Question about Pioneer ACARD 1-TO-3 TARGETS 16X DVD+-/RW/CD STANDALONE DUPLICATOR WITH LCD DISPLAY-NO HDD BUNDLE (NEWITEM14720531) Burner
Im haveing problems with my towere burner and need help can you help me? keeps saying "source drive not ready" im downloading movies and trying to burn them and was successful on many of occassinos now it is acting up. Is there a solution for this?
    Sergeant:
  • 320 Answers
Hi RBig,
    • Download and install CCleaner (free) from Piriform
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If this does not resolve your problem, try the following.
If you take all these step and you still can not burn a DVD, chances are your DVD burner componet needs to be replaced. Good Luck.
  • If this helps resolve your issue, would you please rate the solution
Posted on Dec 30, 2010
When I try to play a movie with my samsung se so84d drive, my mac says "a valid dvd drive was not found." How can I play the movie????
Good day..!!Maybe your using cd disk that why ur external wont accept it.,or maybe there was a error on your cd.thanks
Aug 17, 2011 | Samsung External Slim DVD-W USB Compatible...
Tip
How to copy DVD Movie on Mac OS X?
This step-by-step guide is dedicating to demonstrate how to backup DVD movie (copyright protected included) to computer and copy DVD to a new DVD disc with no protections on Mac OS X (leopard included)
The tool you need is Aimersoft DVD Copy for Mac, which you can download for free from here.
It’s very easy to use, just with three simple steps then you can easily copy DVD on Mac.
Step1. Select DVD Source
After you install and lunch Aimersoft DVD Copy for Mac, put the DVD disc into your DVD drive. Click the “Select Source” drop-down list to browse your computer and located your source DVD movie (either in a folder or from your DVD-ROM).
Step2: Select DVD Copy Method
Aimersoft DVD Copy for Mac allows you to back up DVD to a folder on your hard drive or directly copy DVD to a new DVD disc. In the “Select DVD Copy Method” field, select a method to output the selected DVD movie according to your need:
If you want to back up your DVD movie to a folder on your hard disc, you can select the “Output DVD Folder” option, and specify a directory to save the copied DVD movie.
If you want to directly copy your DVD movie to a new DVD disc, you can just select the DVD Burner where you have inserted a blank DVD disc.
Note: If you are copying a DVD disc from your DVD Burner to a new DVD disc, Aimersoft DVD Copy for Mac will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
But if you have two or multiple DVD Burner, you just need to change object DVD to another DVD burner and insert a blank disc into it , then Aimersoft DVD Copy for Mac will automatically copy DVD movie to the new DVD disc. No need to wait for the conversion to insert a new blank DVD disc.
Step3: Program Settings (optional)
Set Buffer Directory: Specify a directory on your hard drive as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard drive that has relatively big free space.
Select Language: Select an interface language for the program. The currently available languages are English and Simplified Chinese.
Step4: Start Copying DVD
After all things done, click the Start button to start copying your DVD movie or burning it to a new DVD disc. That’s all.
on Feb 10, 2010 | Computers & Internet
Acard duplicator - 'Source drive not ready'
When you push the button to open/close the drawer, does it work,
i.e., is there electrical power reaching the drive?
Did you put a disk into the "source" drive?
Is the same disk recognized when you put that disk into any other computer?
If so, then the "source" drive is damaged, and needs to be repaired/replaced.
Jul 18, 2011 | Acard Technology 15 CD DVD Duplicator...
Just purchased a liteon dvd burner.When I try to burn copy of dvd movie; the message I get states that the movie is copyguarded. My old dvd burner has no problem copying copyguarded movies using...
you might need a program like AnyDvd which removes copywright from a dvd and allows you to burn it without any restrictions to be able to play the dvd in australia
hope this helps
Dec 13, 2010 | Lite On LITEON 16X DVD BLACK OEM (Come...
DVD will not duplicate in copier
Remark: This DVD duplicator do not copy protected DVD of movie, music and games.
try with nero to perfom the others.
Feb 15, 2010 | Computers & Internet
Trying to burn dvd. It keeps saying Target drive not ready
Hi, assuming the rest of the drives are working there are three probable issues.
1. The cabling for power or data is loose or faulty, check the cabling, remove and reseat it, then try again with new data cable and swap power connectors with one of the other drives. If the results do not vary it's not the cables, If the problem moves with the data cable but is not resolved by replacing the cable it is the logic board at fault.
2. Try cleaning the drive, do not use brush cleaners as they can damage the head, just used a compressed gas can or air compressor on less than 20lbs/in, if this does not work...
3. The second drive may be faulty, check with the manufacturer/manual. Many of these devices require a specific model or one of only a few models for compatibility, replac with an appropriate model.
Hope this helps FixYa,
Chris
Jul 17, 2009 | Telex SpinWise 7-824D (301689000)...
Burning downloaded movies
Dear download Nero 9 from the web
it will solve ur all burning prob.
Oct 23, 2008 | Dell Inspiron B130 Notebook
Sony dvd rw dw-g120a
I cannot burn my home movies to my dvd drive, my dvd drive is called SONY DVD RW-G120A, it says this device is disabled Code 22, Please help me fix this problems. Thank you
Oct 15, 2008 | Sony DW-G120A DVD RW Dual Layer Burner
Accutower duplicator
accutower won't burn cd it says "no clear cd'
Apr 08, 2008 | Tower ACCUTOWER CD "Music" 5 Writer...
DUPLICATOR
Hi there check the source drive by placing a cd in the draw close n draw wait 2 seconds open and see if the cd has rotated. If not then the drive is faulty. If so you may still have a faulty source drive check by placing audio cd in there if sound great if not Faulty.
Thanks J
Jan 26, 2008 | ASUS 52X CD Duplicator - Black 1-1...
Pioneer ACARD 1-TO-3 TARGETS 16X DVD+-/RW/CD STANDALONE DUPLICATOR WITH LCD DISPLAY-NO HDD BUNDLE (NEWITEM14720531) Burner Logo
148 people viewed this question
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
