Question about Hotpoint Refrigerators
Water freezing in the drain off - Hotpoint Refrigerators
    Scholar:
  • 148 Answers
Defroster bar ,check with ohm meter for resistance,or defrost timer
Posted on Jul 07, 2008
Samsung RS2630sh. Drain line Freezes shut. Water drains to bottom of freezer and freezes there. Cooling coils are not collecting ice. Drain line has been cleaned. Why does it keep freezing shut?
If water still collecting and freezing at freezer bottom then drain line is not cleared and still obstructing the normal flow of water downward.
Aug 22, 2017 | Samsung Refrigerators
Why is my GE TPS24 drain freezing
It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube. Small particles of food can build up in the drain. Ice forms around the particles and blocks the drain. Sometimes the insulation gets saturated with water and the drain will continue to freeze up in about a month or so. If this is the case there isn't much that can be done except replace the refroigerator
Aug 15, 2014 | Refrigerators
2 problems one water escaping to the drain freeze cycle short
first, freeze cycle too short because you are loosing water. Water may be leaking thru the dump valve. Look at drain while machine is running and see of alot of water is draining. The dump valve spring may be week or there is trash in the dump valve preventing it from seating properly. drain water first before pulling dump valve apart.
Aug 29, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Kenmore elite model 52603100 freezer defrost water freezes in drain tube/plan then over flows to bottom of unit. freezes then water eventally runs on kitchen floor
You need to clean out the drain tube it's clogged that's why the water is freezing.Try using hot water and maybe something like pipe cleaners to get what's in there out.Hope this helps. On some models it may be easier to pull out the refrig from the wall and get to the drain from the back.
Jun 15, 2011 | Kenmore Refrigerators
Freezer leaking water and freezing
you probably have a plug in the drain line that normally drains the water when your freezer goes into the defrost mode. at the base of the refrigerator there is a evaporative drain tray where the water drains from the freezer into the tray and evaporates during normal operation of the unit. You should be able to see the drain tube just above the tray. Attach a hose to it and use compressed air to blow through it and clear it out.
Mar 16, 2010 | Refrigerators
Freezer drain not working. water accumulates and freezes in bottom of freezer compartment and sometimes will melt/leak onto floor
use hot water and turkey baster . force the water down the drain till it clear's to prevent it from freezing again install drain heater . some model's need them.
Jan 18, 2010 | Refrigerators
What is the best way to winterize a standard large capacity washing machine?
If the product will be exposed to sub-freezing temperatures, turn off the water supply to washer, disconnect fill hoses, drain them and reconnect. Remove the drain hose from the standpipe in the wall and place it into a shallow pan at floor level untill the water floe stops. Unplug unit and you are good to go.
If no sub-freezing temps are expected, turn off water supply. Turn on washer for a warm wash cycle for a few seconds to relieve the pressure in the hoses. Turn off machine and unplug it.
Nov 04, 2009 | Kenmore 22422 Top Load Washer
Water Pooling and freezing on floor of freezer
most likely you have a frozen drain in the freezer section so that whne your refrig defrosts the water runs out into the freezer compartment instead of the drain pan underneath. the fix is to flush the drain with warm water to clear the obstruction. the drain can be reached either by removing the cover in the freezer area or by back flushing the line from beneath the refrig.
Dec 10, 2007 | GALAXY Microsystems 25.4 cu. ft....
Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
Aug 15, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
