Question about Dryers
The barrel won't spin. the heat is still working, but the barrel won't spin. i may have overloaded the dryer (five pairs of jeans and three hooded sweatshirts) there was a loud bang noise and the barrel stopped spinning.
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
Roper RAS8333RQ0. If I put more than 4 or 5 pieces of clothing in it won't agitate or spin. I checked the lid switch and it seems to be OK, as it agitates just fine if the load is small enough.
A couple of ideas.
First, type in your model number to the web-site named: "SearsPartsDirect".
The schematics will show whether you have a drive belt on that model.
If there is, that belt may be slipping, or worn out.
Before you order a belt, consider this.
If the machine is not properly spinning out the water on the spin cycle, ( for example, if the belt were loose), then too much water may overload the machine causing your problem.
God bless your efforts.
Nov 27, 2017 | Roper Washing Machines
Tip
SENSOR DRY IN SAMSUNG DRYERS
As a tech, I'm constantly fielding questions about loads of clothes not drying properly in the larger Samsung dryers--and this tip can be used for a lot of dryers with the sensor-dry feature. Sensor drying uses a pair of metal strips located on the filter holder or on the back wall in the dryer. When wet clothes rub against the strips, this sends a signal to the main board which tells the dryer to keep going. Unless large loads are used, the consumer should use "timed dry". This is because smaller loads won't hit the sensor strips often enough and cause the computer to count down too rapidly. Also, consumers should try to make sure like items are placed with like items( shirts with shirts, pants with pants, towels with towels, etc) Thick clothing(jeans, heavy sweatshirts, etc.) usually will have damp spots like pockets due to the moisture not being able to contact the sensor strips--the technology is not 100%. Also, if there are problems with the timer starting to count down too rapidly all the time, and dryer sheets are used, the sensor strips may be coated with a waxy layer. Use some super fine emory cloth to polish the coating off of the sensor strips. You very well might find that the problem is solved and not have to initiate a service call!
on Sep 08, 2015 | Samsung Dryers
If I put more then 2 pair of jeans it won't spin out. Is the censor gone or barrel off
The barrel is out of balance. Remove the jeans and redistribute evenly, or wash fewer pairs of jeans at a time.
Feb 02, 2016 | Maytag Centennial Top Load Washer
Samsung dryer, model: DV317AEG turns on, but won't spin
Could be the motor is full of lint. Depending on how mechanically inclined you are take the belt off and spin the barrel and the motor separately motor should spin free, barrel a little harder to spin,but spin at least a quarter turn after letting go.
Jul 05, 2012 | Dryers
Tested every part for continuity, replaced ignitor, still no heat
If the dryer runs , but no heat , then the thermal fuse is probably the problem . Unplug the dryer and remove the lower front panel . Remove the inside filter from inside the dryer , and remove the filter housing form the front , held on by 2 screws and the clip holding it to the blower housing . You will see 2 wires going to a flat egg shaped piece ( you may not be able to see the piece , but you can see the wires ) . This is on the left of the visible thermostat . Remove the 2 wires from this piece and put them togather . Plug in dryer and see if burner lights then . If so , then replace the thermal fuse . Pt # 3392519 .
Sep 10, 2009 | Whirlpool GGQ8831L Gas Dryer
My 9150 doesn't spin well and my clothes are very wet, when they come out. Then when I try to spin & drain only, it wants to run for 4 hours. Looking at the problems how good of a product did I buy.
from the description you are giving, i would guess that: 1. the "coin-catcher" ahead of the pump is plugged. 2. the tub is overloaded. 3. the loads are heavy, bulky [ blankets, jeans, towels]. when a load is too big or it is all very absorbent materials, the machine tries to balance the load before it goes into a final spin, it will not spin on high if it cannot balance - remember, ten towels or pairs of jeans soaked with water is darned heavy - mix the loads i'm familiar with this machine because i have one, i repair washers and dryers as part of my job, in my opinion, the duet is the best and most reliable washer available
Aug 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine does not clean properly.
Let's start with the detergent and the water temperature. If they are the same as what you use at home,
then I have to assume the machine may be overloaded. Back off on the load by about 1/3 and see what happens. In the worst case scenario, you could let the jeans soak in the detergent/water mix over-night
Jun 17, 2009 | Daewoo DW500M Top Load Washer
New LG WM2688H*M Steam Washer
Your load is unbalanced, at least that is what is sounds like. Have you taken out all the shipping bolts?
These washers and dryers hold very little clothing, 3-4 pair of jeans or less if the person is really large and maybe three regular sized thick bath towels since they weight so much when wet. You must make sure you are not overloading your machines when in use.
Good luck and if you keep having problems I would take a look at the manual and call customer service to report this issue to them. Make sure you get a repair number for your records.
Jan 14, 2008 | LG WM2688H Front Load Washer
Kenmore Elite dryer shutting off several times...
Sounds like you have a high limit thermostat that is failing. Hence, the reason it works on light weight items, but not on heavier items where more heat is required. When replacing the high limit thermostat it's also a good idea to replace the thermal cut-out (they are usually sold in pairs). Both should be mounted somewhere near the heating element, and both have two wires going to them. Remove power to the dryer before servicing, however. There is one more thermostat the is called the operating thermostat. It has four wires going to it and is mounted near the blower fan housing. There's a chance it could be malfunctioning but I doubt it. Let me know what you find and if I can help any further.
Jun 06, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
93 people viewed this question
Top Dryers Experts
