Question about Dell Inspiron 1525 Notebook
My dell laptop 1525 wont turn on or even charge i tried holdin FN and F3 but nothing and unplugged everything and then later plugged back in and still nothing. I had just used it the other day and now nothing will come on. how do fix it and what caused this?
  • 2,567 Answers
Please make sure it is not a power supply issue. Refer to the following article for more details:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Posted on Dec 29, 2010
My dell inspiron 1525 wont even come on when i press the start button, nothing?
Hi Jerrel Castille,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    Now try turning on the computer. If still same issue then check if there are any series of beep codes emitted from the computer and see if there is a Power/ Battery status light glowing near the front (touchpad) of it.
Feb 05, 2015 | Dell Computers & Internet
Dell inspiron 1525 pluged in not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
Dec 02, 2012 | Dell Inspiron 1525 Notebook
Inspiron 1525 charging problem
Try the following steps to solve it:
it of googling on the web and finally found the solution here.1 Turn off laptop.2 Unplug AC power.3 Remove battery.4 Replace AC power.5 Turn on laptop, allow OS to boot.6 Once logged in to the machine, perform a normal shut down.7 Unplug AC power.8 Replace battery.9 Replace AC power.10 Turn on laptop, allow OS to boot. The battery should once again be charging as normal.If it can't still resolve this problem, try a new laptop charger or repair your laptop dc jack.
If you plan to be on a budget for your dell 1525, you may try the following third party charger:
Replacement Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Oct 20, 2012 | Dell Inspiron 1525 Laptop Midnight Blue
I cant use f3 key to disable battery charging for dell inspiron m101z.
You have to Press and Hold the FN function key at the lower left portion of the keyboard, then hit the F3 key. Hitting the F3 key alone will do nothing.
May 18, 2012 | Dell Inspiron M101z Laptop Computer (AMD...
I have a dell inspiron 1525 and want to hook it up thro the hdmi lead to my sony bravia lcd tv. I have tried doing this with the lap top off when i plug it in and doesnt work. I can get the laptop to...
There is usually a keyboard combination to switch between the laptop screen and your TV.
The keyboard toggle is done by holding down the Fn key and pressing one of the F keys (between F3 and F6).
Good luck.
Jun 27, 2010 | Dell Computers & Internet
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
I have a dell inspiron 1525 and it wont charge
If possible could you check output voltage of the charger with a multimeter? If you can get output voltage, then might be something wrong with laptop battery charging circuit. Contact Laptop Repairing Engineer.
Regards;
Hassan
Aug 04, 2009 | Dell Inspiron 1525 Notebook
My dell inspiron 1525 vista will not turn on
ok first remove battry .press start button for 15 seconds and now aplly battry and give sometime on charging and than press start button . enjoy good luck
Jul 28, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 not turning on
hi. I suspect that you have either a dead battery or just need a reset. unplug the power cord and then remove the battery. wait two minutes and reinstall the battery.
this will reset everything. now try turning it on. if it won't come on plug in the power cord and charge the battery for 30 minutes before attempting to power up.
Jun 29, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 will not charge the battery
CHECK IN YOUR BIOS AND MAKE SURE ANY SETTINGS FOR POWER ARE ALL CORRECT ...SO THAT WOULD BE A F2 FUNCTION IF THE ABOVE IS CORRECT ...SEE IF THAT SOLVES THE ISSUE .
Jun 02, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Notebook Logo
54 people viewed this question
Alun Cox
