 5315 Notebook
Starting up
Has the hard drive been replaced yet? Computer hard drives have a 4 year average life. the last g3 shipped in 2002.................The G3 ibook was also infamous for bad logicboards or separated GPUs. Check
! for research only- I take no responsibilty if you turn your failing ibook into a brick or set your block on fire, but I know this technique very well!
Jul 30, 2008 | Apple iBook G3 Mac Notebook
Computers & Internet Logo
David Payne
David Payne
