Question about Garden
CTC318 45 Min. Charger REPAIR MANUAL - Garden
Why does my battery charger only go on float charge
If you are saying the charger is staying on the very low side of charge for a dead battery .depending on the type charger you have it may be your battery is too low for your charger to get the dead battery going..sometimes I need to give a completely dead battery a jolt to get it going..if you have or know some one has a jump start type charger that puts out very high amps for starting..have them give it a few min of that high amp charge..if you have a battery where you can take the cals off you should see the cells bubbling...All cells must show some or it is shorted. Just don't let on more the a min or two...good luck
Oct 01, 2014 | Cars & Trucks
Chevy 4X4 Repair
This sounds strange but it works! Clear all codes, turn the key to the on position and leave it there for 25-30 min, a battery charger or jump box is recommended but not absolutely ness as long as all accys are off. then try to start it, if problem persists see a gm dealer.
Oct 19, 2013 | Cars & Trucks
Bought the rechargeable light new a couple years ago, used one time for about 90 seconds. Went to use it again, it was dead. plugged in the battery charger into the cig lighter and it worked after 5 min....
First, ensure the charger is delivering voltage using a volt meter. If it is, the battery is probably bad. If you have soldering skills, the light can probably be disassembled and a replacement battery can be purchased from Radio Shack or online.
Jun 29, 2011 | Camping, Backpacking & Hiking
My ipod wont turn on help me it worked for a min then it turned off
  1. Try plugging your iPod into your computer or into a wall charger. After a few hours, try using it without it being connected to the charger.
  2. If your device is less than a year old, go to the Apple Store and they may be able to replace it for free on the spot as part of the warranty.
  3. If your device is older, you can go to the Apple Store and have them repair it for free
  4. You can go to the Apple Store with your iPod, and buy a new one for 10% off.
Mar 10, 2011 | Apple iPod touch
Dremel Stylus model 1100
Change the capacitor 220uF and it will most certainly work again. I got the idea from FixYa and it solved my problem!
Easy to change just 2 soldering points and a component costing around 0,2 Euros. If you do not know how to operate a soldering tool ask someone for a quick assistance. The switch takes around 2 min (1,5 min to open the charger and 0,5 min to change the component!).
/Johan
May 05, 2010 | Dremel & Stylus Lithium Ion Cordless...
My magellan maestro shuts off after 10 seconds even if it's plugged in the cigarette lighter charger.
I had similar problem. While it was still on I pressed the recessed "reset" button and it magically fixed the problem. It retained all my prior settings and locations. Note: must press reset before unit powers off.
Mar 07, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Yellow & Green lights stay on,battery will not charge
I hooked a 12 volt car battery charger to the battery for about two min. Then I put it in it's own charger,the yellow & green lights came on for about 5 sec. then the red light came on . About 30 min. later the green light came on and the battery is fine.
Jun 22, 2009 | Ryobi Multi-Volt Battery Charger
Charger/power light will not come on when plugged into usb or car charger
Check the FUSE usually located in the plug if so equipped try owners manual. Also check car fuse for short or overload fuse opens, also bad battery replace it, try Mouser electronics lotta techs are ordering on line no min order.
Apr 16, 2009 | GPS
Sidekick 3 powers down
The Sidekick 3 has an issue with the charging port going bad. It sounds like your may be having this issue. That or your charger is going bad. You battery sounds like it may be an issue as well.
The charging port issue can be worked around by getting an cradel with a spare battery charger slot. An extra battery is a good idea as well. That way you can have one charging with the other one is in use. A new battery and a cradle charger go for about 30-40 dollars on ebay.
Check out Sidekick Battery Charger to see whats available.
Jan 19, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Maglite charger
Hold the maglite after 30 min charge if warm means charging , if cold no charging , test the light when so bright means very good.
Dec 25, 2007 | MagLite - Mag Charger System 110v (M)...
Garden Logo
234 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
