Question about Kenmore Dishwashers
My Kenmore Dishwasher Model #16769000 says its a Kenmore 665 will not unlock to restart the washer. The air dry light will not go off and we held it for four seconds and still it did not work. Help
  • dhowe Jul 07, 2008
    This didnot work
    Turning off the breaker did not work.
  • Kenmore Master
  • 19,396 Answers
Unplug the machine for at least ten mins or so, replug with cycle at start, try restarting cycle, if it still get locked on dry, then probably the control panel must be replaced.
Posted on Jul 07, 2008
    Genius:
  • 1,011 Answers
Sir,
Open the door if its not locked and there is a square section with a piece of metal behind it, push it in and turn the lever. There is a small protruding finger that is on the dishwasher that moves into that hole to show door is closed. If your door is locked in position and you cant open it the only thing you can do is pry the two retaining screws that hold the dishwasher to your countertop and pull out the dishwasher far enough to unscrew latch and repair. sometimes it gets bent and all you have to do is bend it back either up or down.
Thanks
Good Luck
"Don't forget to rate the solution"
    Genius:
  • 1,689 Answers
Push the heated wash and the heated dry buttons one after the other for about 5 times, then all lights will lit up, the washer will go through different settings, just wait and it will start normally.
good luck
  • marlon john madrid
    marlon john madrid Jul 07, 2008
    dhowe, sorry about this, i forgot to tell you this earlier
    "try to hold in the No Heat rinse button for 10 seconds"
    Master:
  • 788 Answers
Press Sani-Rinse then Heated dry then Sani Rinse then Heated dry. This should reset your machine and you should be able to restart your cycle.
    Master:
  • 555 Answers
Try unplugging and replugging to reset (or, if the plug is too difficult to reach, reset the breaker)
The lock symbol light is on and the dishwasher won't start
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock
the dishwasher controls by pressing and releasing
the DELAY START pad (some models) or the AIR
DRY pad (some models) for 3 seconds. An
indicator light on the lock graphic pad will illuminate
when the controls are locked and no new
selections can be made until the lock is released.
To unlock the controls, press the DELAY START
pad or AIR DRY pad until the indicator light goes
out
Nov 21, 2010 | Frigidaire PLD4555RFC Dishwasher
How can I get my lock on light off and turn my ultra dish washer on all buttons are disabled it is kenmore 665 15819
If the model number is correct, press and hold the "NO HEAT DRY" button for 4 seconds to lock or unlock the controls.
Aug 23, 2010 | Kenmore 15899 Built-in Dishwasher
Dishwasher won't run. Light flashing on Air-Dry button.
check bottom of dishwasher, front left, round breather, gets clogged...clean and restart
Mar 13, 2009 | Dishwashers
Kenmore 665 15899
To reset and run diagnosis on the model 15899100 Kenmore Dishwasher you need to press the following buttons on your front panel. Hi Temp, Air Dry, Hi temp, Air Dry. The sears service technician just left my house and used these codes to reset and run diag on my washer.
Hope this helps
Jan 05, 2009 | Kenmore 15899 Built-in Dishwasher
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Kenmore dishwasher model #587.16252402
Hi stmike1georg
I'm Harvey the Master Plumber.
You want to know how to unlock the controls on your dishwasher?
No problem. You'll notice the lock light is next to the "heated dry" button. Just press and hold till the lock light goes out, about 6 seconds. The same process will turn the lock light back on. Perhaps the last time someone touched it they held it too long.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Whirlpool Quiet Partner II dishwasher
I held down the heated dry button & it worked!
Aug 26, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher Problem
According to my ultra wash dishwasher you have to hold the no heat dry button for 4 seconds and that is how you lock and unlock the control panel
Jun 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Blinking Quick Rinse
brent, After doing a little research on this model, I see that Sears put out a service flash concerning this problem. Dishwasher stops in mid cycle and one or more of the lights are flashing. SF22-715. The correction is to replace the existing board with an updated board that controls the line voltage better. Part number 8530928. You could be covered under this flash. The tech will have to eliminate the possibility of a stuck or shorted keypad which will cause this same effect. You can try to get this back in operation by pressing in this order: high temp wash-air dry-high temp wash-air dry. This will put it into a self test mode. Just let it run through if it works. If you don't have those keys try power scour-air dry-power scour-air dry. Catriver...post back.
Nov 19, 2006 | Kenmore 16639 Built-in Dishwasher
Dishwashers Logo
247 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
