Question about Sony DAV-FC7 System
I have a Sony DAV-FC7 System that has worked well for about six years. Recently it has "resisted" turning on when I push the power button (the red light in the button stays on). For some time the switch worked when I had left it plugged in for hours; it almost seemed as if the switch had to "warm up" to operate. When I push the power button and hold it the red light pulses (the remote can also cause the light to pulse). Thanks in advance for any assistance.
  • 22,156 Answers
You will need a specialist repair man their is a problem with the switch but a micro chip recieves the order from the switch and then tells a transistor to switch power on ,its a bit beyond myself this problem but the sony agent will change a part and it doesnt cost a lot .
Posted on Dec 29, 2010
Sony DAV-FC7 won't power on. I bought it new and have only had it for about 2 years.
I suspect you might have a power failure caused by an internal fuse. Fuses rarely just go on their own, so it might be caused by an overload, generally caused by a faulty output device.
If you have any knowledge to repair one or no someone who has you can or they can look around inside. Otherwise it's off to the repair shop with it. Unless you have a five year warranty on it or have paid for extra cover, then you will be liable for the full cost of the repair. If you have a five year cover or extended plan, contact the manufactory or the service plan provider. But do NOT open the unit yourself.
Sep 25, 2016 | Sony DAV-FC7 System
Can i watch regular tv and use the dav-fc7 as audio?
just run the "line audio" not your speaker audio out from your tv to the aux or dv/cd input...
on your dav-fc7 it will sound great! just turn the tv audio sound down at the set.
Dec 03, 2010 | Sony DAV-FC7 System
Video1, video 2 humm
Replace C602 on dvd board. noise on 10v line causing problem.
Jan 19, 2009 | Sony DAV-FC7 System
Sony DAV-FC7 squeals
I had the same problem....but it kept taking longer and longer for it to quiet down, then eventually it just kept whining and I couldn't take it anymore...I had to stop using it for tv and only used it for DVDs (it didn't whine on the dvd function). I was going to get rid of the unit because my old tv died and I had to buy a new flat screen high-def unit, which needs a surround system to do it justice. I then noticed the digital optical connection on the Sony DAV-FC7 as well as my new Direct TV HD-DVR. I bought the optical cable for about $15 and hooked it up....and voila...NO MORE WHINE! If you have the optical connection option....try that route...it might work for you as it did for me. Good luck
Dec 21, 2008 | Sony DAV-FC7 System
My DAV-FC7 System squeals loudly.
If you can, use the digital optical connection....I had the same problem and switched to the digital optical connection and that worked for me....no more whine.
Dvd's wont eject from my sony dav-fc7
because of bad loading mechanisum.
its belt melted i think.can you observe the motor runing sound the inside of player.
nuwan...
Nov 22, 2008 | Sony DAV-C770 System
Sony AV System DAV-FC7 cannot turn on
Now the solution (rather, a workaround) for this problem is power off the main supply (or remove the plug from the electrical outlet) and then plug it again. From now, on do not power off the unit. If you have to, then you need to perform the work around again.
-Sathish
May 13, 2008 | Sony DAV-FC7 System
FAC-FC7 DVD player is locked and the Standby indicator flashes
I had the same problem and searched FIX and found a solution for a Phillips DVD player that worked on my Sony DAV-FC7 dvd player. Someone posted that they called their Phillips Tech Service and was told to (a) unplug the dvd unit from the wall and wait 20 seconds,then (b) press the standby+plug the unit back into the wall at the same time and hold for 10 seconds. I did this for my Sony DAV-FC7 which would not power on nor eject (just red light on). IT WORKED!! after doing these steps, my SONY powered on and the rented DVD ejected. The dvd palyer works again. Thanks fellow FIXYA "posters".
Nov 12, 2007 | Sony DAV-FC7 System
Sony DAV-FC7 System Logo
123 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
