Software disc is smaller than usual size...is it safe to insert into my imac drive to down load to my computer ? will it eject ? Thanks
    Sergeant:
  • 320 Answers
Hi Don,
  • Software install disks sometime are sent on mini disks, and should be fine to load in you disk player. Just make sure that it is centered. On most cd players there is a smaller grove in the middle just for minis. Many people don't even notice because minis are not very common in the States.
If this helps resolve your issue, would you please rate the solution. If this does not help please leave a comment giving me more information on the problem and I will try to help you further.
Posted on Dec 29, 2010
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
May 21, 2010 | Apple iMac G5 Desktop
Powers on , wont boot and cant insert a disc to get it to boot.
To eject an optical disc at startup, hold down the mouse key on a wired mouse immediately after turning the iMac on with the power button. Keep it held down until the disc ejects, which should occur within two minutes. If you hear the disc trying to eject but failing, it is physically jammed in the drive and will have to be removed by a professional technician.
May 17, 2010 | Apple Computers & Internet
Can't reboot iMac and disc is stuck in the slot loading drive
Shut down the mac by holding in the power button for about 10 seconds.
Is the CD a system CD or something else?
If it's a system CD restart the mac and hold down the letter C on the keyboard. after about 30 seconds the mac should boot up into installation mode. If it does, click on the language then then at the next page go up to the menu bar and locate Utilities and disk utility. Run the disk repair then try and restart. (The flashing ? means that the computer cannot find a start-up drive with a valid system on it. The repair routine can sometimes fix that - it doesn't always though.)
If it's not a system CD and you obviously need to get it out before you can do anything else - restart the mac but this time instead of holding down the C key, hold down the click on the mouse. It takes 10 to 15 seconds (sometimes longer) but it will force the computer to eject t the CD.
Feb 14, 2010 | Apple iMac Z0CY Desktop
The container that hold my dvd disk wont come out when I press the open button on my apple computer?
It may be stuck so what you can try are one of these options:
Option# 1
* Shutdown your iMac G4
* Before you turn on your iMac, hold down your mouse button(s).
* Turn your iMac on still holding the mouse button(s) down.
* You will need to keep holding, until your disc ejects as your iMac starts up. That should do it.
Option# 2
If it does not, try using the Terminal utility to attempt to eject the disc.
* Click anywhere on the blank space of your desktop
and then you should see Finder appear near the Apple menu icon located in the upper left corner of your screen.
* Now from the Finder menu, select Go > Utilities.
* Within the Utilities folder. locate the Terminal application and launch it.
* When the screen prompt appears, type:
drutil tray eject
Option# 3
If that does not work, you can also try ejecting the cd using Open Firmware:
* Restart your Mac and hold these keys:
* Hold Command, Option, O and F keys while booting up.
* Now type: eject cd
To exit the open firmware screen type: mac-boot
One of these 3 methods should eject your disc.
If not, you may have a genuinely stuck CD in your drive and may need to take your iMac in to your local Apple retail store Genius bar or local Apple-authorized service center to have it safely and correctly removed.
Honestly, however, I have this same type of iMacG4- you will probably have the cd out by Option # 2 :)
Regards,
-Mactechtrainer
Jan 04, 2010 | Apple iMac G4 Desktop
Blueberry iMac with slot-loading CD rom drive will
It would be very difficult to open up the imac to retrieve the disc as the CD drive is totally enclosed and would probably result in it not be functional after removing the disk. Have a look at the following article on the apple website
http://support.apple.com/kb/HT3007?viewlocale=en_US as it does indicate that the slot loading imac does have a hole for paperclip ejection. You could also try opening up disk utility and and clicking on the icon of your disk under the left hand column then go up to eject button and click eject. Hope this helps.
Nov 12, 2009 | Apple iMac G3, G4 USB Keyboard 9224078
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Dvd wont eject when you try to open it. or dvd wont play
i think the cd or dcd disc inside stuck-up you have to insert the tiny hole located at the dvd rom and insert a needle or something that is similiar or smaller of the hole size of that locted in your dvd rom.usually its new the LED blinking when opening or inserting the disc. and now you can now eject your disc manually regarding your question about it won't play a dvd try first to clean your DVD disc with a micro fiber cloth, avoid you'll scratch it, if still the same i think you're dvd room is defective.
Oct 08, 2009 | Bose (321GS) System
Disk won't eject on my iMac
Ok, I assume you have hit the eject button on the keyboard. Try dragging the CD icon on the desktop to the trash can. If that doesn't work, Shut down the computer and start up while holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Another option is to open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder. Another option is to Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Lastly if your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button. One of these should work.
Sep 03, 2009 | Apple Mac mini G4 Desktop
Dirty DVD Drive?
You can clean your DVD Drive by inserting the Disk Cleaner its either dry or liquid cleaner. If you don't have a disk cleaner just purchase it in the store near in your neighborhood. In that way you can clean the DVD Drive Laser eye and make it possible to read another disk next time you used. Usually it takes 15 minutes the standard cleaning time if you are cleaning the DVD Drive to ensure that it is properly cleaned. Also if it doesn't work then probably you can find a technician and let it check to the technician. I hoe that the laser eye of your DVD Drive is not damage due to some disk you inserted earlier.
Hope this recommendation helps solved your problem.
If you need more assistance just reply to this post. thanks
Jun 26, 2009 | Apple 24" iMac Desktop
Playing PS2 on apple iMac
if the iMac is one of the computers with the slot-load drive (you don't load the disc into a tray before it goes into the computer), then placing a disc smaller than a regular CD/DVD will damage the CD drive and will be very hard to remove.
you could buy an external CD/DVD drive and then use smaller discs with the iMac.
Jun 10, 2008 | Apple iMac G5 Desktop
Computers & Internet Logo
David Payne
David Payne
