Question about HP Computers & Internet
Pavilion does not boot. Lights on strip below screen flash on and off. HDD drive does not come on
    Guru:
  • 679 Answers
-If you are not able to boot in Windows but still able to get error codes like from windows you can just reinstall the Operating system using your recovery discs
-If there's no display at all even the HP logo upon startup its a motherboard issue
- if you are able to get the hp logo in startup but not able to go to windows its a RAM issue
Posted on Dec 29, 2010
I have hp pavilion dv2000, when I plug in dc cord it switches on without pressing power switch. Than I'm able to switch it off and on. All lights on panel and motherboard switch on also. CPU fan switches...
dv2000 zero support now at hp,
2006? year.
so does the VGA port on the rear of PC work. to a desktop monitor
yes, then the mobo is ok. but not screen.
easy no?
i can make the mobo run on a table. vga connected.
with Fn+F4 toggled on and external USB keyboard, I can activate the external screen.
steps. are as follows. in proper order
1: remove that shorted huge battery, there. get it out of there.
2: make sure the power pack reads (VM) 19vdc at the jack.
3: new coin cell if voltage on its pins below 2.9v... yah?
4: get BIOS screens working FIRST. disconnect HDD and DVD drive. now.
5: go to 1 ram stick bank 0 (try 2nd one by self)
6: does the flashlight trick work on that CCFL screen,?
7: remove all modules from MOBO cept CPU and 1 stick RAM?
we call that the strip down tests.\
8: beep codes, or Caps lock key flash codes? what?
BIOS screens have to work, or mobo is dead.
has anyone been playing with BIOS doing crazy things like flashing it.>? yes, oops now you bricked it. then what (ask)
if pc is 2008 that is the solderball from hell year.
see that and the CCFL test here.
http://www.pcdied.com/monitors.html#flashlighttest
Aug 16, 2017 | HP 417035-001 - HP Pavilion dv2000 Series...
My HP Pavilion dv5 1125nr laptop won't boot up. The screen never lights up when the power is turned on, the little hard drive light next to the power light doesn't flash at all (normally it flashes...
check by removing the battery then put it back again power it on, or without battery power it on directly then check, if still the same problem, the fault is in the motherboard of the laptop, better take it the service center or consult some technician in your area
Aug 02, 2011 | HP Pavilion dv5-1125nr Notebook
Computer will not start up on power up. Computer does a system check with all L.E.D. lights, cooling fan starts, empty cd drive bay does a system check. The computer hard drive will not start and the...
notebooks, battery out first, just take it out the leds mean zero.
there is no LED that can tell you a battery is ok,
did you?
if that fails.
next is what, BIOS
get the BIOS screens up. (my guess its DEAD) not even text or HP logo.
if not the pull hdd,dvd and all ram but 1 stick.
and all usb jacks empty , unload it.
fails now. then the Power pack is bad
you do know packs can be, good, bad or weak right
19vdc is good, 10 not.
see?
the GOAL on ALL PC's get BIOS UP.
take no hdd , no dvd to do that. ever
once it works we can move to booting any OS>
we can boot to 5 things on my laptop, even SD,mem.
try to think this way
if the Power pack is 65w+ and 19v
then remove all possible shorted devices from the PC.
strip it down. if it runs now, (means BIOS wakes up an screen)
test 2 on all LT
is the rear VGA jack will run a external screen if the internal is suspected.
black screens only can be CCFL dead.
if it has that.
i cant hear you hdd spin/
nor see the eject work work on the dvd
if the PC self shuts off, that means the power supply has issues
the Power pack bad , the MOBO regulators are in overload
and shut it down (called shorts on devices)
this is normal action on any regulator..... normal for shorts./
Jul 20, 2017 | HP Pavilion dv6000z Notebook
My hp dv9000 will not boot. when power is turned on all leds light up screen stays black. hard drive and fan can not be heard. restarts after 10 seconds with no error message or flashing lights.
Remove the hdd cover from the bottom and make sure it is completely seated and connected. If the hdd is properly installed and it still will not boot, try entering the CMOS Setup. If you can enter setup you most likely have a bad hdd. If you can't you need to take or send the pc to a repair shop.
Oct 06, 2009 | HP Pavilion dv9000z Notebook
Hp Pavillion Tx1320us..wont boot up
You're probably one of thousands of victims of defective nvidia chipsets in these systems. Call HP and complain.
Jun 08, 2009 | HP Pavilion TX1320US Tablet PC
My mom has a Pavilion 513n desktop. At boot up it
you're receiving a "No POST" issue. It could be any base component in your system. Strip it down to the bare basics. Power supply, motherboard, RAM, CPU, fans. HDD. Then start removing those components until you receive an error message. You'll be able to figure out which part needs replacing from that.
Jun 05, 2009 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Hp pavilion dv2000 notebook will not boot up
Go to this Hp website for you could have a grapgics chip fault. One way to test is to plug a VGA monitor into the VGA outlet port on the upper left side of you laptop and start it up. If you get a clear display you have a screen problem - next step remove the external monitor and again boot up but in a darkened room to see if your backlight is off - if you can just see the HP logo in the back ground then your backlight has failed or more rightly - the backlight micro switch under your R/H hinge has failed. A cheap fix. If there is no display external or TFT your Nvidia graphics chip has failed. m/board replacement required BUT you may qualify for free m/board replacement under Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario v3000/v6000 Series Notebook PCs - HP Limited Warranty Service Enhancement go to this site below to see if you qualify
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Mar 07, 2009 | HP Pavilion dv2000t Notebook
New HDD inserted into Pavilion ZD7000 - will not boot from XP CD
Try your old HDD in it and see if that works. If it does work then nothing is damaged except your DVD drive/Controller. Try putting the new HDD in another computer, installing windows then putting it back in the HP. If all else fails then flash the bios with an updated image and see if that rectifies the problem.
Feb 01, 2009 | HP Pavilion zd7000 Notebook
HP Pavilion DV1000 doesnt start up.
The unit is not finding any boot drives and is trying to boot from a network.
Make sure no disks are in a floppy or cd drive, and if so, remove and try to reboot.
You may have a dead or troubled hard drive.
Nov 19, 2008 | HP Pavilion dv1000 Notebook
Status lights flash, but no bodys home!
remove the hard drive and try to see if that boots up if does bad hard drive if does not do anything change the internal batery and try again i think that will fix the problem
Dec 30, 2007 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
