Question about Linksys Wireless-G Broadband Router
Change Drum Soon - black vertical lines
I have changed my drum twice with a new drum, I have black vertical lines on my pages. HELP, any other ideas? The printer says, "change drum soon." I have twice.
  • 40 Answers
This is probably the wrong place for you to post this as it seems to be a printer problem. However, let's try some ideas here.
1. Try getting some canned air and thoroughly cleaning the printer out. If there is dust in the paper path, it may start leaving marks. You don't specify any other print quality problems, but let's try that.
2. If that doesn't work , then you have to replace the fuser.
Good luck
Posted on Aug 02, 2008
C5350dn
If the whole page is covered by these black lines, then you have to replace the developer unit K..
If there is (for example) one black line that is been repeated in page three times (vertical) then you have to replace the drum unit. The drum units are all the same, so you can test by change two drums between them.
Jul 15, 2014 | Kyocera Office Equipment & Supplies
Vertical black line
change the toner then if u can change the TAPLON
Jan 29, 2014 | Canon LASER SHOT LBP-2900 Printer
Canon 2016, vertical black lines.Print and copy, not always
Dear. first change the drum cleaning blade and clean the waste toner from the drum unit safely and then try to copy if the black lines still appears then change the drum then it must solve the issue , If still the problem comes then check the laser unit if there is anything which produce the black lines on the pages.
Aug 14, 2013 | Canon imageRUNNER 2016 All-In-One Laser...
3 vertical dashed lines down every page
Hi there, I would assume that you are speaking about a laser printer, if this is the case you would have to take the printer in for a service and ask them to clean the primary and secondary corona wires.
A dirt corona wire can cause a vertical lines down the print job cause that part of the OPC drum is not being charged by the charge corona.
Could also be a dirty drum.
Hope this helps. :)
Please let me know.
Jun 29, 2012 | Office Equipment & Supplies
All documents have dark vertical lines printed across them
you can change the drum unit. line will disappear after this replacing.
Apr 17, 2011 | Canon imageRUNNER 3030 Black and White...
My samsung ML 2510 prints a black streak on each plus a watermark from previous page
If your paper setting are set corectly (normal paper) and you are getting a "ghost image" from the previous page, most likley the fuser is the problem. On rare occasions, the drum unit could be the culpret (Black lines) down the sides of the page as you indicated.
You may have 2 problems.
I would change the toner drum 1st. If the black lines go away ,yet the ghost image continues, then change the fuser as well.
Jan 16, 2011 | Samsung ML-2510 Laser Printer
Problem for print by photo copier
sounds like the charge grid is not set properly in the drum unit..did you et up the drum unit properly and run the new dev and drum set up..if youy are getting black the charge is not working correct as the charge of the drum help to keep the toner from adhering to the drum surface when copying .. I would take the drum chrge unit out again and check it is set in the right way when you put it back on also check the contacts arent put out of line.
Aug 05, 2009 | Kyocera Copystar CS-1820 Black and White...
Black lines vertical and horizontal on printed pages in addition to the persistant error message to change the drum I just found out how to re-set that. Does this sound like the fuser is going?
If the black lines are combination of thin and thick lines you really need to replace the drum instead of just resetting it.
Just examine the drum if there are scratches. (",)
Jul 31, 2009 | Brother MFC-7820N Laser Printer
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Linksys Wireless-G Broadband Router Logo
27 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
