Question about HP Photosmart M417 Digital Camera
My memory card is locked how do I unlock it - HP Photosmart M417 Digital Camera
  • HP Master
  • 4,738 Answers
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Dec 29, 2010
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My memory card is locked am not given lock number how to remove lock 2gb micro
Look closely at the memory card itself. There should be a tiny picture of a lock indicator on the card and a little tab to click or move to the lock position. There should also be a picture of an unlocked lock to signify which direction you need to move that little tab in order to unlock the memory card. Try sliding it to the unlock position to solve your issue.
Sep 12, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card lock how can unlock micro sd card
Locked Memory card.
Note:- Locking of memory card is a RANDOM process.(means it gets locked on its(memory card) "OWN')
1.Whenever a card gets locked,its mainly due to the following reasons.
(I)When you insert it into a uncompatible mode.
(II) when some unsupporte files are placed.
(III)When its for specific mobile.
100% working solution for LOCKED MEMORY CARD is :-
1.Use Unlocker(its like a pendrive device with 9V battery ),and its IC is programmed in such a way that it tests every possile code.
2.The one that sets mades the memory card Unlock.
3.BUT you cant know what the CODE was.
4. Data can NEVER be retraced.
Noye :-Buy an Unlocker available @ Rs.200.But you may not get the same problem often so take it to the retailer it will costaround Rs.20 for unlocking .
Aug 29, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Dec 30, 2010 | SanDisk 4GB microSD High Capacity Memory...
My memory card suddenly says locked, why and how do I unlock it
Thanks for using Fixya.
(i) Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.9632f20.gif
(ii) Toggle the lock switch.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 06, 2010 | SanDisk 1GB microSD Memory Card
Unlock 1 GB micro sd memory card of Kingston Made
check the adapter maybe its switched to locked mode sanjan
Aug 17, 2008 | Nokia 5300 Grey Cellular Phone
Unlock memory card
There is a little 'lock' switch on the side on the card with a lock symbol. Slide the switch to the unlocked position to unlock your card!
Aug 06, 2008 | Cell Phones
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
HP Photosmart M417 Digital Camera Logo
61 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
