Question about Electrolux CHANTAL Loop Tea Kettle - Brushed Stainless Steel Electric Kettle
The whistle fell off my chantal teapot and when reattached it will not whistle. How can I fix it?
2 Suggested Answers
  • 66 Answers
SOURCE: Will not whistle
It is possible the reed valve broke.
Posted on Aug 02, 2009
Where can I buy another screw for my Chantal teapot whistle?
You can try and source one from the manufacturer or maybe easier to simply try a local hardware store and try to locate the correct one.
Jan 05, 2015 | Chantal Classic Teakettle, 1.8-Qt. -...
My son was playing with the speaker cube and the push button, internal springs, and clips fell out. He tried to fix it himself and pushed the button back into position. I need to get the button out a
Have your son "play" with it again, or at least have him show you what he was doing when it "fell" out, he may have stumbled on the technique, but chances are a tab has broken off meaning it should be easier to remove now. Good Luck!
Nov 22, 2014 | Bose Acoustimass 5 Series III Speaker...
Le Crueset 1.8-Qt. Enamel on steel whistling teakettle u-shaped metal piece fell out
There are two parts to the whistle - the hinged whistle bit and the black base that is attached to the spout. They are joined by a pin that passes through the base and through a bracket that is fixed above the spout, and through the bottom of the arm on the hinged whistle. Remove the pin - it is a push fit - so you need a rod of the same diameter. It will then all come to pieces. The U shaped metal spring sits in the bracket on the spout - the open end and the slope on the spring to the top. Then put the bits back together and replace the pin! This is tricky but do-able as all the holes have to line up. You need to have plenty of light to see what is going on. Once aligned the pin goes back in okay but don't try to force it. If it doesn't go in your alignment isn't right.
Mar 22, 2013 | Le Creuset 1.8-qt. Enamel on Steel...
Hi, my husband bought me your KAMENSTEIN WORLD OF MOTION SERIES ANIMATED HORSE CAROUSEL many years ago. I did not keep the box or manual and now I want to ask can you e-Mail me a download or one I can...
I cannot loacte an actual manual but....The Kamenstein Carousel teapot was part of the MKI versions of teapots Kamenstein released in the mid-2000s. The teapots came in a range of colors, from blue to red, and they had a small carousel on the top. As the water boils the carousel spins around, bringing an element of whimsy to your tea time. The teapots are all metal and can be used on any type of stove top.
Instructions
    • 1 Fill the Kamenstein Carousel teapot with water just below the sprout.
    • 2 Place the Kamenstein Carousel teapot on the stove and set the heat to "Medium."
    • 3 Allow the water to come to a boil and remove the Kamenstein Carousel teapot from the stove.
    • 4 Pour the hot water into a cup over a tea bag.
Read more: How to Use a Kamenstein Carousel Teapot ' eHow.com http://www.ehow.com/how_7718254_use-kamenstein-carousel-teapot.html#ixzz1JAQxUJn2
Thanks
Apr 10, 2011 | Vacuums
I have a brand new Euro Pro Toaster Oven, Model # TO176. After a week of use a pin or similar piece fell out of the door hinge, and the door keeps falling out on the right side. The left side is still in...
My mother had/has the exact problem right down to the teapot. I am in the process of fixing it, but don't have time to post solution right now. I will post later today. I should probably post a video as it is not real simple.
Oct 26, 2010 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
Big chip in glass top burner
If you are looking to fix instead of replace (the better option) you will need to find a ceramic adhesive to put the parts back in place. You arn't going to find it at a hardware store. Try this link. It sells for about $20 bucks.
http://www.waleapparatus.com/catalog.asp?prodid=548630&showprevnext=1
Jan 04, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Will not whistle
Aug 02, 2009 | Electrolux CHANTAL Loop Tea Kettle -...
Window and parts fell into inside of door. How
I assume you have the panel off. Is the question how to get them out of the door so you can reattach them or is the question how do you reattach them?
You can reattach them with pop rivets and a pop rivet gun. Screws might work, but sometimes screws protrude too far in and get in the way of moving parts.
May 04, 2009 | 1992 Ford F150 SuperCab
Melted plastic (teapot whistle) on glass cooktop
Hello. I don't know if this will work but you could try getting it as cold as you can and maybe it will come off that way. If it were me I would use my refrigerant, but I am sure you don't have that. Who knows maybe ice will work. Now that I think about it, maybe you can carefully use some sand paper being sure you don't scratch the surface.
Nov 28, 2008 | Jenn-Air JED8430 Electric Cooktop
Electrolux CHANTAL Loop Tea Kettle - Brushed Stainless Steel Electric Kettle Logo
160 people viewed this question
Top Electrolux Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Electrolux Kitchen Appliances - Other Expert? Answer questions, earn points and help others
