Question about Dymo LabelWriter 330 Thermal Printer
Trying to use USB connection. Power good. Program install seems correct. When told to connect USB to computer, nothing happens (no recognition.) Have to cancel out of install. Have checked out supplied USB a/b cord with another device and it seems fine. Running XP Pro. Former owner said device worked fine. Appreciate any suggestions
    Genius:
  • 1,739 Answers
Following are three possible issues you can easily investigate and correct:
Upgrading DLS or Adding an Additional LabelWriter
A previous LabelWriter printer may still be installed with documents in the print queue. You must delete any documents in the print queue for all previously installed LabelWriter printers before proceeding with the installation.
1.Open the Printers folder. Based on Operating System and system configuration, the Printers folder can be accessed in one of the following ways:
Start > Settings > Printers
Start > Control Panel > Printers & Other Hardware > View installed printers or fax printers
Start > Control Panel > Printers & Faxes
2.Double-click on the LabelWriter printer, the print queue will open.
3.Delete any pending print jobs and close the print queue.
4.Reboot your computer and re-run the DLS installation.
Installing DLS and a LabelWriter for the First Time
Some antivirus or anti-spyware applications may prevent the installation of DLS and the LabelWriter printer. You may have to temporarily disable these applications in order to successfully complete the installation.
1.Restart your computer.
2.After restarting, temporarily disable any antivirus and anti-spyware applications.
3.Install DLS, connect the LabelWriter when prompted during the installation.
4.Once installation has completed, re-enable any antivirus or anti-spyware applications.
DYMO Label Software Fails to Install because Word or Outlook is Running
While installing the DYMO Label Software (DLS), prompted with a message that Word or Outlook is open. How can I resolve this?
1.Exit Word and Outlook.
2.Open Task Manager.
??¦To open Task Manager press Ctrl - Alt - Delete.
3.Click on the Processes tab in Task Manager.
4.Verify that WINWORD.EXE and OUTLOOK.EXE are not running processes. If present, select every instance of WINWORD.EXE and OUTLOOK.EXE and click on End Process.
5.Close Task Manager and reinstall DLS.
Should you require updated driver/software for your printer and operating sytem, check here.
Trust this helps resolve your installation problems. Please vote.
Posted on Dec 29, 2010
How can Western Digital hard disk drives be recognized by third party USB external docking stations?
The format on a disk, will not be relevant of recognition via an USB connector. To connect a drive via USB, the computer must have the correct driver for the hardware you are connecting. Be sure you connect the HD coerce to the external harness and make sure it is supplied with the correct voltages.
When you connect a working system on the USB connector and the drive does not have a format, the computer will see that and ask you if it should format the drive.
Mar 04, 2015 | Western Digital Computers & Internet
Recognition of recorder
Does the computer recognize the Olympus DS-30 being connected to it at all? If not, do you happen to have another USB cable that you could try using? Either way, you should try connecting it to a different USB port on your computer, as you might have happened to connect it to one that doesn't work.
Jan 06, 2008 | Olympus DS-30 Digital Voice Recorder
Power Light comes on, no function what so ever
Check to make sure that the FireWire or USB cables are
correctly attached and firmly seated in both the drive and
computer's FireWire or USB ports. Disconnect them, wait 30
seconds, and reconnect them. If the drive is still not
recognized, restart your computer and try again. If they are
correctly connected and your drive still does not power on,
trying using the optional power sharing cable, described in
section 2.3 Connecting the Optional Power Supply of the LaCie Mobile Hard Drive User Manual.
Feb 17, 2013 | LaCie Computers & Internet
What is an ORC?
ORC is life form in the Lord of The Rings. What you want is OCR which stands for Optical Character Recognition. It is the software that converts a scanned document into a string of characters that you can edit to correct OCR errors.
To be able to scan to a computer the computer and the printer must be connected through a USB port or be part of the same network.
When you press the scan button, the printer tries to communicate with the computer and launch the scanning software installed on the computer.
Install the software that shipped with your printer, connect the computer and the printer. If everything is correctly connected and installed, the scanning software will open to receive the scanned document.
Oct 14, 2012 | Lexmark X5650 All-in-One InkJet Printer
Adding to ubuntu desktop
it could be that power isn't sufficient on the USB connection. you might need to plug in your AC adapter.
Also this drive has both FireWire and USB ports on it.
To get it working, make sure that the AC adapter is supplying power, and that USB is connected correctly, then re-boot.
Ubuntu should recognize the drive.
Command line tools that may help are
lsusb
this shows which devices are connected via USB to your computer.
dmesg | less
will help you look for the drive's identification and recognition by the computer, providing information such as vendor strings, capacity, and device assignments.
Good luck.
Mar 23, 2010 | FireLite (USBFLB80) Hard Drive
No connection recognition
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Nov 15, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Cannot make TomTom HOME recognize my device
Sounds like you are trying to install tt home from your tt device. Go to the tt website and download from there.
Mar 01, 2009 | Tomtom One XL GPS Receiver
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Nikon Coolpix S550. Installed Nikon Transfer..won't work.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo management program, such as Picasa.
Organize edit and share your photos
Dec 08, 2008 | Cameras
Portable Hard Drive will not respond / install
how many wattage had your computer? you need to upgrade your power supply.you need also to check your bios setup on usb port
Oct 01, 2008 | Toshiba Computers & Internet
Dymo LabelWriter 330 Thermal Printer Logo
443 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
