Question about Homelite Mighty Lite Lawn Trimmer
I have a homelite 26ss. no spark. multi tester indicates there is no current running through the kill switch when in the "on" position. when in the off position, there is current running though the switch. is this correct. I thought it should be the opposite. Help.
    Sergeant:
  • 223 Answers
The switch is correct. It grounds the ignition when it's in the 'off' position.
lp
Posted on Dec 29, 2010
How do I start a Homelite little red XL
usually by pulling on the rope .after priming and choking with the kill switch turned to the run position .sometimes it helps to remove sparkplug and give it some fuel there and quickly put plug back in tight .
Nov 30, 2015 | Homelite Garden
Where can i get Homelite HGN2400D manual
what engine do you have ??? remove the kill wire and see if it has spark
Sep 07, 2014 | Cars & Trucks
How do i adjust my idle crew
The idle screw isn't as important as the low/high setting on the carb. Start with one turn out on both low and high side settings.
Aug 30, 2014 | Homelite Garden
No spark - coil ???
Could very well be the magnito (coil). You may also want to check the kill switch. If the switch failed in the off position... = no spark. Plug failure could also be the cause, although not likley. Good luck!
Sep 25, 2011 | Homelite Factory Reconditioned 26cc...
How can I trouble shoot the kill switch on a echo weed eater. The spark plug is good as it has ben tested on another machine. There is no spark and seems the kill switch should be the next obvious thing...
Check the kill switch terminals with a continuity tester (small multi-meter will work). If the switch is Ok and there is no spark, take off the engine cover and check the "air-gap" between the magnets in the flywheel and the ignition module legs.The closer the better, but you want about a ,008-.010"gap there...about the width of a standard sized business card. Metal feeler gauges "stick" of course to the magnet area in the flywheel and throw off clearance sensitivity. Try it with a business card. If not in range, then loosen the coil screws, double the card over, and let the magnets pull the coil legs into the card...retighten screws and check for spark.
Mar 15, 2011 | Echo Garden
I get no spark from the spark plug, replaced it with new one still no spark why, echo hedge cutters
please check kill switch and wire for making ground when they shouldnt make contact in the run position
bassically pull the wire off at the stop switch or at the ignition unit if it fires
faulty stop switch or grounding wir indicated
if not faulty ignition unit indicated
replace ignition unit and assemble
cheers paul
Aug 11, 2010 | Garden
Chain Saw Motor will not start.
Yes it is very important i would recommend also putting in a new spark plug. Thanks for asking and I hope it helps
Jul 20, 2010 | Homelite ZR10926 16 Chain Saw
Homelite mighty lite 26ss weedwacker won't start, its getting spark and gas.
http://www.fixya.com/support/t2258508-homelite_mighty_lite_26ss_weedwacker
May 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
180 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
