Motorola dct2524/1631/al how do i reset this device all it says on the receiver screen is hunt and the tv is black please help
2 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: The green light is lit on the TV but the screen is black
Could be a bad powersupply in the TV since you did unplug it and try to start it up it maybe you got a bad power unit inside these can be replaced for under $150. If you Tv is under warranty I would suggest you bring it in for a repair. Thanks for using Fixya.com please hit the ACCEPT button and give a good review thanks.
Posted on Aug 18, 2009
I locked G from a remote device or device manager can't moto G has a black screen when power on how do i unlock the device from device manager
Hi Travis,
With the device manager (Android Device Manage or Motorola Device Manager) you will be able to block the device and reset the password, however you will not be able to unlock the device from there.
For the Black screen problems, I would like to advice you to trust the hands of our Technicians and contact our Support line: 1-800-734-5870 on this hours: Mon-Fri 7AM-10PM; Sat-Sun 9AM-6PM CST
Regards,
Gaby
Motorola support.
Jul 29, 2014 | Motorola MOTO G XT1033 8GB Unlocked GSM...
We have an Electro Brand Inc. DVD Home Theater System, model # STS2891-1. We cannot see ANYTHING on the HDTV screen that would allow us to access the SETUP menu. Please help!!!!!! We have tried...
First, does your TV have HDMI connections? If so, you need to connect your home theater to one of those (it doesn't matter which one, although I would choose HDMI1 (you will, of course, need an HDMI cable for this). You will see nothing on your TV screen until you make that connection. Once you do, using the Electro remote, you should be able to access the "set up" menu.
Jul 15, 2011 | Audio Players & Recorders
I received an error 4 code on my comcast supplied motorola dch3416 hd dvr, looking up this error on the web it was suggested that i reset the device, but did not specify how. can you help?
Hi chestmcn. Here's how you reset your device to its defaults:
1. Make sure your receiver is plugged in, that it's connected to your TV, and that your TV is turned on.
2. Turn your receiver OFF, then press MENU on the front panel of the box. You will then see a menu on your TV.
3. Using either the up/down buttons on your remote control or the up/down buttons on the front of your receiver to navigate. Use the right arrow button to view the options for each setting.
4. Arrow down to the setting labeled "Restore All Defaults", then press the right arrow button to select that option.
5. Exit the menu and save your changes by pressing the POWER or MENU button.
For what it's worth, this issue may also be related to Comcast reference code error s0900, which means a disruption in service, usually temporary.
In case you run into more trouble with your receiver, here is a link to the user guide- http://www.motorola.com/staticfiles/Business/Products/TV%20Video%20Distribution/Set-tops/QAM%20Set-tops/All%20Digital%20QAM%20Set-tops/DCH3416/_Documents/Static%20Files/DCH3416_User_Guide_537529-001-c.pdf
I hope this helps. Thanks for using FixYa!
Mar 24, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
Aug 18, 2009 | LG 32LB9D TV
HDMI connection not working
I have a DCT6416 which is essentially the same unit but with a bigger hardrive. I just had the same problem and was able to fix it.
First connect your DVR to your TV with the composite RGB cables and disconnect the HDMI. Then power your unit on. Then power it off (using the power on the DVR not a remote) and immediatly press the menu button on the DVR (not the remote). A white screen with black writing will come up. Using the down arrow buttons on your DVR go to the bottom line where it says "reset factory default" Toggle down to that and then use the right arrow key and your settings will be reset. Then exit out of that by powering off. Now remove your composite cables and replace the HDMI. You should be back up and running.
Feb 06, 2009 | Arris DCT6200 DTV Receiver
Motorola DVR
Try unplugging the unit for at least one minute and then plug it back in . The unit should reset itself . I will take 20-30 minutes for the guide to repopulate.
Nov 29, 2008 | Arris DCT6200 DTV Receiver
Motorola 6412
There are no code modules on the box. The box is searching for the appropriate code to download and is not finding anything suitable. Time to call your cable company.
Dec 09, 2007 | Arris DCT6200 DTV Receiver
Televison & Video Logo
433 people viewed this question
Top Televison & Video Experts
