Question about Plustek Ipcam P1000 Network Camera
I have an plustek ipcam 1000a I think I've found thecorrect ip address of the camera but when I look on the router for it It's. It listed nor can I access it directly with what I believe is the ip number no prompt for username password nothing the scantool fromplustek does not find cam even with direct connection to the pc
How to configure huawei hg533 router for home network
William the more information you can provide the more accurate can be our brain trust community's answer.
What I have to guess is you added the cameras to an existing network.
What you need to provide is how are the camera's getting their IP addresses ?
How are the PC getting their IP addresses.
My guess
Go into the router settings and look for DCHP server. Look at the leases issued and change the IP addresses that are assigned to the cameras to Static rather than Dynamic. if the cameras are getting IP address from DHCP. server rather than being set up manually..
If you manually set up the IP addresses on the cameras then alter the available ip range on the DHCP server to avoid the IP addresses assigned to the cameras. As an example say the DCHP range was 192.168.1.1 to 192.168.1.254 then alter it to be 192.168.1.21 to 192.168.1.254 and then hence the ip addresses 192.168.1.2 to 192.168.1.20 are used on static ip addresses like printers and cameras devices.
How do you log into the router
go to the internet browser and type in 192.168.1.1 and it should bring up your router The user name is most likely admin and the password will be admin by default. If no one has changed them.
I have looked at the usre manual but it does not spell out how to change the DCHP ip address ranges leases out or the way to change the ip addresses leased out to static for the cameras. I think you will find some sort of setting in thew dhcp menu option of the router.
What
I think is happening is called an ip address conflict. And the above suggestions should stop this from occurring when you reboot the IP address is re assigned and the DCHP server could be issuing ip address leases to your p.cs that are already staticly assigned to your cameras.
Apr 03, 2015 | Computers & Internet
Fs-613a-m136-b2 driver
It doesn't have a driver. It is accessed via the web browser on your computer or an app on your phone. If it is a new camera, the box has the IP address of the camera (typically 192.168.1.100 or something like that). The camera typically comes with a little CD (about 6 cm in diameter) that has windows software to view the camera. You must first connect the camera to your network with the Cat-5 cable and configure the wireless settings. If you have the little CD it also has a tool call "IP Camera Tool" or something like that. It will allow you to directly connect the camera to your computer via the Cat 5 cable as well. Then you can configure it.
May 01, 2014 | Corn Digital wanscam fs-613a-m136 b2...
How do you set up a ipcam to work on the internet
That's a great question, but there are no details here.
What kind of internet connection do you have? Are you behind a Wi-Fi router? What kind of ipcam do you have? Do you know the IP address?
Generally, if you are at home, you need to add a NAT transversal rule to your router to access anything from your home network on the Internet, unless your router and IPCam support UPnP. I can't help you any more without more details.
Apr 05, 2013 | Computers & Internet
Hi, i have a dlink dir-412 mobile router. how can i add an ip camera in this router. i will connect to internet via modem. i get an dynamic ip address after conect to internet. is it possible see the ipcam...
access your router using 192.168.1.1 username/passwd if not altered should be admin/admin u can set your ip (static ip) and i do not see why you can not assign an ip for your cam, my guess is you want to veiw you the camera feedback across the Internet. there various ways of doing this just remember that your cam is connected to your local network not to the Internet. good luck
May 09, 2011 | D-Link 3G Mobile DIR-451 Router
I cannot connect to my security cameras. In my house from the computer in my house.
If your cameras are connected to the router wireless or wired they should have an IP address. This is a unique number assigned by the router. If you have a utility software to access your cameras with a direct connection to your computer you may use that to get the IP address. If there is none either your camera is using the default IP address which you can get from the manual and enter on your browser or get it from the DHCP client list found on the router when you access it at 192.168.1.1 using your browser. At the client list you should see the computers that are currently connected and the camera.
Accessing the computers from the outside of your network or away from home, may be done once you have access it within your home. Otherwise you may need to open up ports on the router.
Apr 03, 2011 | Linksys Wireless-G WRT54G Router
How do I find my webcams ip address Panasonic BL-C30
Hi, the best and easiest way I can think of for this is to go to your wireless router and get the list of ip addresses it is sending out for your wireless connections.
Nov 02, 2009 | Panasonic BL-C30A Network Camera
My problem is I cannot access my router to enter my dvr information to view my cameras on line
Get to a command prompt and type 'ipconfig' - no quotes.
You will see some ip addresses listed. The gateway ip address is the ip address of your router. Put that ip address into the address bar of your web browser and it will take you to the router config page. This is where you can do port forwarding if you want to be able to view the cameras from outside your network. Post a comment if you need any more help.
Or did you just forget your router password........or is the router not responding......let me know :)
Sep 05, 2009 | Computers & Internet
Panasonic network cams
go to the router page in there port forwarding option is ther give there your ipcam ip address then save it and give the port no also properly.
Jul 04, 2008 | 2wire 2700HG-B Router (2700HGB)
IP camera keeps resets itself
Hi
I have a pretty good knowledge of these cameras as I have 5 around my house.....
IP address resets are likely caused by the default address being loaded (192.168.0.99) and the box is not checked to reset the IP on reboot. You have two options.....
Using IP surveillence, open the camera settings. You will be prompted that the recording will stop, just press OK. Once you get to the settings window, you should see your list of cameras and the config screen for the one that is highlighted. Pick the camera you want to change the setting for and go to the tab where you can assign the IP address and gateway. Type in the IP address you want it to use. Uncheck the box that says 'reset IP on reboot'. That box is at the top. Hit apply. Once you do that, cycle the power on the unit leaving it off for at least 10 seconds. When the camera reboots, type in the new IP and you should be able to view it. (sometimes the camera will default on that IP if your router is using 192.168.0.1 and DHCP for computers that has that IP in it's range of assignments of IPs. Telling the camera which one to use and telling it to not reset on reboot will make the new IP stay in the camera.)
Your second option is to use the Installation Wizard or IE, find the camera either by typing in the IP for the camera in IE with the http:// or linking to the device with the installation wizard. If you follow the same procedure of assigning the IP and unchecking the box on reboot like described earlier, this should cure your problem. You do NOT want the IP resetting on reboot unless the camera will not link to your home router (likely causes for this is the IP range the router uses, say 192.168.1.1 like most belkin or linksys routers use, does not cover the IP range of the camera in it's DHCP server.
What I found best was to buy a junk router, set it's DHCP IP range to cover 192.168.0.99, set the camera, save it, kill the cameras power, connect it to the router you plan to use, then start the camera back up. Make sure whatever IP address you use on the camera is one covered by the DHCP server list on the router. ie: camera is set to 192.168.2.2 and the router assigns IPs from 192.168.2.2 through192.168.2.254. If your router only assigns IPS from 192.168.2.100 through 192.168.2.200 and the IP on the camera is 192.168.2.2, you won't be able to connect to it.
Hope this helps
May 19, 2008 | D-Link DCS-3220 Network Camera
Need to change ip address for my camera
How is your webcam connected to your network? Is it connected to your PC or your router?
If it is connected to your router, go into the router settings and see if the router reassigned a new ip address to the camera. If you set the router up for DHCP, it will automatically assign IP addresses to all devices that are connected to it, as long as the individual devices are also set to dynamic IP addressing. Your router is set up for the 1.0 network, so your pc is most likely 1.2, while your router port connecting to your home network is 1.1.
Another thing you can do is make sure your webcam is turned on and go into 'My Network Places', then click on workgroup computers. See if the webcam is listed there.
Apr 11, 2008 | Toshiba IK-WB01A Network Camera
Plustek Ipcam P1000 Network Camera Logo
126 people viewed this question
Top Plustek Computers & Internet Experts
David Payne
David Payne
Are you a Plustek Computer and Internet Expert? Answer questions, earn points and help others
