Linotype 560 SPINNER TIMEOUT - Office Equipment & Supplies
SPINNER MOTOR FAULTY
Posted on Feb 06, 2011
  • leroes64 Jul 15, 2011
    Tengo, una linotype 560, tenia las balineras muy ruidosas, se las engrasamos y luego volvimos a armar el spinner y ahora da mensaje "spinner timeout"
The "Spinner timeout" error message is usually caused by one of the following 2 parts.
LES assembly (set of boards) ................... US$ 990
Spinner motor ........................................... US$ 1,395
Peter Warzecha, Sales Manager
Viprofix Prepress Solutions
3650 N. Cicero Ave. Chicago IL 60641
Phone: +1-773-545-7700 ext. 217
Email: pwarzecha@viprofix.com
Website: www.viprofix.com
Posted on Sep 10, 2015
Oki b430 error timeout
It is a timeout value which works only when a job
with a specified size is received.
Apr 24, 2014 | Oki Electric Industry Office Equipment &...
I cannot find Habitat Linotype complete skateboard anywhere! Every single site is sold out. When is the next shipment?
You'll have to ask the manufacturer. FixYa has no access to another company's manufacturing/shipping records.
Oct 17, 2013 | Habitat Linotype Skateboard Complete
When i load a disc, the unit says that there is no disc. Have tried many dvds.
This happened to me too. Try wiping the DVD clean. I did this and then it worked. "Auto F5 reload window" options Default timeout * Timeout for this page * Add random value to timeout between 0 and * Show and hide menu Ignore everything after these symbols in URL(separate with spaces) Include the separators in the URL saved Hide menu when clicking outside the menu Prolong timeout on mouseclicks or keyboard input Reload all pages with default timeout, which has no timeout set
*Format examples: hh:mm:ss, h:m:ss, m:sss, s etc. like 1:20:30 oder 500 oder 3:100
Dec 23, 2010 | Philips HTS3151D/37 Theater System
Will a Linotype Hell Ultra 2 Saphir run on a pC?
Yes. Just got mine running on Windows ME. Problem is getting the SCSI set up. Once you get that done, I used Vuescan (http://www.hamrick.com/) and it works. Slow, but functional. I have yet to get scans of the full scanner screen (10 x 14 inches). But 8 x 10 is working fine.
Sep 10, 2009 | Heidelberg Linocolor Saphir Ultra2 Flatbed...
Windows XP Timeout
You can fix this by removing that software. But if you must keep it, you can change the timeout by doing the following:
  1. Login to Windows
  2. Start > right-click My Computer > Properties
  3. Advanced tab
  4. Under Startup and Recovery click Settings...
  5. You will find the timeout settings there
Best of luck. Please vote for this answer. Thank you.
Jun 19, 2009 | Computers & Internet
Message ID . . . . . . : CPA403D Severity . . . . . . . : 99 Message type . . . . . : Inquiry Date sent . . . . . . : 12/11/08 Time sent . . . . . . : 15:13:47 Message . . . . : Operator action required on...
This is a JetDirect error and can be cured by adjusting the IO and Idle timeout values. Set the IO Timeout (or Job Timeout) to 300 seconds ( 5 minutes) and set the Idle Timeout to somewhere between 900 seconds (15 minutes) and 3600 seconds (1 hour). Setting the IO Timeout (or Job Timeout) and Idle Timeout to 0 does not disable them. It causes the printer and/or print server to timeout immediately. The IO Timeout can typically be set through the control panel on the printer, or it can be set using the HP JetAdmin Utility. The Idle Timeout can be set by TELNETing to the TCP/IP address for the printer, or it can be set using the HP JetAdmin Utility. The HP JetAdmin Utility can be downloaded from HP's Web site, www.hp.com.
The print job is defaulting to tray 1 so you will need to change this at the application and printer driver admin and not at the printer itself.
Dec 11, 2008 | HP LaserJet P4014n Printer
Time Out Error
This is from Xante's 3G Manual (downloadable via PDF)
"Printer Timeout The Timeout feature allows you to select the number of seconds the
printer waits for additional data before cancelling a job and returning
to the READY/IDLE state.
Set Timeout from the MISC:TIMEOUT configuration menu. The
factory default of 40 seconds (40 Sec) is an average setting. Set
timeout according to the type of files you send. Use a low setting for
small, simple files to prevent an indefinite tie-up on one job. Use the
300 or Never setting for large files, such as graphic intensive or CAD
(Computer Aided Design) files, to allow enough processing time.
With the NEVER selection, the printer does not timeout; it waits
until it receives additional data or until the printer is reset."
Here is the address where you can download the manual:
http://www.xante.com/support/aw3g/manuals/PDF/complete.pdf
Nov 15, 2008 | Xante Accel-a-Writer Laser Printer
Taking the spinner off
if you are calling the washplate the spinner pry off the dome then take out the six or eight bolts holding it down.
Oct 25, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Duplicate/incorrect MAC addresses in the CAM table
This is from the Cajun P333R manual but it should be very similar if not identical.
Good Luck.
arp timeout Command
Use the arp timeout command to configure the amount of time that an entry
remains in the ARP cache. To restore the default value, 14400, use the no form of
this command.
The syntax for this command is: arp timeout <seconds>
The syntax for the no form of this command is: no arp timeout <seconds>
Examples:
To set the arp timeout to one hour:
Router(configure)# arp timeout 3600
To restore the default arp timeout:
Router(configure)# no arp timeout
ip-address IP address, in dotted decimal format, of the station
hardware-address 48-bit address of the local data link
seconds The amount of time, in seconds, that an entry
remains in the arp cache.
Nov 09, 2007 | Lucent Cajun P333T Networking Switch
219 people viewed this question
jasbo
jasbo
