Question about Sony Computers & Internet
I have a Sony Bravia Model KDL 37M3000, and I am having problems, because when I turn on the TV in about 1 hour later the TV automatically turn off itself and after that I tried to turning on again but is impossible, I have to unplug the TV and wait about 2 hours to have the TV working again, but with the same problem. Months ago I have the same problem but the TV did not turned off automatically. What I have to do, I hired a technician he told me probably and according to the codes is the main board, but he is not sure, do you know which is the serial number of this part to check the price or may be you may give another solution. Thanks, Oscar Renderos.
  • 18 Answers
SOURCE: Please wait
try to clean loading sensors
Posted on Jun 03, 2007
Chadha Saab
  • 142 Answers
SOURCE: asus a8v deluxe mobo no start
This is a NO POST scenario
How to troubleshoot No POST
1. Check wall socket whether power is working fine
2. Check PSU (Power Supply Unit) fan whether it is rotating or not.
3. Change power socket.
4. Change the the main power cable from the wall socket to the PSU.
5. Check whether the lights on the keyboard flash when you turn on the power.
6. Check the voltage selector swicth at the back of the PSU ( Ideally should be 115v for US region and 220v for Asia ).
7. Check all peripherals like keyboard, mouse, video cable whether they are connected properly or not.
8. Open Chassis >> Check RAM connected properly.
9. Remove add-on cards like graphic cards, modem card, PCMCIA card slots, LAN card etc.
10. Take out main power connector (grey-black) or brown, green cable from front board panel of cabinet from where you turn on the power for CPU. and also take it out from the motherboard,
11. Check I/O cable which comes from power button on cabinet whether it is firmly connected nor not.
12. Plugg all the cables back in.
If still u face the same problem Then
13. Take out CMOS battery from motherboard and press power on/off button for 30 seconds and plugg CMOS battery back in to the motherboard.
ram chips swapped out with a known working chip of the same type
HDD swapped over with the HDD out of my portable external backup HDD
FLASHING A BIOS:
A couple of items are really important if you decide to flash. First. Make sure the updated bios addresses the issue you are trying to solve. eg many motherboard makers update their bios's for many different reasons. A reason may simply be to get a certain big name brand of pc to work correctly with a new cd writer big brand pc is selling.
So you really have to read the docs so see if the upgrade addresses your specific niggle or concern. Secondly, try your motherboard maker first to see if they have the files you need. Bios's upgrades are best had, if available, from the company that made your motherboard or pc. In most cases these are free.
Thirdly, READ THE DOCS CAREFULLY AND FOLLOW THEM TO THE LETTER. Dont skip any steps, especially the backup option if available. Fourth, if the upgrade calls for a clean bootdisk, use one. The disk I made especially for bios flashing is the one you can download above. It's a DrDOS bootdisk with NO drivers loading up in config.sys or autoexec.bat which is very important. My bios flash bootdisk is recommended by the most popular motherboad makers.
If you dont have a 1.44 drive I also created a utility to use to flash from a CD which you can add the new bios and flash utility to and then burn it.
It should have room to add your new bios, the flash utility, and also have room for the backup. If not one can always use another disk for the info. Always use BRAND NEW MEDIA when dealing with flashes.
In order to locate the correct bios upgrade for your motherboard you need to know who made it AND you need to know the model number. If your PC was made locally perhaps you have the manual. If not, then you need to find out the maker and model. Or, and very common with major brands, your computer maker will/may have the updated bios's on their website.
I have one windows and three dos utils that find your motherboard maker and model number. One of them should work for you. The DOS utils are on my DOStools Page under Diagnostics, and are called CTbios, MBID, and HW iNFO. The windows utility is called BIOS Agent and is on my Utilities Page under Hardware .
Once you ID your motherboard and model go the the manufacturers website and see what they have available. Note that some upgrades will come with their own bootdisk/utility so you may not need the disk I made.
Again, note that even tho many people flash their bios regularly to get the latest features and never have a problem, I still recommend it as a last resort as a flash gone bad will make your pc unusable if the backup doesn't work. Look at it this way, suppose I have a used 80 gig drive I want to resuse and my old P400 cant even detect it so I have an unusable pc. This is the best, and most common reason to flash.
On the other hand, if you have a more modern pc that cant see lets say a 180 gig drive and but all else is working properly then you may want to consider a PCI hard drive controller card which has an onboard bios that will see your new large hard drive and also come with 2 more IDE channels you can use in addition to the 2 channels you already have. This is safer than flashing the bios.
Posted on Jun 08, 2008
mdsaeed67
  • 849 Answers
SOURCE: asus p5p800 motherboard
seem power supply fault, because some times, it looks that power going on, it is not giving proper voltage to motherboard. check other power supply.
Posted on Nov 21, 2008
  • 17 Answers
SOURCE: Gigabyte GA-K8N Pro-SLI won't boot and no beep codes
hi kathy,
there are a few things you can try, reseting the cmos, with the jumper usually located near the battery. if you cant find that, try removing the battery for 30 mins and then popping it back in. if no luck from there, you could try another cpu, if that dont work then it may just be the mobo! good luck!
hope it helps!
Posted on Feb 11, 2009
prawinmv22
  • 106 Answers
SOURCE: light flashing 13 times on sony bravia KDL-46x3100
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
Posted on Jun 16, 2009
I have Sony bravia KDL 32 lcd tv, If I turn off the tv by remote after running it about one hour ,the tv will not turn on again by remote or side switch on the tv, I have to completely remove the plug from...
It is a failure of the power board voltage converter. Replace the power board and the issue will be resolved. It is not a difficult process if you are a DIY type pesonality I would go for it. Call sony for the power board, need model size and where it was constructed , Canada, Mexico or the US.
Good Luck Ed Pinero
Feb 02, 2013 | Sony 32 Bravia Lcd Kdl-32ll150 Hdtv
Sony bravia model kdl-46z4100 has no sound. picture is ok.
Tries tv unplug,replug it back about an hour later for the tv for a resetting back to the factory setting.Go into the tv menu go to Audio Setting go down to do a resetting back to factory setting.These steps will help the tv to get the tv audio back.
Jun 11, 2011 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
I have a Sony Bravia 45" Flat Screen, it turns on but there is no sound.
Tries tv and cable or satalite boxes unplug,replug it back like about an hour later.Than tries goes into the tv Menu go into Audio Setting and do a resetting back to the factory setting.Follow these steps,should help ur tv sound to come back.
May 30, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a 52" sony bravia MODEL# KDL-52V4100. it comes on but every 3 minutes it shuts off and restarts. have gone through all the timers and settings but still does it. i dont have the remote that came...
Try website like Remotes.com to buy an exact remote to the original remote.Tries tv unplug,replug tv an hour later,the tv will reset itself back to the factory setting,could solved ur problems.
Oct 11, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony bravia kdl-46z4100 is 18 months old. TV speakers quit working. can they be replaced easily, or does a repairman have to be called.
Try the tv unplug,replug it back an hour later.The tv now,resetting back to factory setting.Go to tv Menu.Goto AUDIO setting,go down to reset,the Tuner board is now resetting.The tv should have sound now.Not than,the Tuner board have problems.Not the speakers,yes call the repairman.It'll cost half the price of a new tv.
Sep 07, 2010 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
When turning on TV, sound is often absent.
Unplug,replug the tv about an hour later,let the tv reset itself.Tries goto tv menu,go to AUDIO,go down to reset the audio setting,back to factory setting.Goto menu to PICTURE,go down to reset,to resetting the Tuner board back to factory setting.The sound,should be there,now all the time.Not,than the Tuner board have problems.That the board,where the broscasting signal cable plug into it.That the Tuner board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 23, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Digital tv sony kdl-32l4000 lower audio sound. Has got worst yesterday. Have turn the audio up louder to hear it well. what could be the problem?
Unplug,replug about an hour later let the tv reset it self.Go to ur tv menu.Go to AUDIO go down to reset.The audio should reset back to factory setting.Ur sound should return to normal.
May 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have a sony bravia kdl 37m3000. We have cable and the wide screen would not go away so we unplugged the cable to reset the tv. Now the cable and the tv comes on but no picture.
Make sure you change the input that the cable is coming in on, If you was watching in HD mode then you was using an HDMI or compontet hook up.Look on tv remote for Video input button to select the componet input 1 or 2 or HDMI inputs which it is connected to. Look for a button on the remote called TV/VIDEO or INPUT
Dec 15, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Sony Bravia KDL-37M3000, bought June 08. The
Get a digital antena,If u using the signal over the air,rescan.If the signal is cable or other pay tv signal.Ur digital turner,it damage.
Jul 09, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
6 flashing lights
Similar problem with my Sony. I unplugged for 36 hours and it seemed to solve the problem.
Dec 28, 2008 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Computers & Internet Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
