Dell Dimension E510 Wont Boot up. PSU is working 100% CPU is working 100% Ram is working 100% Disconnected all other hardware. No Power On Light. Light on Motherboard is green. Once you plug in the PSU Power Cord it starts the PSU Fan and the CPU Fan and acts like its running but theres no Power Light on front of case or nothing displaying on Monitor.
    President:
  • 2,992 Answers
How did you determine the power supply is fully functional? Just because the system comes on when you press the power switch, or jumper the "turn-on" pin in the plug to ground, it doesn't mean the outputs are correct. The only sure test of whether the supply is causing problems is to substitute a known good supply as a test.
That said, if the power supply really is good, all that's left is the system board. I have replaced many motherboards that fire up the power supply when you press the power button, but that's all. Take a close look at the filter capacitors on the board, and you might see some that have bulgy or split tops. They are a common source of problems when they go bad. Sometimes you can repair a board by changing out the bad parts, but it's usually more cost-effective just to replace the board. You can often find the original board on eBay these days, or you can purchase a new board that uses the same processor and memory and fits the case.
Posted on Dec 29, 2010
E510 no video
This issue can be caused by a number of factors, these are the main ones:
1: The power supply has failed (and if it is a cheap PSU, most likely killed the motherboard too, but, knowing what dell are like, it should be a good PSU in there, so hopefully, no worries there :))
2: RAM the no video can be caused by a defective module, remove or replace any RAM and try again
3: Graphics hardware you may have installed: If the GPU is not correctly seated in its slot, or the cables powering it are loose or the video cable is loose or broke, then remove and/or replace the defecrive part
4: Motherboard: This one is common, sometimes it is easily remedied by replacing some bad capacitors, but if the board is too far gone, then it needs replacing.
5: CPU: This one is very rare, I've ony had one system do this to me, but it is caused by a build up of dust in the heatsink and fan, this causes overheating, and eventually over time, the CPU's performance begins to downfrade until you hear a little pop and that's the end of that, the older dual core CPUs are cheap to get, unlike the Core I7 chip, you can get a new CPU from almost anywhere now, so try this as a last resort as it is the least likely to fail!
and simply, if it does not turn on, check the fuses first, this is the cheapest option of the bunch, and is the easiest as you don't need to pull your PC to pieces to get at the parts!
Feb 11, 2013 | Dell Dimension E510 Dual Core 2.8 Ghz...
Can't turn my computer on and i have a yellow blinking light on my dell dimension E510
Do you use a surge protector? If you do, try turning off the power supply to the surge protector and switch on again.
There are a number of causes for this problem, the most likely being a PSU problem or a motherboard fault/failure. To check the power from the PSU to the motherboard, you will need a multimeter to make sure enough power is going to the motherboard. Also check the motherboard closely to see if there is any signs of corrosion or blackened areas, which could be caused by overheating components. Check for leaky or burnt capacitors.
Apr 13, 2012 | Dell Dimension E510 PC Desktop
Dell Dimension E510 Wont Boot up. PSU is working 100% CPU is working 100% Ram is working 100% Disconnected all other hardware. No Power On Light. Light on Motherboard is green. Once you plug in the PSU...
Hi
With that scenario i would recommend you check the front panel assembly where the power button is located and also have you tried to reset the CMOS from the motherboard.
Dec 29, 2010 | Dell Dimension E510 PC Desktop
Blinking amber light and wont boot up.
if the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Sep 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Dimension E510 will not turn on
It could be.
When you switch on after it has been turned off for a while look at the fan on the PSU as you switch on.
If it spins or tries to spin for a very short time then I would indeed suspect the psu.
If however the psu fan does spin for longer and you can hear any beeps then that would be an indication of a different problem.
Should that be the case then check here.
http://www.computerhope.com/beep.htm
or here
http://www.pchell.com/hardware/beepcodes.shtml
  • If you found this information useful please click
Aug 13, 2009 | Dell Dimension E510 PC Desktop
Steady amber Power light
You are looking at a new mother board. I would take it to a certified technician shop, so they can run a stress test on the motherboard for final benidiction.
Aug 13, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Want power up
Any lights at all? try swapping a printer power cord or another power cable on it. Does the fan on power supply move? CPU fan moving?
Need more info.
Jul 08, 2009 | Dell Dimension E510 PC Desktop
Flashing Orange light, computer wont boot
Below is the link to the NoPower, No POST, No Video troubleshooting.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=&treeid=011360B8243248349C306481A954B356&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=en&toggle=&dl=falseFollow all the steps without skipping any and if there is no hardware failure,this should definitely resolve your issue.
Hope this helps. Please rateyour feedback!
Thanks,
VJ
Mar 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Bios problem on dell dimension e510
At first u need to remove the bios. wait for 5 minutes. then add the battery. start it
Jan 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Power problem on Dell Dimension 5100
plz check the ram and powersupply unit and try to reset the bios
Sep 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
