Question about Sharp AL-1457 Black and White Copier
Sharp Mx-M350U shows L04-02 service code - Sharp AL-1457 Black and White Copier
    New Friend:
  • 111 Answers
L4 -02 cause Drum motor trouble
Improper connection of harness between the
PCU PWB and the drum motor.
Control circuit trouble
Posted on Dec 29, 2010
Tip
F2-02 error code on Sharp AR-M350/450 and 355/455 Copiers
The F2-02 code will often be the result of a defective or after market toner cartridge. Try replacing the cartridge and power cycling the copier before placing an expensive service call.
on May 17, 2010 | Sharp AR-M350U Copier
Sharp MX-M550U cartridge error code: F2-05
f2-05 means that the cartridge is either not in correctly or is a "noncompatible cartridge" aka a knockoff.try a different cartridge and then reset the machine by pressing #,*,C,*, 1,4,start,1,start
Dec 16, 2010 | Sharp AR-M350U Copier
Sharp AR-M350U Copier/Printer Error Code F2-00
clean developer unit connector .pull out , clean , then insert .
May 25, 2010 | Sharp AR-M350U Copier
Scanner on Sharp AR-M350u is showing NG800000 and is not sending scanned items.
This mistake NG800000 offset scanning device.
1 Try reinstall a driver on local on cord USB
2 Remove glass of the scanner and check displacement scanning device, it must softly move. Smazhte nodes mask, продуйте the sensors, check join a wire. Do Not use the long cord USB gets lost the signal, appear the hindrances.
Write, help. Good luck
Jun 22, 2009 | Sharp AR-M350U Copier
Error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
May 07, 2009 | Sharp AR-M350U Copier
Error code h5-01
Hello sir; the paper exit sensor get stock, just put back in the track let it moved free.
Apr 14, 2009 | Sharp AR-M350U Copier
Error code l6-10 on a sharp ar-m350u
I can't find a table of Sharp error codes.
Do all documents have this problem? Then I would contact an authorized Sharp repair center.
If there's only one document that does this, it could be a corrupt or very large file that the printer can't handle. Try sending a single page of the document instead of the whole thing.
Isn't the AR-M350U a "Corporate" multifunction device? Then your vendor should be providing warranty support or service contract support for it. Check with the vendor before getting involved with another company.
Jul 18, 2008 | Sharp Computers & Internet
Sharp AL-1457 Black and White Copier Logo
340 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
