Question about Stairmaster 4600CL Stepper Blue Console Nautilus 4600 CL
When i step down, the left side works perfectly, but the right side has no resistance at all
  • 30 Answers
Check the recoil spring for that pedal
Posted on Feb 03, 2011
The running bords on my 2008 Yukon stop working
Circuit/System Description
The assist step control module (ASC) controls the running board actuators to extend or retract the running boards. Each actuator consists of an electric motor and a potentiometer. The module supplies a low reference and 10-volt reference source voltage to the potentiometer. The ASC control module monitors the voltage drop across the potentiometer on the position signal circuit. When the actuator shaft rotates, the voltage on the position signal circuit changes. The ASC control module supplies the actuator motor with a 12-volt control circuit and a ground control circuit. The ASC module controls the direction of the actuator by changing the polarity of the control circuits.
You should take this to a ASE certified repair shop that has the diagnostic tools to check for stored DTC'S in the running board control module . A code reader for check engine light codes will not work for this system !
This system can set numerous DTC'S
Diagnostic Procedure Instructions provides an overview of each diagnostic category.
DTC Descriptors
DTC B051A 0B: Left Side Assist Step Motor Control Circuit Current Above Threshold
DTC B051A 01: Left Side Assist Step Motor Control Circuit Short to Battery
DTC B051A 02: Left Side Assist Step Motor Control Circuit Short to Ground
DTC B051A 04: Left Side Assist Step Motor Control Circuit Open Circuit
DTC B051B 0B: Right Side Assist Step Motor Control Circuit Current Above Threshold
DTC B051B 01: Right Side Assist Step Motor Control Circuit Short to Battery
DTC B051B 02: Right Side Assist Step Motor Control Circuit Short to Ground
DTC B051B 04: Right Side Assist Step Motor Control Circuit Open Circuit
DTC B051C 01: 10 V Reference Circuit Short to Battery
DTC B051C 02: 10 V Reference Circuit Short to Ground
DTC B051C 2A: Left Side Assist Step Position Sensor Circuit Too Many Pulses
DTC B051C 22: Left Side Assist Step Position Sensor Circuit Low Time < Minimum
DTC B051C 29: Left Side Assist Step Position Sensor Circuit Too Few Pulses
DTC B051C 62: Left Side Assist Step Position Sensor Circuit Actuator Stuck Open
DTC B051C 63: Left Side Assist Step Position Sensor Circuit Actuator Stuck Closed
DTC B051D 2A: Right Side Assist Step Position Sensor Circuit Too Many Pulses
DTC B051D 22: Right Side Assist Step Position Sensor Circuit Low Time < Minimum
DTC B051D 29: Right Side Assist Step Position Sensor Circuit Too Few Pulses
DTC B051D 62: Right Side Assist Step Position Sensor Circuit Actuator Stuck Open
DTC B051D 63: Right Side Assist Step Position Sensor Circuit Actuator Stuck Closed
If you don't know how the system works you could make it worst !
You
Aug 16, 2015 | Cars & Trucks
Left side does not work well
Even though the cable may be in perfect condition, there may be a bad connection
Jan 10, 2013 | Philips Tapster BluetoothStereoheadset...
ProForm 675 elliptical is very hard to peddle
use the next steps:
Step 1
Use your flathead screwdriver to pry off the plate on the left side of the elliptical trainer.
Step 2
Look for the magnet and reed switch. These elements will be roughly the same size, and the reed switch should have a series of wires connected to it.
Step 3
Loosen the screw in the reed switch using your screwdriver. Move the reed switch by hand until it sits 1/8 inch from the magnet, then re-tighten the screw.
Step 4
Test the unit to see if the display and heart rate monitor are working properly. If not, move the reed switch slightly so it is closer or farther from the magnet, then try the machine again. Once you've found the correct location for the switch, tighten the screw to hold the reed switch in place.
Step 5
Replace the cover plate by snapping it into position by hand
8_1_2012_1_02_58_pm.gifGod bless you
Jul 31, 2012 | Exercise & Fitness
Split screen, right side perfect left side garbage
Just visit this site for details. I can't type in all the details by this window. The site name is "Electro-help". Search for it in internet. It is an electronic equipments' repair help site in English language. All about faults to DLP TVs, and its recitciations are described here in detail.
Jun 20, 2012 | Samsung DLP HL-P5663W 56" TV
I need to know the torque settings on the head for a 94 jeep grand cherokee laredo
Assuming the motor is an inline six
1.Middle bolt is number 1.Clockwise torque to 22 f/lb
2.Same pattern to 45 f/lb
3. same pattern to 100 f/lb
Be sure to use loctite 592 to the threads and some head gasket sealer to both sides of the head gasket.
Hope this helps
Oct 18, 2009 | 1994 Jeep Grand Cherokee
The left side sound is intermittent
Sounds like dirt in the volume control or a high resistance speaker wire.
Try switching the right and left speaker wires and see if the problem changes.
Aug 03, 2009 | Audio Players & Recorders
No output from right side speaker jack
audio board located inside the mainboard console to the right trace your speakers wire to bd, disconnect the three leads, 3 phillips screws, and examine bd for burns. If yes, ebay the board id for a replacement.
Apr 24, 2009 | Dell W4201C 42 in. Plasma HDTV
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Feb 25, 2009 | HP LaserJet 2840 Printer
Only the left half works
You could try removing the ribbon cable directly under where the lines are from the X module and clean the cable and reinsert it. You could have a bad X Module if cleaning doesn't fix it.
Let me know if this helps.
Jul 29, 2008 | LG 32LX1D 32 in. LCD Television
Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Mar 13, 2007 | Logitech Z-2300 Computer Speakers
Stairmaster 4600CL Stepper Blue Console Nautilus 4600 CL Logo
90 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
