Question about Philips PET702 Portable DVD Player
PET702/37 Connection to PAL TV
My wife has the Phillips PET702/37 in Italy. She is trying to hook the dvd player to the PAL TV there. All she is getting is chatter on the screen. Is there a PAL setting on the unit to play to PAL TVs? I am looking for an electronic document of the device but I cannot find one. Any help would be appreciated.
    Problem Solver:
  • 7 Answers
This link : http://www.consumer.philips.com/consumer/en/in/consumer/cc/_onlineStoreStatus_false/_productid_PET702_98_IN_CONSUMER/_retailStoreStatus_false/Portable-DVD-Player+PET702-98
features both a leaflet and manual for this model in pdf format.
Posted on Sep 26, 2008
Can you hook up a blu-ray player to a Samsung TX-R2765 TV? I don't see an HDMI plug.
HDMI to AV Converter Composite 1080p HDMI to 3 RCA Audio Video AV CVBS Adapter HDMI 2 AV Converter Supports PAL/NTSC for HDTV DVD Amazon com HDMI to AV Converter Composite 1080p HDMI to 3 RCA Audio Video...
Nov 19, 2017 | Televison & Video
IWhat's your problem? I have a Hisense LTDN42V68US LCD TV and I am trying to hook it up to a Phillips HDMI DVD Home theater surround system HT53544 my problem is I am not getting a sound I only get so
Good day!!!
Your problem is on your digital cable signal or connection..
Please check all the wirings and connection from the to cable box..
its better if you re insert all connectors and restart all TV,cable box....
Hope it helps...
Dec 06, 2011 | Televison & Video
How to make PAL region code 2 dvd's work on a regular tv
The tv in U.S. and Canada can't set in the play pal mode.Only in NTSC mode.
Aug 13, 2009 | GPX D1816 DVD Player
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
Hooking dvd player up to tv
Sounds to me as if you have not set the Playback CODEC properly.. In the Menu system, as in NTSC or PAL. Make sure that the DVD & Player are set the same Format ie: NTSC or PAL..
Nov 30, 2008 | Emerson EWF2004 20" TV
Phillips dvd player
i need to figure out how to burn a dvd with my phillips hdmi recorder.
Sep 13, 2008 | Televison & Video
Nextech N600 DVD player problem
You may have connected one of the component outputs (usually colored red, green, and blue) of your DVD player to the composite input of your TV. Connect yellow to yellow. See section 3.2 for hookup details. Also, if you've hooked up component video, check the three cables to make sure one of them hasn't become disconnected or developed a short and that they are connected in the correct order. If you use an s-video connection, the chroma wire maybe broken -- try a different cable or try the composite connection.
If you live in a PAL country (most countries outside of the U.S., Canada, and Japan) you may be playing an NTSC disc in a PAL player, but your PAL TV can't handle the signal. If your player has a switch or on-screen setting to select the output format for NTSC discs, choosing PAL (60 Hz) should solve the problem. See section 1.19 for more information.
May 03, 2008 | NexxTech N600D DVD Player
PAL problem
Hi!
The DVD player you have is only compatible with NTSC TV. There is no way of changing that to PAL.
It is compatible though with PAL discs. It will convert the video signal of a PAL disc to NTSC format.
Dec 21, 2007 | Philips DVP3140
Help
Go to menu and sub menu video .Under video option you will see video formatt,e.g Pal,NTSC.You confrim your tv standered if its pal or NTSC (this you can check at back of your tv set ,not always mention but most of them are printed)On your dvd player
you have to select same formatt as your tv .If not sure of you tv system try auto system on you player.
NB dont select progressive scan by mistake otherwise you will not see any picture on your tv if its not progressive scan tv.
If you could mention tv and dvd model and brand will be able to advise you exactly.
Dec 13, 2007 | Televison & Video
Philips PET702 Portable DVD Player Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
