Question about Kenmore 63942 Dryer
Heating Element Where is the heating element for a Roper heavy duty/extra large/6cycle/3 temp dryer the Model# is YREX6634R20 the Serial # is MS4004307, and how do I go about changing it?
  • dkubison Jul 09, 2008
    This was terrible info you did not even show me where the heating element is located on my dryer.
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Are you certain that you need an element? There are numerous things that keep a dryer from heating.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
From this link you can navigate through the site to find the information that is pertinent to the model of your dryer, just enter your model number in the search box.
Below are some solutions to your dryer problem:
Temperature Switch, make sure a positive heat selection has been made. Then:
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Whirlpool heavy duty 5cycle 3 temp dryer won't turn on suddenly sound whatsoever..changed heating element and still not on
Check your thermal limiter . It should look like a white bar about a inch long . You can find it on the blower housing
Feb 17, 2013 | Whirlpool Dryers
I have model REX3514PQ0 that I purchased from Lowe's in 2005. It is a Heavy Duty, Extra Large Capacity, 3 Cycle dryer. The dryer will turn on and will blow but only cold air. A friend suggested I check...
There are three switches :: high heat thermostat, low heat thermostat, and thermal limit switch.
Could the the thermal limit switch is opened because the dryer overheated -- these cannot be reset -- need replacing.
Could also be a faulty heating element. To test these components you'll need an ohmmeter (multi-meter) and will need to remove the back of the dryer.
More info, let me know.
Feb 20, 2011 | Roper Dryers
My roper dryer REX6634pq0 does not heat!!
there is a thermal overload switch that activates the heating element. This switch will be located in the area of the element itself. It is designed to shut off the element in the event the element itself reaches a temp beyond it's designed temp. It is a safety device. If the switch is out it will not allow the heating element to activate. This switch looks like a silver button and has several wires going to it is about the size of a dime. Replace this switch and you should be good to go
Mar 17, 2010 | Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly.
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Warm heat..clothes not drying
john there is only one heating element.ither it works or it dosent.when acustomer complains of low heat or long dry times 99out of100 its the venting or the dryer is blocked with lint.remove the dryer from the venting and try a load.if better clean house .........if not better you should have a great air flow leaving the dryer so if not drying well with venting off.take dryer apart a clean all araes that air is moving,where lint can block that flow.god bless .tom
Jan 01, 2009 | Roper REX3614KW Electric Dryer
Warm air but clothes not drying
Make sure u have seleced the high heat setting..The fact that it is heating more or less indicates that the element is o/k.
Check and clean any filter(s) that u can see,it is more likely to be a thermostat problem than anything else. and there are at least 2 of them, also check line voltage is correct.
Plz rate this solution.
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
95 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
