Question about Reddy R115DT Oil Filled Utility Heater
Reddy Heater Pro 100: plug in, fan turns on, blows out small amounts of unburned fuel and then fan shut off. What could be the problem?
  • 1,476 Answers
Jeffsampson,
This is a classic reddy heat problem. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to go to get the parts you need to fix it.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Dec 30, 2010
I have reddy pro 170 i plug it in , the fan & igniter comes on for 10 to 15 seconds then shuts off ,blew through fuel line and nozzle still same result, i do see fuel mist coming out nozzle ,i dont k
You must make sure the mist is not to close to the igniter . If it is it wont be misty enough to ignite. And make sure its in the path of the mist. If its new return it to the store.
Feb 07, 2015 | Reddy Heater Pro-Tough Kerosene/Diesel...
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a Reddy heater pro 155.
Check all of your air filters but most likely it's the CAD flame sensor.
Jan 22, 2009 | Reddy R155D Utility Heater
Reddy heater 115 just turns on then shuts off
a new flame sensor is in order, if you have spark and it blows fuel then thats the answer. you can get one thet will fit from Mr. Heater for 3 bucks. the wires are different so just splice the to your old wire harness, there is no wrong way to hook them up.
Jan 15, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Blowing smoke immediately prior to auto-shut-off
Try a new CAD falme sensor, or high limit control, both very cheap.
Jan 07, 2009 | Reddy R155D Utility Heater
Unburned fuel coming from front nose cone when heating
in the back of the heater by the filter there should be a screw if yours is like mine screwing it in adds fuel backing it out gives you less make sure filtre is clean because if it isnt it will make it **** more fuel i took the cover off watched the ignitors and adjusted the fuel until it stoped making the jet sound and that is where i left it seems to be burning good there give it a try hope i helped
Jan 04, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater pro 110
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Nov 01, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Does your heater use the older spark plug technology or the newer Hot Surface Ignitor (HSI) technology?
Without this critical information about all this technician can do is guess.
My best guess at this time would be either water in the fuel or a restricted fuel filter.
Nov 01, 2008 | Heating & Cooling
Reddy R115DT Oil Filled Utility Heater Logo
99 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
