Question about Kenmore 44102 Front Load Washer
Water keepscoming in to washer - Kenmore 44102 Front Load Washer
    Sergeant:
  • 223 Answers
The solenoid valve is stuck open. It has either failed or has something it it holding it open.
Try making it open and close a few times along with a little gently tapping where the hose hooks on the back of the machine (tap on the hose connector itself, you want to jar the piece the water is going into). You can make it open by turning the selector to "fill" and close it by turning the selector to "off".
While you're behind the machine take the hoses off and check the little screens in the water inlets on the machine, it you're working on it already you might as well clean the screens.
lp
Posted on Dec 29, 2010
How do i fix an LG 5.0 fuzzy logic washer that keepscoming up with a DE error?
The DE error indicates a Door Error condition....check out the door for any distortion or misalignment with the door latch.
Check the door latch assembly for continuity and if faulty replace the switch.
Mar 24, 2015 | LG Washing Machines
Nut on bottom of wiper motor keepscoming off
i would suggest getting a lock nut or a spring washer for this. the vibration causes the nut to loosten up. to be safe use a drop of lock tite on it
Feb 26, 2015 | 2004 Saturn ION
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Jul 28, 2013 | Haier HLP23E Top Load Washer
Hot water does not fill in the washer. The spicket has hot water.
There is an obstruction after the shut off to the hot water hose that feeds the washer. Shut off the hot water, disconnect the hot water hose from the washer, and hold the end in the washer tub. Open the hot water shut off. If now water comes out the problem is in the hose. Replace or clear obstruction. Make sure washer at hose end is in place before reconnecting to washer.
If how water flows, inspect the input hose connection to the washer. Some have a screen filter that my be clogged with sediment or other debris. Clean and try again.
If still no hot water, there is likely a problem with the hot water solenoid valve inside the washer itself. You'll have to remove and probably replace the valve or coil (or assembly).
Mar 09, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Security Sheild keepscomming on how do I get it off??
try running microsoft security essentials - it is a free program from the microsoft website!!! if that doesnt work you will need to download and run a malware/spyware removal program (good ones can be found at cnet.com
Dec 15, 2010 | Computers & Internet
Welding aluminum and wire keepscoming out of rollers
your hobart machine it's not suit up for standard aluminum welding, the lenght of the gun it's too long therefore the wire will nest at the drive rolls. You need to buy a spool gun. Or change gun liner for a teflon one (instead of metal one), then change the drive roll for knurled ones and finally oversize your tip if you can. No need to do ALL this if you buy a spool gun.
Oct 24, 2010 | Hobart Handler 140 Mig Welder
I cant print it keepscoming on the dash e 1 4 blinking
check the ink catridge ,E14 - shows that The Ink cartridges destination are wrong
Aug 17, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 44102 Front Load Washer Logo
18 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
