Question about KitchenAid KESC307 Electric Kitchen Range
Control panel Our range, Kitchenaid KESC307HWW8 has an intermittent control panel display. It will function for awhile, then go completely dark but all functions still work. It seems to decide on its own when the digital display, clock, etc will work. What do you suggest
  • sknapp2001 Nov 25, 2008
    cook top still on, oven no lights and inoperable.
  • kristanb25 Mar 31, 2009
    Control panel display goes out but all controls still function. If you press hard on the panel, the display will light up but will not stay. Appears to be a short.
  • 22 Answers
SOURCE: my clock stopped working on the display
The plug on your range may not be completely inserted into the outlet.
Clear all functions and see if the clock unfreezes
After all this, if the clock digits light up, and you still can't use any clock functions, it may be time for a new control panel.
Posted on Dec 03, 2007
  • 7 Answers
SOURCE: Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Posted on Feb 09, 2008
  • 1073 Answers
SOURCE: KERS907 series electric ranges.
any high tech range or any appliance for that matter that is high tech has a greater risk of repairs, the smart solution is to purchase an extended warranty on the appliance so if it does need to be repaired it will not cost you any additional expense
btw kitchenaid makes a fine range
Posted on Apr 16, 2008
  • 1314 Answers
SOURCE: jenn aire range model jjw9630aaw.
try pressing clock key
Posted on May 24, 2008
  • 1214 Answers
SOURCE: KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Posted on Jan 29, 2009
The display/control panel on my kitchenaid oven model KESC308LSSO is functional but does not light up. What part would I need to fix this? + looking for video of repair
I assume the display is hard to see but otherwise the unit function correctly? I'm going to gear my answer to this issue. If everything on unit functions but just can't see clock and temp. settings, you have a bad display. That's gonna be part #2. I'm not how to upload video but go to youtube and type in Kitchenaid slide in electric control replacement. The top video should give you a good idea on how to change display board out. Good Luck
Sep 18, 2017 | KitchenAid Microwave Ovens
Feature not available
I had the same problem with a new kitchenaid range which they have agreed to replace after 1 month. Oven shut off a couple times while baking and feature not available displayed when trying to turn on oven again. I tried starting clean cycle and waiting a couple minutes for element to heat then cancelled clean cycle. Oven worked fine after this but this shouldnt be a solution, obviously something not wired right.
Dec 09, 2013 | KitchenAid KIRS608BSS Induction Electric...
My display on my 2003 KitchenAid model KESC307HBS8 range was slowly diming until I could not see the display anymore. I ordered a new control panel 9782419CB and new Main Control Board 9782455 from Sears...
You have not said what problems you are having but want to know if you have wired up the unit correctly. Is that correct?
You are only saying that the configuration is wrong but not that the unit does not work....if the unit works...be happy.
For examp you say the the # 9 key turns on the oven light....are you saying it should be another key?
You may have to restate your problem. Make sure the new board is the one that substitute for your old one. If it is not, they will usually provide you with the package insert to explain the changes or differences.
Oct 19, 2013 | KitchenAid KESC307HBS Electric Kitchen...
Kitchenaid oven troubleshooting
it sounds like the heat escaping from the door damaged the electronic control board part number 8186393 and sears has it for 200 dollars.the way the door was left open was directing the heat right at the computer board and you sholud never use the stove for heating the room or things like this happen
Nov 20, 2011 | Kitchen Ranges
KitchenAid KCMS1555RSS - display completely blank and does not function. Is it worth fixing?
i would try and see if the fuse is blown in unit ... normally behind control panel there is a in line 20 amp fuse that may have blown.... if the unit makes noises when you touch the buttons but no display then you have a bad control board assembly
Jan 11, 2011 | KitchenAid KCMS1555RSS Stainless Steel...
Door Locked on and can't remove after water spill
At this point it is very likely the control panel will need to be replaced. If you had disconnected the power and let it dry completely before trying to use it it may have been ok except for the cosmetic issues. You might still try unplugging it for a half hour or shut down the circuit breaker for that amount of time. I am thinking it won't help but it is worth a try. I don't know what to tell you about the cobweb looking damage.
Jan 01, 2009 | KitchenAid KESC307 Electric Kitchen Range
Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Nov 29, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Error codes on kitchen aid range
Hi.
F2 E1 is a keypad connection error.
Here the complete list of Kitchenaid error codes:
Troubleshooting KitchenAid oven, range and...
Feb 11, 2008 | Kitchen Ranges
KitchenAid KESC307 Electric Kitchen Range Logo
65 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
