Question about Linksys : WRT54GS Wireless-G Router W/ SpeedBooster (NELIWP17)
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to the computer. When it's like that, the internet works just fine, but as soon as I hook up the linksys to the modem and computer, it wont work. The WLAN light won't com on on the linksys, and the "PC/ACTIVITY" light on the Motorola modem won't go away. I've followed all the steps on the linksys easy advisor program. The reason I'm trying to set up this wireless network is because I'm trying to get it for XBOX Live. If that makes any difference.
    Genius:
  • 1,400 Answers
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Posted on Dec 29, 2010
Slowness internet connection
- Re-install the Adapter.
- Update Wi-Fi Drivers.
- Optimize Internet (Use reliable program for it like Reginout.)
- Disable Global Auto-Tuning Feature.
- Uninstall Remote Differential Compression API Support.
- Clear DNS.
- Upgrade your Wi-Fi's Antenna (If needed)
Oct 28, 2013 | Linksys Wireless-G WRT54G Router
Wireless g router network set-up
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
thanks for choosing fixya.com and kindly rate this post.
Jan 03, 2012 | Linksys Wireless-G WRT54G Router
Need to connect Linsys to motorola modem for wi fi usage
  1. simply unplug the router and the modem from their power source
  2. plug the power cable into the modem
  3. wait for the lights to stop coming on, until you see solid power and internet connectivity LED and an intermittently blinking activity light.
  4. now plug the power to the router and allow it to boot all the way up as well.
  5. no your internet should be workin. (the ethernet cable should go from the LAN port on the modem to the Internet port on the rear of the router, and any desktops should be connected beginning with the LAN 1 port and advancing as required)
Jan 08, 2011 | Linksys Wireless-G WRT54G Router
Cannot connect linksys wireless broadband router with at & t dsl modem to connect to internet ?
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Then check
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 05, 2010 | Linksys Wireless-G WRT54G Router
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Linksys router
unplug your DSL modem. Wait 30 seconds and plug it back in.
Make sure the router is connected to a DSL modem. Lately I have seen DSL modems connected to offices that are really routers. If thats the case it may not be talking because the DSL is address the gateway with the same address as the router.
The best way to test this is to see what happens when you disconnect your linksys router and type in http://192.168.0.1
in internet explorer.
If the DSL modem screen appears, it's configured as a router.
Then you will have to take the linksys router and turn it into a switch with a wireless access point. I
Jul 14, 2008 | Linksys Wireless-G WRT54G Router
Help
If it is the Linksys Wireless G WRT54G, then go to this link there is simple instructions on how to setup wireless network.
But, first verify you do have a Wireless card in your laptop. by, hitting Start, Run, then type in CMD in the run box.
When the MSdos(Black window) opens type in IPCONFIG/ALL
this should show all the Network adapters on your machine including your Ethernet and any wireless if avail.
It is usually listed below your LAN/Ethernet settings. It may say something like Intel Pro/100 or 1000 Mobile connection under description. If you dont see a wireless adapter. then go out and buy a Wireless card or a USB wi-fi dongle.
Apr 01, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
313 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
