Question about Siemens HE2415U Electric Kitchen Range
Door will not close all the way Have door off oven, do you have a blow up diagram of door & parts available?
  • 5 more comments
  • zvision749 Dec 29, 2010
    Thanks,
    I can't get the door to close all the way to run the oven properly.
    Looks like the hinges?? Any solutions??
    Siemans electric range model # HE2415U/01 door does not close all the way.
    Troubleshooting ideas??
  • zvision749 Dec 30, 2010
    The door closes, but not all the way. If you push the door
    The door will close, but not all the way. If I push on the door it will connect the fan. When I let go, the door is ajar slightly & fan turns off. Is this a sensor, or hinge issue?
    looks like the door lock assembly. The door closes, but not all the way,
    Still no good. Door will not close against top seal. I tested the convection,
    Thanks Daniel,
    Do you have a parts number on this assembly to be sure I order the right one?
    Also, is there instructions available to replace?
  • Siemens Master
  • 1,711 Answers
As you have
mention it you need new hinges and the problem will be solved since old hinges
does not worth it to be repaired something that is not possible also.
We have
here below a link with a supplier of hinges and other parts for your Siemens oven.
The model is not specified but you can clearly confirm from the photo attached
but you can confirm before order it by a small email direct contact to the
supplier.
http://www.espares.co.uk/parts/cookers-and-hobs/hinges/siemens/p/1598/161
We also a
video showing how to replace the hinges which is all you need to replace the
hinges yourself.
http://www.youtube.com/watch?v=kESnnYR4VhM&playnext=1&list=PL23C4E9C1BA6C775A&index=13
Posted on Dec 30, 2010
  • 4,323 Answers
Hi
This issue is either due to a faulty door latch or a failed door lock mechanism. Turn off the oven and unplug it from power for 10-15 minutes. Try and close the door while the power is turned off, if you are able to close the door then probably there is a shorted wire near the door latch mechanism. However, if you are unable to close the door while oven is turned off then the door latch assembly has engaged the lock and will not unlock, this could be either due to disconnected/loose wirinng to door lock assembly or a faulty door lock assembly. You can use a multimeter to check the continuity of the door latch assembly. Also, the parts for the oven are available on this link---
Siemens HE2415U Electric Kitchen Range Parts
Hope this helps... Please post back if you need more information.
Daniel
  • 2 more comments
  • Daniel Scott
    Daniel Scott Dec 30, 2010
    Hi
    I hope you have tried the procedure mentioned in my earlier post, if you are unable to close the door even when it is turned off and unplugged then its the door lock assembly which has failed. Hope this helps....
    Daniel
  • Daniel Scott
    Its definetly the door lock assembly that is bad. I would suggest you to replace it or get it replaced. Hope this helps...
    Daniel
  • Daniel Scott
    You can check Siemens website....unfortunately I don't have the parts list and the replacement instructions comes with the part
  • Daniel Scott
    Don't have different parts list from the one that I gave you earlier.
  • 3,083 Answers
The only diagrams I could find online were at the following site, in the manual:
http://dl.owneriq.net/9/950820db-087c-4c06-8610-296dae3425cf.pdf
You will probably have to contact Bosch for more detailed diagrams, and here is their site:
http://www.bosch-home.com/us
If you can find a local shop that services Bosch, you may be able to get them to show you the diagrams on their computer.
The title says Siemens, but when I googled it, it came up Siemens on some, and Bosch on others, but I think Bosch may have made it for Siemens, since the parts sites said Bosch, and the only diagram/manual was for the Bosch.
Anyway, hope this helps.
Posted on Dec 29, 2010
I opened the door on my microwave oven and the fuse blown
I gotta do the same thing. Fuses wear out. Luckily they're usually a cheap part. Search for a diagram for your make/model on line or one close to it by the make. There should be 2 or 3 fuses easily accessible once the exterior is off. Search "order online + the fuses' part numbers". Favorite/bookmark that diagram to remove cover and pop out & replace all fuses. Make sure to follow safety guidelines, unplug and don't touch what it tells you not to, like any capacitors. Ground yourself just in case. I'm gonna wear work gloves too.
Jan 15, 2017 | Microwave Ovens
Why my Daewoo microwave oven blows the fuse only when the door gets closed while when it startre with the door opened the bulb is lit and so is the control board until the door is closed then it blows
Hi. The fact that the fuse blows when the door is closed is quite logical. There are safetyswitches preventing the oven to start with an open door. As to the fuse blowing, There are 3 possibilities: the High voltage trafo is defective, the voltage doubler diode or the capacitor are defective. You must be VERY CAREFULL when working on these parts: the voltages are LETHAL.
Aug 25, 2014 | Daewoo Microwave Ovens
GE spacemaker XL microwave oven blowing fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the house fuse or breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Here's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 26, 2012 | GE Profile Spacemaker XL 1800 36 in....
Fuse burn
Yes. But when does the fuse blow?
If it blows immediately after you press "Start" to begin cooking, that would be a shorted high voltage capacitor.
If it happens when you plug the oven in the wall or when you open or close the door, it may be a misaligned door, damaged or misaligned door switch mounts, or a shorted monitor interlock switch.
See my help file on door switches here.
After you remove the grille and control panel assembly, you should be able to access the switches.
Also, there should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, and it is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 20, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge jvm 1750 dm1ww microvawe and suddenly stop working . i changed the 20 amp 250 w fuse inside the display panel and the light and the microvawe started working again.However as soon as i use the...
It's possible the high-voltage capacitor is bad, but I suspect a bad interlock monitor switch. This is one of several switches operated by the door latches, and it's wired to cause the fuse to blow if you try to operate the oven with the door open. The switch may be stuck, which can happen if the oven door gets slammed. It's also possible the switch is good but is out of adjustment.
Replacement switches are available. The Sears parts website has an exploded diagram showing where it's located (item number 30). You should let a professional make the repair, though. Microwave ovens are dangerous items to work on, and if door repairs aren't done correctly there can be excessive microwave leakage.
Mar 20, 2011 | GE Microwave Ovens
The 20 amp power fuse blows every time i start the mircowave oven?
The oven probably has a bad interlock monitor switch, one of several switches in a microwave that are operated by the door latches. The switch is wired so the fuse will blow if you try to run the oven with the door open, and it isn't operating properly when you close the door. As soon as the oven kicks on the power to the magnetron tube, the microwave source, the fuse blows. The switch may have been damaged if the door was slammed, or it's just a mechanical failure. It's not an expensive part, but any microwave repair involving the door should be done by a professional because of safety concerns, so you will have some labor cost to add in. It shouldn't cost as much as a new oven to make this repair, though, so it's probably worth fixing.
Jan 13, 2011 | Hotpoint Microwave Ovens
Won't run because of constant error message saying "DOOR" .. I ear the latch door close fine.
It depends on the model number, but with some Whirlpools the door switch circuit is complicated and has a couple of fuses that can blow, resulting in a door error message.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
I'd also recommend this file on door switches.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Dec 25, 2009 | Whirlpool RMC275PD Microwave Oven
Fuse keeps blowing
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jul 08, 2009 | KitchenAid Microwave Ovens
Microwave model jvm1540dmlww went out when door closed
See:
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Please write back if you need further help.
Jan 24, 2009 | GE JVM1440 Microwave Oven
Home Circuit Breaker Pops When Door Is Opened
It does sound odd for it to blow the breaker. It should blow the fuse, not the breaker. But looking at the exploded view diagram, I don't even see a fuse! Makes me wonder if this is some foreign model. *grin* In any event, you will need to replace all the door switches since they all have been stressed by the same overcurrent. Also be sure that all the switch mount and door latch parts are activating properly when you open and close the door. The switches (generic replacements) are widely available from local appliance parts stores. If you need any other parts, you can see an exploded view and parts list here: http://www.geappliances.com/shop/prts/
Dec 16, 2006 | GE JE2160 Microwave Oven
Siemens HE2415U Electric Kitchen Range Logo
465 people viewed this question
Top Siemens Kitchen Ranges Experts
R.A. Ellis
R.A. Ellis
Bill Boyd
rpar
Are you a Siemens Kitchen Range Expert? Answer questions, earn points and help others
