Question about Home
Triton T80si electric shower. How do I clean the filter.
3 Suggested Answers
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Unpredictable water temperatures!
i am not an expert but i have a hunch it could be the tempeture gauge but i have no solution sory
Jun 19, 2012 | Home
Triton Ivory 2, 8.5 kw electric shower flow has been getting porgressively weaker. Mains pressure if fine. Shower head is clean.
there could be a blockage on cold water connection which may have a filter which needs cleaning or the heating tank inside the shower could be blocked with limescale try cleaning the filter you cvould also check the shower hose for blockages or kinks
Dec 09, 2010 | Home
Triton t80si shower is very hot even on a low setting then fluctuates between hot & cold, pressure switch is not activating but pressure seems low any advise will be gratefully received.
If the water temp is fluctuating from very hot and cool the problem could lie with a blockage in the inlet to the shower, scale inside the heater can, shower hose needs replacing or the shower head needs to be cleaned The problem is a "slowing" of the water across the heating elements which causes the water to pick up too much heat
Jul 09, 2010 | Home
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
Dec 09, 2008 | Home
Triton electric shower runs cold
Just a thought!
Dec 01, 2008 | Home
Home Logo
383 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
