Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore washer HE3 broken door latch. How do you replace
  • 347 Answers
Unplug unit then You can open the door, then remove the spring loaded clamp that secures the door boot (rubber) to the front panel, carefully pull the door boot away just where the door latch is (no reason to completely remove) remove the 3 screws securing the door latch to the front panel..Then reach behind the panel and pull the latch towards the opening the give just enough wiring to do so undo the 3 wiring connectors to the latch assy. then pull out the rest of the way Reverse the procedure to reinstall
Posted on Dec 29, 2010
3 Suggested Answers
watugot
  • 290 Answers
SOURCE: Kenmore Elite he3 front load washer
What you describe still sounds like a door switch problem but if you can run it through the diagnostic cycle then it should be ok.
The only thing different in starting diagnostics and starting normal cycle is you don't press the start button in diagnostics.
If you know how to put it into manual diagnostics you can check all the buttons to make sure they are working properly.
It is unusual to have 2 different problems at the same time and if the switch was broken, it definately would not start the cycle.
Put it into manual diagnostics and check the start button.
Post back and we will go from there.
Thanks/Mike
Posted on Nov 03, 2007
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
My kenmore he3 dryer door keeps opening when operating. Thus stopping the drying process. What should I check and replace?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The door latch is broken...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 08, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore model 110.42832.201 won't start, door won't lock - cycle selection button just flashes.
Hi, check you door latch. When you open the door, there should be a black square hole on the frame and a black round hole above it with a pin sticking out. The pin is probably broken off and the door latch assembly needs to be replaced.
Take care
Jul 19, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How do i replace kenmore washing machine latch
I'm assuming you are referring to the door latch assembly. The following link explains step-by-step how to replace the door latch on a Kemore Elite front loader:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Nov 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How to replace door lock on my kenmore elite washer he3
The following link explains step-by-step how to replace the door latch on a Kenmore Elite HE3:
This is a very simple repair. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Sep 07, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Door won't latch and dL and F come up
your dl (door latch) is broken replace it you can order it from searsparts.com
Apr 26, 2009 | Kenmore Washing Machines
Front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
HE3 Washer door will not open
chris unplug unit.take off bottem paneland reach up in door latch area.their is a tab you can pull to open locked door.is the washed draining.you may need to clean pump if not.God bless,tom
Dec 30, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kemore HE3 front load washer won't start
Check you door latch. When you open the door, there should be a black square hole on the frame and a black round hole above it with a pin sticking out. The pin is probably broken off and the door latch assembly needs to be replaced.
Jun 03, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
628 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
