Question about HTC Touch P3450 Smartphone
Not receiving a gps signal
Can anyone help as to what com port and baud rate you have set into your htc
Thanks
Pete
  • 34 Answers
Com4, Baud 56K, Other NMEA GPS Antenna.
Posted on Jul 08, 2008
My navman icn 320 keeps searching for gps signal
a few things to ensure
1) battery is fully charged
2) Thed correct BAUD rate and PORT are set ( see manual)
3) You are oiutside and there is a clear view of the sky.
Still failing? Then possible damaged SIIRF chip caused by starting engine while plugged into power socket
Please rate my help++++Thanks for using FIXYA
Jul 12, 2010 | Navman iCN 320 GPS Receiver
My finedrive is not picking up an signal...it says waiting for gps signal and nothing happens.
some of the reasons a GPS cannot find signals..
1) BAUD rate and PORT are incorrect
2) GPS not in clear view of the sky
3) Battery is too low to receive signal.. Recharge using USB or AC charger before trip
4) Siirf chip is damaged from plugging in gps when starting the engine, this will damage the chip beyond repair
May 31, 2010 | Fine Digital FineDrive 400 GPS Receiver
Igo sat nav cant get gps signal ,it was working fine untill november 2009,now it does not pick up gps signal
The mosdt common reason for non connection is low battery power. The battery lasts approx 2 years and may not be charging correctly. Try changing to a new battery.
Second reason is that it is not on the right port, consult manual for your model and set it to its correct port and BAUD rate.
Finally if you have started the enginbe with it connected to the 12v car outlet you may have damaged the chip.
Feb 27, 2010 | Navigon GPS MobileNavigator 5 Base Car GPS...
My navman f15 will not recieve signal anywhere
the reason your device does not receive any signal is because the baud rate and com port might be wrong. go to settings and fing GPS port, after entering choose auto choice so it can take the suitable gps port and baud rate
Feb 19, 2010 | GPS
No valid GPS signal for two days, what I can do?
You can try a reset Check in the manual where the reset hole is i thinlk this model is under the scfreen surround which is removable.
This will take ut back to factory settings, you might want to check if its set to the right PORT and BAUD try this
GPS Program Port: COM1
GPS Hardware Port: COM9
Baud Rate: 4880
Manage GPS Automatically (Ticked)
Now other reasons are low battery= low signal//fully charge the battery
no signal from satellites= damaged SIIRF chip caused by plugging into car power when starting engine...needs new m/board
Maximum time to access 1-9 minutes max...
Please rate my help++++Thanks for using FIXYA...
Dec 01, 2009 | Tomtom ONE GPS Receiver
After installing iGo navigon no gps signal
You must edit port and baud rate in sys file. If dont know parameters just write:
[gps]
port="auto"
baud="auto"
Aug 26, 2009 | Navigon 5100 GPS Navigator Handheld GPS...
My HTC TyTN II GPS does not appear to work. I have bought the device, and when I first installed TomTom the device was able to get a GPS fix, Howeve after I ran external GPS, the device no longer seems...
I Got it!
I finally got my HTC TyTN II yesterday from Dubai.
First thing I wanted to test was the GPS. It did not work with: TomTom6, Google Maps, Yahoo Go.)
I was surfing around to find something that would help me out and have noticed that many people have the same problem.
Many people (Like me) did not know howe to setup the GPS.
Many people are saying: "You have to put it your GPS settings in Com 4 and the Baud rate on 4800 and it should work.
Well mine didn't work with those settings. (Along with other people.)
I had played with the External GPS option (Don't do this cause setting something wrongm ay cost you a HARD-Reset.)
I Was lucky that mine worked again after a SOFT-Reset. So watch out!
The standard GPS settings! (If you have changed it, Soft-reset your phone and set it up as these pictures show.)
Why am I doing this?
People buy this phone to make use of it. When something does not work why buy the phone then :S
Hope that this may help a lot of people on here and other forums, communitys & websites.
Here is my story of how I did get my GPS to work:
1. Download the GPS addresses by using QuickGPS (Start -> Programs -> QuickGPS).
(This will download info of what your GPS Reciver needs to connect to the satalites.)
2. Download a free (Well half free, You can also buy this application it will give you some extra options, but we don't need those extra options.) tool named: GPS Test. (http://www.smartphone.net/software_detail.asp?id=3170 or at http://www.pocketpc-software-downloads.com/software/t-free-pocketpc-gps-test-download-uykfcoyy.html)
(This program will scan all your mobiles com ports and Baud rates, To see what your real GPS settings are.
In my case they were: COM PORT: 4 - Baud Rate: 9600 (Notice it ain't 4800. Usaly it shows your settings with a pop-up.
When It doesn't Go to "Menu -> GPS Settings", There it will show you you're GPS settings.)
3. Install TomTom 64. Download your free map.
5. Go to the GPS settings.
(Set-up: Other NMEA GPS-Reciver -> GPS-Baud Rate -> Com. (Select the Baud rate + Com port from what the GPS Test did show you.)
6. Now wait.
Jun 29, 2008 | GPS
Getting my phone to see the GPS signal
Can I Install any other language fonts other than than english
Feb 11, 2008 | HTC Touch P3450 Smartphone
Problem with gps not connecting.
I have Google maps for Mobile working on Mio P550 with GPS Program Port: COM9.
GPS Hardware Port to COM2, baud rate 4800.
http://blogs.msdn.com/windowsmobile/archive/2006/06/07/620387.aspx
Dec 24, 2007 | GPS
HTC Touch P3450 Smartphone Logo
190 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
