Question about Panasonic NVVP30EBS DVD Player/VCR
How do I reset my remote control back to vcr1 frequency as I have accidently set it to vcr2 and now I can get the video setup menu to appear so I can change it back
  • 47 Answers
SOURCE: dvd recorder remote control
Anytime your unit displays RC1, 2, or 3 - the remote code needs to be reset. Other messages are "chk remote n" or "set n", n being the number 1, 2 or 3. These remote codes are set in case you have multiple products that interact w/ the remote - so when operating one device the other doesn't interfere. Unfortunately, every now and then for completely unknown reasons, they can slip out of the proper code. All you have to do (if your remote is, in fact, functional) is press and hold the number on the remote that corresponds with that which displays on the unit - in your case the number 3, and hold the Enter key at the same time for about 5 to 10 seconds. This should resume operation shortly thereafter. However, you will not see any confirmation on the display as you are performing this reset. It is trial and error.
Posted on Apr 05, 2008
  • 70 Answers
SOURCE: Remote Control
have you tried leaving the batteries out for an hour?
Posted on Jul 28, 2008
SOURCE: DMR--EZ48V
Your DMR is telling you that it is set to listen for RC2 but your remote is transmitting RC1.
Two choices for a fix:
1. Put the remote back into RC2 mode by simply holding both the ENTER and 2 button for at least 5 seconds.
OR
2. Reconfigure the DMR to listen for RC1 by going into the function menus and selecting SETUP. Look for the remote control option. Change it to 1, it will currently display the value 2.
Enjoy.
Posted on Jan 28, 2009
  • 6 Answers
SOURCE: I accidently selected in the setup for TV type>
connect an rca connection cable on the yellow video output on your dvd player to your tv, grab your tv remote and select that input, then go to the setup menu on your dvd player and change the settings.
Posted on Apr 27, 2009
Demonic-2011
  • 467 Answers
SOURCE: While going through the setup
You can try resetting the remote itself (this is necessary whenever the batteries are replaced). Remove the batteries, as if to replace them, press any key on remote (to clear its buffer) then reinsert them. Next step, since your unit is 'Set 1' (or remote command mode 1 - DVD1/RC1) - you could (on the remote) press 1 and OK/ENTER together - hold them for 10 seconds, then release.
This should restore the remote to the unit. If it doesn't, a workshop service may be required to reset the unit internally, but at a cost. Try the remote battery reset first (even try using new batteries).
Posted on Apr 06, 2011
Testimonial: "Your correction routine works like a charm. Thanks a million from an 88 year old who has been working in electronics since July 1941."
Setting code remote control tv polytron plm32b72
Find codes for each device and brand.
Press and hold the TV, VCR1, VCR2•LD,SAT•CABLE, or AUDIO button you want to set up.
Enter the three digit code from the TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box, or Audio code list.
Release the device key.
With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat 2-4 using another code.
To get code list and more, try these sites. [1], [2]
Dec 28, 2012 | Universal Remote Control
How to connect Denon avr 1804 connecting to roku hd
I connected by Roku to a Denon 1804 Receiver this way:- I plugged the cable that came with the Roku into VCR2 input jack of the Denon. (I used VCR2 because it was available).- Using the remote from the Denon, I made sure the slide switch was on "Audio." (See page 20 of Denon Manual).- I pressed pressed the System Setup button- *System Setup appears in display of Denon- Using the cursor buttons I scrolled to menu Digital in Assignment- I set Menu item 16 Coaxial to VCR2 since that was the input jack I used for the Roku. - After making the selection press the CH Select Enter button to save- To exit the System Setup press the System Setup button again- When using the Roku, select the input source as VCR2 (or whatever jack you used). You should now have sound through the Denon.The most important step is to read the Denon manual starting on page 20
Dec 08, 2012 | Denon AVR-1804 Receiver
I need to know how to program an old rca CRK76AD1 surround remote that works a tv, vcr1, vcr2, dvd, am/fm, cd, tape,sat-cab
1. Turn on the component to be programmed.
2. While keeping the corresponding Source Button pressed (like TV, VCR1, VCR2, DVD, etc.), enter the 4 digit code for the device using the number buttons.
3. Release the component button, then press ON-OFF to see if the component will be turned off.
4. If this does not work, repeat steps 2 & 3 by trying to use the next code (if available) listed for the brand of your component until the component responds to the remote command.
Jan 05, 2010 | RCA Televison & Video
My x box will not play through my rca projection tv it was working 2 weeks ago i unhooked it because my vizio tv had to be repaired now i can't get the tv to recognize it. i've tried all the different...
yes, you will have to set up and assign the aux channel thru the tv menu.. make sure that the xbox is
turned on so that the tv will pick up the signal..
Nov 10, 2009 | Microsoft Xbox 360 Elite Console
I want to duplicate a vhs tape....how do i hook up 2 vcr's and the tv to do so?
vcr1 plays the tape
vcr2 does the recording
connect vcr1 video/audio output to vcr2 audio/video input to audio/video output to tv audio/video input
May 27, 2008 | Televison & Video
Proscan vcr plus gold stuck in lock
I just had the same problem and found a solution on the internet that worked. Hopefully you still have the VCR's remote control. Press and hold either the on/off, VCR1 or VCR2 button on the remote. I pressed the VCR1 button and held it for about 5-7 seconds. It released the lock and worked fine afterwards. The lock is some kind of childlock devise.
Mar 10, 2008 | Proscan PSVR73 VHS VCR
Hitachi onscreen menu access
Afraid only the original remote will fix this. All universals and aftermarket remotes will not have the function you need. try going here www.vancebaldwin.com and use there remote finder and see if they have the one you need
Feb 26, 2008 | Televison & Video
I need programming procedure for RCA remote control rcu-100, along with the codes for sharp TV 13l-m100.
hit component button (tv. vcr1, vcr2, cable , or audio. you'd hit tv) then ID button. within 3 seconds, enter two digit code and test with on/off button.
sharp has quite a few codes. if first doesn't work, move to next code.
11,20,25,27,37,52,53,59,60
Jan 10, 2008 | Televison & Video
How to set up to copying a video tape.
This is a snap, as long as you have a second VCR if not you can't do it.
1. Hook the out put line(s) from VCR1 to the input line(s) on VCR2.
2. Put recorded tape into VCR1 and press play.
3. Set VCR2 to the channel that VCR1 is playing on, it's usually 3 or 4.
4. rewind the recorded tape and put the blank into VCR2.
5. Press record on VCR 2 and play on VCR1.
if you want an exact copy stop here. . . or
6. pause VCR2 when ever something comes up you don't want to record, ie a commercial if you'r re-recording a movie from TV. be for warned though each time you re-record an analog recording, like a VHS tape, the audio and vido tracks get further and further apart. After about the second or third time you re-record a tape you'll hear something before you see it, or vice-versa. I hope this helps you out.
Dec 24, 2007 | Emerson EWD2202 DVD Player/VCR
Panasonic NVVP30EBS DVD Player/VCR Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
