Question about Samsung SyncMaster 932B LCD Monitor
Black screen and blue blinking light around the power switch. Computer and everything else seems fine.
  • 11,361 Answers
If it deos the same with another PC, then please read on:
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 29, 2010
L246WH blinking light problem
Probably the power supply is failing but periodically recovers briefly.
Jan 05, 2014 | LG L246WH-BN Monitor
Green LED always on, power switch has no effect
if using a box or receiver in line with the set unplug those as well. I assume the red light on the set is not coming on or a light is blinking?
Dec 18, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Feb 10, 2009 | Soyo DYLM1986 Monitor
Screen is blank.
Could have blown some capacitors inside the monitor.
I just fixed one today that had no power, the blue ring around the power button didn't even light up when plugged in.
I open it and found 3 bulgingcapacitors on the power/inverter board.
They were all 25V 470uF rated capacitors.
Went to radioshack and found 2 35V 470uf, got them at $1.29 each, then I found 1 50V 470uF out of a dc car power adapter for an ipod, it was as close as I could find.
Replaced the 3 broken/bulging ones with the new/salvaged ones, put it back together, plugged it in and the blue light came on when I pushed the power button.
Plugged it in to my laptop with vga cable, and it works great.
Oct 24, 2008 | Samsung SyncMaster 932B LCD Monitor
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Monitor Went Black
It sounds like the monitor might be going bad. I would try hooking up another computer to it. If it works with another computer, then I would say the Video card might be going bad.
Mar 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Samsung SyncMaster 932B LCD Monitor Logo
224 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
