Question about Radio Communications
Galaxy 44v will not transmit or receive - Radio Communications
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
Is this a new radio? If it is then get a return request from Galaxy and send it back. If not new then is it for a friend or from a friend to be repaired. If not either then why did you touch the inside without knowing what to do. Go online to www.cbtricks.com and look up Galaxy,get the service manual and repair it the best you can but when it still doesn't work then take it to a tech and have him do it right.
Posted on Jan 12, 2015
5 Suggested Answers
  • 50 Answers
SOURCE: Hello! I have a Galaxy
I don't understand the keys with no carrier. Either it keys or it doesn't key. The most obvious question is does it have power? Does a transmit light come on when you push-to-talk?
If you have power it sounds like a transmission line problem or an antenna problem. Look on the back of the radio and see if the co-axial plug is still secure.
Posted on May 28, 2009
Mister 44
  • 35 Answers
SOURCE: galaxy 44v no transmit or receive
Try replacing TR41 (2SA473).
Also check TR40 (2SC945), D78 (7.5 volt Zener Diode), and D79 (KB 262).
n1pta@msn.com
Posted on Apr 12, 2010
  • 100 Answers
SOURCE: My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
Posted on May 01, 2010
  • 773 Answers
SOURCE: i have a galaxy 44v it transmits on fm but
Replace the AM final, then make sure your antenna is tuned to lowest SWR to prevent the final from burning out again.
Posted on Nov 25, 2010
Transmitting
you will have to get a tvi filter and use it on your cb or just don't listen to the am while talking on the cb
May 23, 2013 | Galaxy Radios DX-44V 40-Channels Base CB...
My galaxy Dx 44v does not rec. or transmit when cold. I put my heater on it and in about ten minutes starts to sound like I'm off channel. Another ten minutes and I receive and transmit just fine.????
you should take it to a tech to check it out . there is a symptom called thermal intermittent.when the radio gets hot it stops transmitting.the oposite is also true and to find the problem a soldering iron would work but if you are not careful you could zap the radio..You would need a commercial thermal spot tester to accomplish thischeck the obvious first until you find the actual problem.
Dec 29, 2011 | Radio Communications
Dx 44v diplay out no transmit anybody ?
Sounds like it blowed...check fuse, power wires.. if it got hooked up backwards it will blow a diode in back of radio. Take off cover change all black diodes with a solder gun.
Mar 28, 2011 | Galaxy Radios DX-44V 40-Channels Base CB...
I have a galaxy 44v it transmits on fm but receives on am what can i do to fix this problem
Nov 24, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
Quiet Galaxy DX 44V
Sounds like you have lost a final or a driver transistor if so a shop or reputable repairman is your best answer. You should also have him check your cables and SWR on your antenna system as well as check for loose grounds. Sounds like you had a high SWR and blew out a final transistor. But it could be as simple as a loose component or cold solder joint in the radio. Get professional help.
Jul 28, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
Galaxy dx440v no receive??
When mixing crystal for different bands, your RX will be affected by the swap as well. I get this every once in a great while, if you want to ship it in I can do the alignments for you here at the shop. dodgem250.com
Feb 03, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
Hello! I have a Galaxy 44v radio,it keys with no carrier and it hsa no receive and no audio.Thank You
May 27, 2009 | Radio Communications
Radio Communications Logo
89 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
