Question about Ariston Technologies Dishwashers
Dishwasher Model LSV66 - door will not open - Ariston Technologies Dishwashers
  • rggoodall Jan 02, 2011
    Thank you for this help. The wire hanger was not strong enough to prise the catch off, but the screwdriver trick did confirm that the problem was the catch.
    However, what we ended up using was the 'z' tool used for laying tongue and groove flooring, and with some help with the screwdriver, we got the short end in place, and with one hefty belt from a good sized hammer, the catch finally released.
    I think when we tried with the coathanger, instead of doing too much pulling at the door, it may have helped if we'd pushed it a little, to take some strain off the catch while trying to disengage it.
    Again, many thanks for the suggestion, guess next stop is online sales for dishwashers - apparently wife has always thought door was not good - either to close or to open - but we've had a good 10 years from it.
    Rob
There is probably something broken with the latch mechanism as it is mostly made of plastic.
Safety first, ensure mains is off to dishwasher!
Your best chance of opening - Method one - first you need to understand how the latch works. In LSV66, the latch is right at the top, centre above the door handle and the ariston logo; you cant see any of these unless you have it opened - so try to imagine the mechanism as I describe; the door side is a tongue while on the dishwasher side it is a D-shape loop - at locked position, the tongue is inserted into the loop from below. So to pick it, use a coat hanger wire, bend it into L-shape. The problem is you need to slide this between the door and presumedly your worktop and slide it to the middle, learn where the latch is initially - the hard part is you need to slide the L-shape tip as close as possible the the door side, the tip should come in from sideway sp that you are trying to slide the tip arm of the L-shape underneath the d-loop and to unhook it is to flick the d-loop with upward turn and NOT downward since it loops over the tongue from top. Method two - assume you are confused about method one or simply cant slide the L-shape between the tongue and d-loop, the next best way is to pry the latch open, here you run a small risk of breaking the d-loop but you can easily buy a replacement spare - to pry open the door, use a sturdy tool if you dont have a suitable size crow bar - a robust screwdriver could do. You need to pry it close to the latch to get good fulcrum power, so approach middle above the logo between door and worktop - you are likely to scratch the top edge of the door but again this part is concealable when the door is shut so wont be too cosmetically bad.
Once opened, unscrew the top panel from inner door, you will find the latch mechanism which I assume something is broken - replace this by buying a spare - usually cost around £20.
Good luck.
Posted on Jan 01, 2011
Dishwasher door will not close dishwasher come on with door open.
Good Morning Garthraie, thanks for your post!
I see that the door on your Frigidaire dishwasher appears to be locked and will not close. Could you please advise if the control panel has any lights lit up on it? Also, may I have the model number of your dishwasher? You can locate the serial tag (which lists your model number) on the inside left hand wall of your dishwasher. With this additional information I would be able to assist you further. -Matt
Apr 12, 2016 | Frigidaire Dishwashers
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I have an LSv66 Ariston dishwasher. When it is switched on, no matter what program, the knob just stays in the same position. It sounds as if the dump pump is running constantly.
The dishwasher overflow detection may have triggered. This causes the drain pump to operate.
The overflow float is located at the base of the diswasher and maybe faulty. It is spring loaded float and should move down and up when pressed. If you cannot find this in your model, then water has leaked into the overflow cavity where the motors are located. This could also trigger the overflow protection circuit.
You have to replace the overflow float if it exists or empty the overflow water in the overflow cavity and dry it out. If leak is taking place then the gasket needs replacement.
Hope you are able to fix the problem with some of the suggestions I have made.
Please rate the solution if you find it helpful otherwise post a comment.
Oct 11, 2010 | Ariston Technologies LL64WNA Built-in...
The detergent door doesn't open
Please reply your exact model number so we can see what the door looks like.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher detergent door won't release soap
There's an answer at: http://www.partselect.com/dishwasher+cup-wont-open+repair.htm.
Pretty in depth, but not a simple fix.
May 22, 2008 | Maytag PDB3600A Built-in Dishwasher
Dishwashers Logo
221 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
