Question about KitchenAid Dishwashers
I have a kitchenaid superba dishwasher. It stopped working. The lights for the settings come on but when I hit start, nothign happens. It's about 7 yrs old.
  • 5,603 Answers
Try turning off the breaker to it to reset the controller. Beyond that, check the water intake valve. Usually the first thing to happen is filling with water and it will wait for fill before doing anything... so if valve is stuck, it will appear nothing is happening. Valves get crud in them and fail to open.
Posted on Dec 29, 2010
When I press buttons to start dishwasher nothing happens
could be the door switch has failed and not seeing dor is closed properly torun .
Jul 03, 2016 | KitchenAid Superba Series 24" Built-In...
MY KITCHENAID DISHWASHER FAILS TO POWER OFF
Programmer fault.......time for repair man or replace machine. I assume out of warranty.
Jul 21, 2014 | KitchenAid 24 in. Built-In Superba Series...
How do I use the thermometer in my Kitchenaid Superba?
I found the answer by checking the Kitchenaid website to find the manual. My model is KEMS308sss04, this is found on the right door frame. Website is: http://shop.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10162223.pdf
You can preheat oven, but then turn off to set thermometer. Put probe in food. Put food in oven and plug in probe. The digital light asks for the temperature you want, type it in. Then the cooking method. I used convection bake at 325. Hit START. (The first time I didn't stop the oven and it didn't work. After stopping everything and starting with the probe before turning on the oven, it worked perfectly. Good Luck.
Dec 05, 2009 | KitchenAid Architect Series KEBC107KSS...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140, THE DISHWASHER IS NOT RESPONDING TO ANY COMMANDS, THE RINSE LIGHT IS BLINKING AND THAT...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140. The unit is not drying the dishes?
Oct 02, 2009 | KitchenAid Dishwashers
We have a kitchenaid dishwasher model#kud102irbl serial#FU1705420 Clean light keeps flashing on 7 times, waits a few seconds and flashes 7 times again. How can we repair this?? Dishwasher will not leave...
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Feb 26, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Child lock shut off
Hold the button with the lock until the light turns off. Consult the manual.
Can you provide a model number?
Feb 18, 2009 | Dishwashers
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
My KitchenAid Superba won't run, no lights, nothing
turn off the power at the breaker and let it stay off for at least one hour
Dec 17, 2008 | Dishwashers
Dishwashers Logo
580 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
