Question about Wagan 20072 3000 Watt 12 115 Volt Ac Dc Power Inverter
VW, Jetta 2009, 115 V inverter. red flashing light on all the time. Should be green when a plug is inserted (the child safe feature, I guess). The red light starts flashing from start. Every two or three seconds the green comes on a fraction of a second, then back to the red flashing light. Check fuse (OK), checked the child safety switch (OK), Normally an overload would create this problem, but then it should get back to normal (green) when unit has cooled down. It does not turn back to normal after sitting in minus 15 deg. C for all of the night. bf
Hot point washing machine WMA76 stuck on child lock
Child Lock
?When activated all the buttons will be disabled and a child will not be
able to alter any wash programme or option settings. Once selected
this feature remains activated, even when the machine is 'off'.
To use this feature press the 'Child Lock' button and hold down for 2
seconds.The child safe icon will begin to flash.When the icon stops flashing
the feature is activated.If any of the control buttons are pressed, the child
safe icon will flash and the machine will bleep 3 times: no alterations to the
control settings will be allowed.If power is interrupted, at any time,pressing
any button will reactivate the child lock feature.
To deactivate this feature hold the 'Child Lock' button down for 4
seconds.You will then hear a bleep and the child safe icon will go out
Mar 27, 2016 | Washing Machines
Glow plug light keeps flashing on a2011 vw jetta
Check brake light switch. Check ECM for faults.
Jan 20, 2014 | Volkswagen Jetta Cars & Trucks
Emissions control light flashing volkswagon jetta why
Hi there, The emission control light can come on for many reasons There are many sensors which
the ECU ( the cars computer ) gets its imformation from to control the engine and therefore the
emissions eg. Oxygen sensor, airflow meter,inlet air temperature,water temperature etc.
The best way to find the fault is have a diagnostic check done ( code reader ) this will find the
problem and avoid guess work which will in the end save you money.
One of the common problems with VW is the spark plug coils, but to play it safe and get it checked
I hope i have been of some help to you
John ( John South Wales UK )
Jun 28, 2011 | 2005 Volkswagen Jetta
Timing of vw engine
You'll need a timing light connected to the number on spark plug wire. On the top of the transmission, below the cylinder head, you should see a round plug, (usually green) with a clear plug in it. Remove the plug, you can then see the flywheel, there will be marks on the flywheel to set the timing. Mark the timing mark with white paint, start the engine, shine the light onto the marks, to adjust, loosen the distributor to turn back or forth to adjust the timing marks.
Feb 26, 2010 | 1992 Volkswagen Jetta
My kenmore elite washer just stop working. My mom
When activated all the buttons will be disabled and a child will not be able to alter any wash programme or option settings. Once selected this feature remains activated, even when the machine is ‘off’.
To use this feature press the ‘Child Lock’ button and hold down for 2 seconds. The child safe icon will begin to flash. When the icon stops flashing the feature is activated. If any of the control buttons are pressed, the child safe icon will flash and the machine will bleep 3 times: no alterations to the control settings will be allowed. If power is interrupted, at any time, pressing any button will reactivate the child lock feature.
To deactivate this feature hold the ‘Child Lock’ button down for 4 seconds. You will then hear a bleep and the child safe icon will go out.
If this is not the problem than turn off the AC power for 30 mintes and then power the machine back on an everything should be OK to use as long as no Error Codes are displayed.
Nov 13, 2009 | Kenmore Elite 45986 Front Load Washer
How do we get childlock off a hotpoint wm 864
Oct 25, 2009 | Washing Machines
I can't remove the childlock on my washing machine! Can you help?
Sep 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Red oil light flashing, oil change no problem but light still flashing noise coming from tappets are they related I have a problem on my vw jetta ? flashing light on my dash
Yes it is related, don't drive it. First thing you should do is install a new oil filter even if it isn't time for an oil change.
May 31, 2009 | 2000 Volkswagen Golf
No power output from my vector 1000w inverter.
Buy a different brand of inverter. Yours has developed a short which the protection circuit is catching. It then tries a restart but fails all over again. Most likely o/p short which looks like an overload to the inverter.
Jan 30, 2009 | Electronics - Others
Transmission fluid check on a vw jetta tdi
Never ever bring a jetta to a volkwagen dealer. They will bend you over and rape you.
All you have to do is remove the top plug with a hex wrench.
Dec 17, 2008 | 2000 Volkswagen Jetta TDI
Wagan 20072 3000 Watt 12 115 Volt Ac Dc Power Inverter Logo
Top Wagan Electronics - Others Experts
Are you a Wagan Electronics - Other Expert? Answer questions, earn points and help others
