Question about Dayton (3VE50) Oil Filled Liquid Fuel Radiator Heater
Ignites about every one half second puff blue smoke when fire puff blue smoke will not run continous
  • 1,476 Answers
Statelinespe,
You have a classic reddy heat problem. Daytons are made by Desa the same as reddy heat so they are the same. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to get the parts to fix it.
Thanks fo using FixYa and for the great rating.
hardrocko
Posted on Dec 30, 2010
Craftsman. Starts up then cuts out after 20-30 seconds big puffs of smoke
What color is the smoke, white , blue, black?
Jan 22, 2016 | Garden
I am experiencing problems with my BMW 320i - 2004 model. It does not start easily. When it starts, a blue fuel smoke comes from the exhaust. this causes the car also to be heavy on fuel consumptio
Blue smoke is caused by oil. Rich running causes black smoke and will set the check engine light. Rich running (black smoke) on startup could be caused by a leaking injector. The blue smoke puff at startup is likely valve stem seals leaking or a bad crank case vent malfunction and sucking oil into the manifold at high vacuum conditions.
Nov 19, 2013 | BMW 320i Cars & Trucks
Smoke coming steering column
is it puffs of smoke or like a vapor. does it smell like coolant
Sep 09, 2013 | Nissan Altima Cars & Trucks
97 f250 5.8L starts to run rough and puffs out thick black smoke. It comes and goes. Any ideas?
Exhaust problems. Black smoke=exhaust, blue smoke=oil, white smoke=water.
Aug 05, 2010 | 1997 Ford F250 SuperCab
I have a a problem with my mr. heater. When I turn it on it puffs
Not knowing what Mr Heater Model you are referring to, I would suggest you call Mr.Heater's customer service line at 800.251.0001.
They have techs that can help troubleshoot your problem.
Dec 30, 2009 | Mr. Heater Portable Buddy
Jetta tdi 2007 running rough on start up at times. blowing excessive amounts of smoke from exhaust at times. poor idle at times feels like running on three and a half cylinders, takes a few seconds too...
You may want to check the ignition system. The smoke could be because of unburnt fuel. You may be running on less then 4 cylinders. Check if all spark plugs are firing. You may also want to use a scanner if there are error codes found in its ECU.
Jul 10, 2009 | 2003 Volkswagen Jetta TDI
Dayton (3VE50) Oil Filled Liquid Fuel Radiator Heater Logo
215 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
