Question about Weiser Lock Powerbolt 1000 Lock
Have no instructions and the lock unlocks when center button is pushed--I know there is a quick change but not sure what--thanks
  • 963 Answers
Here is a link to the Frequently asked question page for your lock:
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Posted on Mar 05, 2011
Cenral locking won open the tailgate fuse 1 ok
It normally DOES NOT Unlock with the Door Unlock. Depending on the Year/Make/Model. Some have a Separate Button, Some you have to Push 2 QUICK Unlocks for it to work, then there is one I ran into that you had to push it 3 times (I though that was odd).
One Quick Push = Drivers Doot
Two Quick Pushes = All Doors
Three Quick Pushes = Trunk
Apr 18, 2015 | Cars & Trucks
07 Convertible
This is easy, first locate the top button on the center console but do not push yet, next the lever on the front off the top, reach your right hand up and grab lever and pull down and twist counter clock wise to unlock it, you may feel roof pop up a little then with roof unlocked push handle back into its slot, next is push button and hold, the roof will start to open and the trunk will start to open and the roof will store away i the trunk,, make sure trunk is empty at first use, then with the top down and trunk closed you are done, open the trunk just to look inside to see where the top goes, this is to make sure nothing gets in the way of the roof, i cant remember if area is blocked off or not but this is a good idea just so you know.
To close the roof you hit and hold the button and roof will come out of the trunk area automaticlly the roof will end up closed all you do is pull lever down then pull on lever to close roof all the way untwist lever and it will go into lock, you will feel this, once it is in the lock groove you will twist lever to the right to lock it, with it locked you then push lever back into its slot. good day
May 06, 2012 | Cars & Trucks
How do i unlock
To unlock the Nokia N8 easily use the unlock code,get the unlock code from the site Onlinegsmunlock.com/nokia/rs7wp8/ and unlock it from Network Lock.Follow the instruction below and unlock it step by step.
Nokia N8 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia N8 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N8 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia N8 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N8.
3 - Compose #pw+CODE+1#.
4 - The Nokia N8 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N8 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia N
Jan 10, 2012 | Nokia N8 Cell Phone
How to put in four wheel drive
FOUR-WHEEL DRIVE SYSTEM
(a) Four-wheel drive control
Use the four-wheel drive control lever and center
differential lock button to select the following transfer and
center differential modes.
The "H" and "L" position of the four-wheel drive control lever
provides either lock or unlock mode of the center differential
depending on the center differential lock button position.
Use the center differential lock system if your wheels get stuck
in a ditch, or when you are driving on a slippery or bumpy
surface. When the center differential is locked, the vehicle
stability control system is automatically turned off and the
center differential lock and "VSC OFF" indicator lights come on
because the function that controls engine performance
As soon as the center differential lock switch is turned
on, the "VSC OFF" indicator light comes on. After the
wheels are out of the ditch or off the slippery or bumpy
surface, turn the center differential lock switch off.
Make sure the center differential lock indicator light and
vehicle stability control system off indicator light turn
off.
"H" (high speed position, center differential unlocked):
Lever at "H", center differential lock button left out
Use this for normal driving on all types of roads, from dry
hard-surfaced roads to wet, icy or snow-covered roads. This
position gives greater economy, quietest ride, least wear and
better vehicle control.
"H" (high speed position, center differential locked): Lever
at "H", center differential lock button pushed in
Use this for greater traction when you experience a loss of
power, such as wheel slipping, in the center differential unlock
mode.
"N" (neutral position): Lever at "N"
No power is delivered to the wheels. The vehicle must be
stopped.
"L" (low speed position, center differential unlocked):
Lever at "L", center differential lock button left out
Use this for maximum power and traction. Use this for climbing
or descending steep hills, off-road driving, and hard pulling in
sand or mud.
In this mode, the braking feeling that occurs when the wheels
are negotiating a sharp corner is further reduced than in the "L"
(low position, center differential locked) mode.
"L" (low speed position, center differential locked): Lever
at "L", center differential lock button pushed in
Use this for maximum power and traction. Use this for hard
pulling in situations the vehicle cannot negotiate even in the "L"
(low speed position, center differential unlocked) mode. Also,
using this mode when driving down steep off-road inclines will
help contribute to increased vehicle stability.
https://secure.drivers.lexus.com/lexusdrivers/info/my-lexus/resources/submit-owners-manual-search.do
Please copy and paste the link above and it will take you to the lexus site. There you will find the owners manual and you can download whatever sections you need for free.
Hope this helps.
Feb 11, 2011 | 2004 Lexus GX 470
Hello, Please help! My 1996 Mustang Gt car alarm wont let the car start. any suggestions? Ericf
use the key to lock and then unlock the drivers door then try to start if it still doesnt start then go to pass/side door and lock and unlock it and then try to start the switch on the drivers door may be bad, if this is a factory alarm system, if its aftermarket then you will need to locate the reset button under the dash, this will be a small red push type button, you will have to turn key on and push button in four times quickly, also are you sure its the alarm? it may be a bad battery or starter but start with the directions i gave first and let me know if it doesnt work make sure to relist the problem. good luck.
Jan 20, 2011 | 1996 Ford Mustang
Unlock nokia 5070
You can unlock your nokia 5070 mobile using unlock instructions provided at http://www.unlocking4u.com/nokia-5070/rs6wp9/ ..
Nokia 5070 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia 5070 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5070 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5070 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5070.
4 - The Nokia 5070 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5070 mobile phones locked to the network Fido in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia 5070.
Jan 27, 2010 | Cell Phones
Push numbers whilst talking on phone
1. FYI, when your call is dailed through successfully - please pay attention as there are two instructions on the screen. It tells you to press which button for dailing and which to press to unlock the screen.
2. To answer your question: On the left hand side of the phone, there are 3 buttons. Press the button at the bottom below the volume up & down buttons. The dailing screen should come up.
This button is also used as a shortcut for changing profiles quickly in the main screen.
Jan 22, 2010 | LG Prada KE850 Cellular Phone
Stanley 10-788 how to change blade
Push the top metal button all the way foward as if pushing the blade out to it's (farthest) 3rd setting. Then push foward and down one more time which locks the mechanism down. Push and hold the yellow side button as you insert the blade. When the blade locks in all you have to do is release the yellow button and return the top slide to it is fully retracted home. The blade is loaded
Jan 14, 2010 | Hand Tools
Alarm and door lock malfunction 1996 Camaro z28 LT1
Hey just wondering if you ever go this problem fixed. I am having the exact same issue. Thanks
Jul 03, 2009 | 1996 Chevrolet Camaro
Weiser Lock Powerbolt 1000 Lock Logo
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
